void main(void)
GPIO_INIT();
DISI(); // 禁用所有未屏蔽的中斷
//AWUCON = 0X80; //0010 0000
// TMR0 = 0; // 加載0x00到TMR0(初始定時(shí)器寄存器)
//T0MD = 0X01; // 將precaler0賦給Timer0, precaler0分割率= 1:8,時(shí)鐘源為指令時(shí)鐘
//INTE = 0X01; // 使能定時(shí)器0中斷&PABIE狀態(tài)變化中斷
//;啟用Timer0和全局中斷位
//PCON1 = C_TMR0_En; // 啟用Timer0
ENI();
CLRWDT();
RX_SHUT=0;
CLRWDT();
Timer1_INIT();
soft_decodetask();
void isr(void) __interrupt(0)
if(INTFbits.T1IF) // 定時(shí)器0中斷 132 = 1MS
if(RFDecodeOK == 0)
if(!RX_DATA)
IR_Time_L++;
IR_Time_H=0;
if(JumpFlag && IR_Time_L > 4)
JumpFlag=0;
IR_Time_H++;
if(!JumpFlag && IR_Time_H > 4)
JumpFlag=1;
soft_decode();
IR_Time_L=0;
IR_Time_H=0;
INTF= (unsigned char)~(C_INT_TMR1); // 清除T0IF標(biāo)志位
/******************************定時(shí)器配置*************************************************/
void Timer1_INIT(void)
TMRH = 0;
TMR1 = 50; //50us
T1CR1 = 0x03;
T1CR2 = C_TMR1_ClkSrc_Inst | C_PS1_Div4;
INTE = 0x08;
/******************************中斷*************************************************/
void soft_decode() //解碼
static unsigned char RxBitCnt = 0; //接收數(shù)據(jù)位
static unsigned long RxData = 0; //數(shù)據(jù)緩沖
if(IR_State==0)
if((IR_Time_L >= 19) && (IR_Time < 25))
IR_State=1;
RxData=0;
RxBitCnt=0;
IR_State=0;
else if(IR_State==1 && RxBitCnt < 32)
if((IR_Time_L > 6) && (IR_Time_L < 9))
RxData = RxData<<1;
RxBitCnt++;
else if((IR_Time_L > 11) && (IR_Time_L < 14))
RxData = RxData<<1;
RxData |=1;
RxBitCnt++;
RxBitCnt=0;
IR_State=0;
if(IR_cnt>=32)
RxBitCnt=0;
IR_State=0;
RxUserCode = RxData >> 24;
if(RxUserCode == K1_NUM1)
RFDecodeOK = 1;
RX_flag = 1;
else if(RxUserCode == K1_NUM2)
RFDecodeOK = 1;
RX_flag = 2;
else if(RxUserCode == K2_NUM1)
RFDecodeOK = 1;
RX_flag = 3;
else if(RxUserCode == K2_NUM2)
RFDecodeOK = 1;
RX_flag = 4;
void soft_decodetask(void)
static unsigned int RxTimerCnt = 0;
if(RFDecodeOK)
RFDecodeOK = 0;
if(RX_flag==1){LED123=0;}
if(RX_flag==2){LED123=1;}
if(RX_flag==3){LED123=0;}
if(RX_flag==4){LED123=1;}
if(RFDecodeOK)
RxTimerCnt++;
if(RxTimerCnt >= 2000)
RxTimerCnt=0;
RFDecodeOK=0;
