提問:
近期,我在學(xué)習(xí)msp432p401r單片機(jī)時(shí),想用msp的adc進(jìn)行多通道采集,然后加上dma數(shù)據(jù)轉(zhuǎn)運(yùn)。以下是代碼起初我是直接用的dma里的adc通道,發(fā)現(xiàn)不行。然后我就仿照官方例程里的進(jìn)行數(shù)組到數(shù)組間的轉(zhuǎn)運(yùn) resultsBuffer -->adc 的轉(zhuǎn)運(yùn),結(jié)果還是失敗了
在主函數(shù)里我就是顯示了一下數(shù)組里的值,發(fā)現(xiàn)程序卡死。希望能得到大佬的幫助。
#include "headfile.h"
#include "adc.h"
#include "ml_oled.h"
//左到右 4.3 4.4 4.5 4.6 4.7
// 10 9 8 7 6
uint16_t adc[5];
uint16_t resultsBuffer[5];
void ADC_config(void)
/* 啟用浮點(diǎn)運(yùn)算的FPU */
MAP_FPU_enableModule();
MAP_FPU_enableLazyStacking();
/* Initializing ADC (MCLK/1/1) */
MAP_ADC14_enableModule(); //使能ADC14模塊
MAP_ADC14_initModule(ADC_CLOCKSOURCE_MCLK, ADC_PREDIVIDER_4, ADC_DIVIDER_5, ADC_NOROUTE); //初始化ADC 時(shí)鐘 分頻 通道 2.4MHz
MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P4, GPIO_PIN5 | GPIO_PIN6 | GPIO_PIN7| GPIO_PIN3| GPIO_PIN4, GPIO_TERTIARY_MODULE_FUNCTION);
// MAP_GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P5, GPIO_PIN1 | GPIO_PIN2, GPIO_TERTIARY_MODULE_FUNCTION); //
MAP_ADC14_configureMultiSequenceMode(ADC_MEM6, ADC_MEM10, true);
MAP_ADC14_configureConversionMemory(ADC_MEM6, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A6, ADC_NONDIFFERENTIAL_INPUTS);
MAP_ADC14_configureConversionMemory(ADC_MEM7, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A7, ADC_NONDIFFERENTIAL_INPUTS);
MAP_ADC14_configureConversionMemory(ADC_MEM8, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A8, ADC_NONDIFFERENTIAL_INPUTS);
MAP_ADC14_configureConversionMemory(ADC_MEM9, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A9, ADC_NONDIFFERENTIAL_INPUTS);
MAP_ADC14_configureConversionMemory(ADC_MEM10, ADC_VREFPOS_INTBUF_VREFNEG_VSS, ADC_INPUT_A10, ADC_NONDIFFERENTIAL_INPUTS);
ADC14_enableInterrupt(ADC_INT10);
/* Enabling Interrupts */
MAP_Interrupt_enableInterrupt(INT_ADC14); //ADC模塊的中斷
MAP_Interrupt_enableMaster();
/* Setting up the sample timer to automatically step through the sequence
* convert.
ADC14_enableSampleTimer(ADC_AUTOMATIC_ITERATION);
/* Triggering the start of the sample */
MAP_ADC14_enableConversion(); //使能開始轉(zhuǎn)換(觸發(fā)后 自動(dòng)ADC上電)
MAP_ADC14_toggleConversionTrigger(); //開啟第一次軟件觸發(fā)
////////////////////DMA配置///////////////////////////////
/* DMA Control Table 這一段是必須要有的*///
#if defined(__TI_COMPILER_VERSION__)
#pragma DATA_ALIGN(controlTable, 1024)
#elif defined(__IAR_SYSTEMS_ICC__)
#pragma data_alignment = 1024
#elif defined(__GNUC__)
__attribute__((aligned(1024)))
#elif defined(__CC_ARM)
__align(1024)
#endif
uint8_t controlTable[1024];
#define DAM_SIZE 1024
uint16_t data_array1[DAM_SIZE]; // DMA數(shù)組
void DMA_config(void)
MAP_WDT_A_holdTimer(); // 關(guān)閉看門狗
memset(data_array1, 0x11, DAM_SIZE); // 目標(biāo)數(shù)組初始化
DMA_enableModule(); // 使能DMA模塊
DMA_setControlBase(controlTable); // 設(shè)置控制表基地址
DMA_disableChannelAttribute(DMA_CH0_RESERVED0,
UDMA_ATTR_ALTSELECT | UDMA_ATTR_USEBURST |
UDMA_ATTR_HIGH_PRIORITY |
UDMA_ATTR_REQMASK); // 禁用通道特征
DMA_setChannelControl(UDMA_PRI_SELECT | DMA_CH0_RESERVED0, UDMA_SIZE_16 | UDMA_SRC_INC_16 | UDMA_DST_INC_16 | UDMA_ARB_1);
// 設(shè)置通道控制參數(shù) ADC映射 主數(shù)據(jù)結(jié)構(gòu) 16位數(shù)據(jù)大小 源地址增量 目標(biāo)地址增量 仲裁大小
DMA_setChannelTransfer(UDMA_PRI_SELECT | DMA_CH0_RESERVED0, UDMA_MODE_AUTO, resultsBuffer, adc, 5);
// 設(shè)置通道傳輸參數(shù) ADC映射 主數(shù)據(jù)結(jié)構(gòu) 自動(dòng)模式 源數(shù)據(jù) 目標(biāo)數(shù)據(jù) 傳輸數(shù)量
MAP_Interrupt_disableSleepOnIsrExit();
DMA_requestChannel(0);
// DMA_assignChannel(DMA_CH0_RESERVED0); // 指定外設(shè)映射
DMA_assignInterrupt(DMA_INT0, 0);
Interrupt_enableInterrupt(INT_DMA_INT0);
DMA_clearInterruptFlag(0);
DMA_enableChannel(0);
DMA_requestSoftwareTransfer(0); //
void DMA_INT1_IRQHandler(void)
/* Switch between primary and alternate bufferes with DMA's PingPong mode */
adc, 5);
void ADC14_IRQHandler(void)
uint_fast64_t status = MAP_ADC14_getEnabledInterruptStatus();
MAP_ADC14_clearInterruptFlag(status);
if (ADC_INT10 & status)
MAP_ADC14_getMultiSequenceResult(resultsBuffer);
