查看: 1339|回復: 0
九齊單片機的ADC采樣程序
ID:1125252 發表于 2024-7-10 19:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
unsigned int ADC_count(void);
void ADC_INIT(void);
void F_AIN4_Convert(char count);
void ADC_Close(void);
void F_wait_eoc(void);
void main(void)
    ADC_INIT();
         temp=ADC_count();
         VDD=temp*4/4096;
    unsigned int temp;
    R_AIN4_DATA=R_AIN4_DATA_LB=0x00;
    F_AIN4_Convert(8);
    R_AIN4_DATA <<= 4;                    // R_AIN0_DATA shift left 4 bit
    R_AIN4_DATA_LB &= 0x7F;                // Only get Bit6~0
    R_AIN4_DATA += R_AIN4_DATA_LB;        // R_AIN0_DATA + R_AIN0_DATA_LB
    R_AIN4_DATA >>=3;
    temp=R_AIN4_DATA;
    return temp;
void ADC_INIT(void)
    ADMD  = C_ADC_En | C_ADC_CH_Dis | C_ADC_PA4 ;
    ADVREFH = C_Vrefh_VDD;
    ADR      = C_Ckl_Div8;
    ADCR  = C_Sample_1clk | C_12BIT;
    //PACON=0X10;
    ADMDbits.GCHS = 1;
    delay(50);
    //temp=(R_AIN4_DATA*4)/4096;
      char i;
      ADMD  = 0x90 | C_ADC_PA4;                // Select AIN0(PA0) pad as ADC input
      for(i=1;i<=count;i++)
       ADMDbits.START = 1;                    // Start a ADC conversion session
       F_wait_eoc();                            // Wait for ADC conversion complete
       R_AIN4_DATA_LB += ( 0x0F & ADR);
       R_AIN4_DATA    += ADD;
    ADMD=0;
   while(ADMDbits.EOC==0)
收藏收藏3 分享淘帖 頂1 踩
