/********************獲取按鍵函數(shù)**********************/
unsigned char Get_keynum(void)
unsigned char temp;
temp=key_num;
key_num=0;
return temp;
unsigned char key_Getnum(void)
unsigned keynum=0;
if(K1==0){keynum=1;}
return keynum;
void key_scan(void)
static unsigned lastkey,nowkey;
lastkey=nowkey;
nowkey=key_Getnum();
if(lastkey==1 && nowkey==0)
key_num=1;
}/****************************配置定時器0********************************/
void Timer0_Init(void)
PCON1 = C_TMR0_Dis;
//1ms
//TMRH = 0X30;
TMR0 = 5; //計(jì)算頻率16M/2/2=4M=4000000HZ=4us 4us*(255-5)=1000us
T0MD = C_PS0_TMR0 | C_PS0_Div2;
INTE = C_INT_TMR0;
PCON1 = C_TMR0_En;
#endif
/***************************中斷************************************/
void isr(void) __interrupt(0)
if(INTFbits.PBIF)
INTFbits.PBIF = 0; // Clear PBIF(PortB input change interrupt flag bit)
INTF= (unsigned char)~(C_INT_PBKey);// Clear PBIF(PortB input change interrupt flag bit)
if(INTFbits.T0IF)
tim++;
if(tim>=25)
key_scan();
tim=0;
INTF= (unsigned char)~(C_INT_TMR0); // Clear T0IF flag bit
/***************************主函數(shù)************************************/
void main(void)
GPIO_INIT();
DISI();
Timer0_Init();
//Timer1_Init();
ENI();
//KEY1_INIT();
CLRWDT();
key=Get_keynum();
if(key==1)
num++;
if(num>=10)
num=0;
if(num=1){}
if(num=2){}
