我自己寫了個(gè)程序: #include<reg52.h> #define uint unsigned int #define uchar unsigned char uchar num;num1; uchar code table[]={ 0xC0,0xF9,0xA4,0xB0, 0x99,0x92,0x82,0xF8, 0x80,0x90,0x88,0x83, 0xC6,0xA1,0x86,0x8E,0x89}; uchar code table1[]={ 0xfe,0xFd,0xfb,0xf7, 0xef,0xdf,0xbf,0x7f}; void delay(uint z); void main() { num=0; num1=0; while(1) { P2=table1[num1]; num1++; delay(1000); if(num1==8) { num1=0; } P0=table[num]; num++; delay(1000); if(num==16) { num=0; } } } void delay(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); }
k2.rar
(61.37 KB, 下載次數(shù): 22)
2009-8-30 21:14 上傳
點(diǎn)擊文件名下載附件
[此貼子已經(jīng)被作者于2009-8-30 21:14:14編輯過]
