只需一步,快速開(kāi)始
查看: 1799|回復(fù): 2
stm32驅(qū)動(dòng)數(shù)碼管動(dòng)態(tài)顯示為何不亮?附單片機(jī)仿真程序
ID:1061677 發(fā)表于 2024-3-16 09:47 | 顯示全部樓層 |閱讀模式
主程序
#include "stm32f10x.h"  // Device header
#include "Delay.h"
uint16_t temp, i, j;
uint8_t table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //定義0~9的共陰極
uint16_t wei[] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xff,0xff}; //位碼
uint16_t disp[2];
int main(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC,ENABLE); //使能GPIOB和GPIOC時(shí)鐘
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //配置PB口為推挽輸出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //GPIOB速度為50MHz
        GPIO_Init(GPIOB,&GPIO_InitStructure);   //初始化PB口
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //配置PC口為推挽輸出
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //GPIOC速度為50MHz
        GPIO_Init(GPIOC,&GPIO_InitStructure);   //初始化PC口
                for(i=1;i<7;i++)
                        GPIO_Write(GPIOB,wei[i-1]);
                        GPIO_Write(GPIOC,table[ i]);
                        Delay_ms(2);
                        GPIO_Write(GPIOB,0xff);
                        Delay_ms(2);
希望有人看到能夠幫一下,實(shí)在搞不懂啦。
仿真程序.7z
225.23 KB, 下載次數(shù): 5
程序何proteus仿真
ID:94031 發(fā)表于 2024-3-17 06:12 | 顯示全部樓層
ID:1061677 發(fā)表于 2024-3-17 11:58 | 顯示全部樓層
xuyaqi 發(fā)表于 2024-3-17 06:12
你沒(méi)有將單片機(jī)與程序關(guān)聯(lián)起來(lái)。
您好,又試了一遍,已經(jīng)亮了。但還是有點(diǎn)問(wèn)題。我想問(wèn)一下,這個(gè)數(shù)碼管動(dòng)態(tài)顯示,單片機(jī)晶振如果是72Mhz的話,根據(jù)這個(gè)延時(shí)函數(shù),Delay_ms()這個(gè)參數(shù)應(yīng)該是多長(zhǎng)時(shí)間呢?
