有沒有大佬幫忙看一下怎么解決
單片機(jī)源程序如下:
#include <reg52.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
sbit KEY_OPEN = P3^3; //引腳定義
sbit KEY_CLOSE = P3^5;
sbit LED_GREEN = P2^1;
sbit LED_RED = P2^2;
sbit BUZZER = P2^0;
#define BUZZER_ON (BUZZER = 0)
#define BUZZER_OFF (BUZZER = 1)
sbit SHAKE_PIN = P1^1; //震動傳感器
sbit HC_SR501 = P1^0; //人體活動傳感器
sbit RELAY_LOCK = P2^3; //電磁鎖
bit g_irFlag = 0; //紅外接收標(biāo)志,收到一幀正確數(shù)據(jù)后置1
unsigned char g_irCode[4];
unsigned char refreshFlag = 0; //更新顯示標(biāo)志
unsigned char setFlag = 0; //設(shè)置參數(shù)標(biāo)志
bit lockFlag = 1; //鎖的狀態(tài)標(biāo)志
bit monitorFlag = 0; //監(jiān)控標(biāo)志
bit alarmFlag = 0; //報警標(biāo)志
unsigned char time500msCnt = 0;
unsigned char time500msCnt2 = 0;
bit oldPinState = 0;
bit nowPinState = 0;
char dis0[16]; //定義顯示區(qū)域臨時存儲數(shù)組
void CheckKey(void);
void CheckBluetooth(void);
void Timer1_Init(void); //定時器初始化
void main(void)
IR_INPUT = 1; 110.c(49): error C141: syntax error near '=', expected 'hdata' ,110.c(49): error C141: syntax error near '=', expected '__asm'
Timer1_Init();
IR_Init();
Uart_Init();
LCD_Init(); //初始化液晶
DelayMs(200); //延時有助于穩(wěn)定
LCD_Clear(); //清屏
LCD_DispStr(0, 0, " Welcome! ");
DelayS(1);
LCD_DispStr(0, 0, " Waiting... ");
DelayS(5);
err_num = GSM_Init(); //GSM初始化
DelayMs(10);
if (gsm_init_flag) //初始化完成
err_num = GSM_Text_Mode(); //GSM 設(shè)置Text模式
DelayMs(10);
if (gsm_config_flag)
err_num = GSM_Delete_Sms("1"); //刪除短信1
DelayMs(10);
if (!(gsm_init_flag || gsm_config_flag || gsm_delete_flag)) // AT命令報錯
BUZZER_ON;
LCD_DispStr(0, 0, " Init Err Num ");
LCD_WriteData((int)err_num+'0');
DelayS(1);
BUZZER_OFF;
LCD_DispStr(0, 0, " Init OK! ");
DelayS(3);
EEPROM52_Init(); //初始化電話號碼
LCD_DispStr(0, 0, " Status ");
while (1) //主循環(huán)
gsm_receive_process(); //gsm接收處理
if (lockFlag == 1) //已上鎖
LED_RED = 0;
LED_GREEN = 1;
RELAY_LOCK = 1; //關(guān)閉鎖
if (alarmFlag == 0)
if (HC_SR501 == 0 && SHAKE_PIN == 0) //有人且震動
monitorFlag = 1;
if (monitorFlag == 1) //進(jìn)入監(jiān)控狀態(tài)
if (time500msCnt >= 10 && time500msCnt <= 20) //進(jìn)入監(jiān)控模式后的5s~10s,持續(xù)監(jiān)測
if (HC_SR501 == 0 && SHAKE_PIN == 0) //再次檢測到有人且震動
alarmFlag = 1;
time500msCnt = 0;
BUZZER_ON;
LCD_DispStr(0, 1, " Warning! ");
GSM_Send_Sms(phone1, "Please pay attention to your car!");
DelayMs(10);
else if (time500msCnt > 20) //超過10s沒檢測到
monitorFlag = 0; //退出監(jiān)控
time500msCnt = 0;
time500msCnt = 0;
BUZZER_OFF;
else //報警模式
if (time500msCnt >= 120) //響鈴1分鐘退出報警模式
alarmFlag = 0;
LED_RED = 1;
LED_GREEN = 0;
alarmFlag = 0;
monitorFlag = 0;
RELAY_LOCK = 0; //打開鎖
BUZZER_OFF;
if (refreshFlag == 1) //刷新界面
refreshFlag = 0;
TR1 = 0;
if (alarmFlag == 0)
time500msCnt++;
time500msCnt = 0;
LCD_DispStr(0, 1, " Lock ");
else //報警模式
time500msCnt++;
LCD_DispStr(0, 1, " Open ");
if (time500msCnt2 > 0)
time500msCnt2--;
RELAY_LOCK = 0; //關(guān)閉鎖
LED_RED = 0;
LED_GREEN = 1;
lockFlag = 1;
TR1 = 1;
CheckKey(); //檢測按鍵
void CheckKey(void)
static unsigned char rekey = 0;
if ((KEY_OPEN == 0) || (KEY_CLOSE == 0)) //檢測到按鍵按下
DelayMs(10); //小抖動
if (rekey == 0)
if (KEY_OPEN == 0) //檢測是否按下
rekey = 1;
lockFlag = 0;
time500msCnt2 = 20; //開鎖20*500ms=10s
else if (KEY_CLOSE == 0) //
rekey = 1;
lockFlag = 1;
rekey = 0; //防止重復(fù)檢測到按鍵
if (g_irFlag == 1 && g_irCode[2] == IRCodeMap[0][0])
lockFlag = 0;
g_irFlag = 0;
else if (g_irFlag == 1 && g_irCode[2] == IRCodeMap[2][0])
lockFlag = 1;
g_irFlag = 0;
*************************************紅外解碼定時器程序********************************************
//外部中斷解碼程序_外部中斷0
void Ext0_Interrupt(void) interrupt 0
unsigned char i, j;
unsigned char byt;
unsigned int time;
time = IR_GetLowTime();
if ((time < 7833) || (time > 8755))
IE0 = 0;
return;
} //找到啟始碼
time = IR_GetHighTime();
if ((time < 3686) || (time > 4608)) //時間判定范圍為4.0~5.0ms,
{ //超過此范圍則說明為誤碼,直接退出
IE0 = 0;
return;
//接收并判定后續(xù)的4 字節(jié)數(shù)據(jù)
for (i = 0; i < 4; i++) //循環(huán)接收4 個字節(jié)
for (j = 0; j < 8; j++) //循環(huán)接收判定每字節(jié)的8 個bit
//接收判定每bit 的560us 低電平
if ((time < 313) || (time > 718)) //時間判定范圍為340~780us,
IE0 = 0;
return;
//接收每bit 高電平時間,判定該bit 的值
if ((time > 313) && (time < 718)) //時間判定范圍為340~780us,
{ //在此范圍內(nèi)說明該bit 值為0
byt >>= 1; //因低位在先,所以數(shù)據(jù)右移,高位為0
else if ((time > 1345) && (time < 1751)) //時間判定范圍為1460~1900us,
{ //在此范圍內(nèi)說明該bit 值為1
byt |= 0x80; //高位置1
else //不在上述范圍內(nèi)則說明為誤碼,直接退出
IE0 = 0;
return;
g_irCode[ i] = byt; //接收完一個字節(jié)后保存到緩沖區(qū)
g_irFlag = 1; //接收完畢后設(shè)置標(biāo)志
IE0 = 0; //退出前清零INT0 中斷標(biāo)志
定時器初始化子程序
TMOD &= 0x0F; //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
TMOD |= 0x10; //使用模式1,16位定時器,使用"|"符號可以在使用多個定時器時不受影響
TH1 = (65536 - 18432) / 256; //重新賦值 20ms
TL1 = (65536 - 18432) % 256;
EA = 1; //總中斷打開
ET1 = 1; //定時器中斷打開
TR1 = 1; //定時器開關(guān)打開
定時器中斷子程序
void Timer1_Interrupt(void) interrupt 3
static unsigned char time20ms = 0;
time20ms++;
if (time20ms >= 25)
refreshFlag = 1;
time20ms = 0;
