查看: 1371|回復: 2
C語言函數聲明報錯error C141: syntax error near '*', expected ')'
ID:1111671 發表于 2024-2-29 19:08 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#ifndef __W25Q32_H_
#define __W25Q32_H_
#include "main.h"
#define PAGESIZE      256//一頁最多輸入256字節
//SPI IO控制
#define SPI_SCL_1(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uSCL_Port, (_HANDLE_)->uSCL_Pin, 1))
#define SPI_SCL_0(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uSCL_Port, (_HANDLE_)->uSCL_Pin, 0))
#define SPI_MOSI_1(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMOSI_Port, (_HANDLE_)->uMOSI_Pin, 1))
#define SPI_MOSI_0(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMOSI_Port, (_HANDLE_)->uMOSI_Pin, 0))
#define SPI_MISO_1(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMISO_Port, (_HANDLE_)->uMISO_Pin, 1))
#define SPI_MISO_0(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMISO_Port, (_HANDLE_)->uMISO_Pin, 0))
#define SPI_CS_1(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uCS_Port, (_HANDLE_)->uCS_Pin, 1))
#define SPI_CS_0(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uCS_Port, (_HANDLE_)->uCS_Pin, 0))
#define SPI_MISO_R(_HANDLE_)        ( GPIO_ReadPin((_HANDLE_)->uMISO_Port, (_HANDLE_)->uMISO_Pin))
extern void  vW25Q32_Init(SPI_ObjectTypedef * hSPIx,
        uint8_t             uSCL_Port,
        uint8_t             uSCL_Pin ,
                   uint8_t             uMOSI_Port,
                   uint8_t             uMOSI_Pin ,
                   uint8_t             uMISO_Port,
                   uint8_t             uMISO_Pin ,
        uint8_t             uCS_Port,
                   uint8_t             uCS_Pin);
//獲取Flash ID
extern uint32_t W25Q32_Read_ID(SPI_ObjectTypedef * hSPIx);
//寫使能(啟動)
extern void W25Q32_Write_Enable(SPI_ObjectTypedef * hSPIx);
//等待保護(等待擦除或寫入操作,直到操作完成結束)
extern void W25Q32_Wait_End(SPI_ObjectTypedef * hSPIx);
//讀操作,*buf為內容,addr為地址,pagesize為要讀出的字節數
extern void W25Q32_Read_Page(SPI_ObjectTypedef * hSPIx, uint8_t *buf,uint32_t addr,uint8_t pagesize);
//芯片擦除,非易失存儲器,寫數據前應該擦除操作
extern void W25Q32_Delete(SPI_ObjectTypedef * hSPIx);
//頁寫操作,*buf為內容,addr為地址,pagesize為寫入字節數必須小于256個
extern void W25Q32_Write_Page(SPI_ObjectTypedef * hSPIx,uint8_t *buf, uint32_t addr,uint8_t pagesize);
#endif
Core\W25Q32.h(25): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(39): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(41): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(43): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(45): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(47): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(49): error C141: syntax error near '*', expected ')'
想問一下,為什么每個聲明語句都有報錯
ID:883242 發表于 2024-3-1 16:54 | 只看該作者
這種#define不太好,inline更好一些。比如:
我會寫成:
inline void SPI_SCL_1(_HANDLE_) { GPIO_WritePin((_HANDLE_)->uSCL_Port, (_HANDLE_)->uSCL_Pin, 1))}
不過雖然編譯器都支持inline,但是這并不是c語言標準關鍵字,要查編譯器手冊才可以。
ID:161164 發表于 2024-2-29 20:59 | 只看該作者
要加分行符
  1. extern void  vW25Q32_Init(SPI_ObjectTypedef * hSPIx, \
  2.                                                         uint8_t uSCL_Port, \
  3.                                                         uint8_t uSCL_Pin, \
  4.                                                         uint8_t uMOSI_Port, \
  5.                                                         uint8_t uMOSI_Pin, \
  6.                                                         uint8_t uMISO_Port, \
  7.                                                         uint8_t uMISO_Pin, \
  8.                                                         uint8_t uCS_Port, \
  9.                                                         uint8_t uCS_Pin);
