查看: 2238|回復: 1
Proteus仿真stm32 PWM直流電機出現Speed超出預設范圍的值
ID:783421 發表于 2024-2-26 23:58 | 顯示全部樓層 |閱讀模式
存在問題:預期的Speed是在-100~100,但實際proteus仿真,反轉時Speed為何存在超出范圍的數值
main.c代碼:#include "stm32f10x.h"
#include  "OLED.h"
#include "delay.h"
#include "Dc_Motor.h"
#include "key.h"
u8 Key;
int8_t Speed;
int main(void)
        delay_init();
        OLED_Init();
        Key_Init();
        Dc_Motor_Init();
        OLED_Clear();
        OLED_ShowString(1,1,"Key:");
        OLED_ShowString(2,1,"Speed:");
        Dc_Motor_SetSpeed(0);
                Key=Key_GetNum();
                if (Key == 1)
                        Speed += 30;
                        if (Speed > 100)
                                Speed = -100;
                        OLED_ShowString(1,5,"+");
                        OLED_ShowNum(2,7,Speed,6);
                if (Key == 2)
                        Speed -= 40;
                        if (Speed < -100)
                                Speed = 100;
                        OLED_ShowString(1,5,"-");
                Dc_Motor_SetSpeed(Speed);
PWM.c代碼:
#include "PWM.h"
void PWM_Init(void)
        //開啟定時器2時鐘
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
        //開啟GPIOA時鐘
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        //GPIOA配置
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        //GPIOA初始化
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        TIM_InternalClockConfig(TIM2);//TIM2 選擇定時器的內部時鐘源
        //時基單元配置
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        //時鐘分頻:1,2,4分頻
        TIM_TimeBaseInitStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        //計數器計數方式:向上、向下、中央對齊計數
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
        //設置ARR時鐘周期
        TIM_TimeBaseInitStructure.TIM_Period=100-1;//ARR:10000個數后重裝
        //設置PSC預分頻的值
        TIM_TimeBaseInitStructure.TIM_Prescaler=720-1;//PSC:720分頻,計數頻率100k
        //重復計數器的值,高級定時器,這里用不到設置為0
        TIM_TimeBaseInitStructure.TIM_RepetitionCounter=0;
        //時基單元初始化
        TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructure);
        //初始化配置定時器輸出比較單元:TIM_OC
        TIM_OCInitTypeDef TIM_OCInitStructure;
        TIM_OCStructInit(&TIM_OCInitStructure);
        //輸出比較的模式:PWM1模式
        TIM_OCInitStructure.TIM_OCMode=TIM_OCMode_PWM1;
        //輸出比較的極性:高極性:極性不翻轉
        TIM_OCInitStructure.TIM_OCPolarity=TIM_OCPolarity_High;
        //設置輸出使能
        TIM_OCInitStructure.TIM_OutputState=TIM_OutputState_Enable;
        //設置捕獲比較寄存器CCR的值
        TIM_OCInitStructure.TIM_Pulse=0;
        //輸出比較單元,通道3初始化
        TIM_OC3Init(TIM2,&TIM_OCInitStructure);
        //使能TIM2
        TIM_Cmd(TIM2,ENABLE);
void PWM_SetCompare1(u16 Compare)
        //修改CCR值
        TIM_SetCompare1(TIM2,Compare);
void PWM_SetCompare2(u16 Compare)
        //修改CCR值
        TIM_SetCompare2(TIM2,Compare);
void PWM_SetCompare3(u16 Compare)
        //修改CCR值
        TIM_SetCompare3(TIM2,Compare);
Dc_Motor.c代碼:
void Dc_Motor_Init(void)
        //電機速度控制設置
        PWM_Init();
        //電機方向控制設置
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
void Dc_Motor_SetSpeed(int8_t Speed)
        //正轉
        if (Speed > 0)
                GPIO_SetBits(GPIOA, GPIO_Pin_4);//AIN1:H
                GPIO_ResetBits(GPIOA, GPIO_Pin_5);//AIN2:L
                PWM_SetCompare3(Speed);
        //反轉
        else if(Speed < 0)
                GPIO_ResetBits(GPIOA, GPIO_Pin_4);//AIN1:L
                GPIO_SetBits(GPIOA, GPIO_Pin_5);//AIN2:H
                PWM_SetCompare3(-Speed);
        //停止
//                PWM_SetCompare3(-Speed);
key.c代碼:
#include "key.h"
void Key_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//GPIOB
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //設置上拉模式 GPIO_Mode_IPU
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1|GPIO_Pin_11;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_SetBits(GPIOB,GPIO_Pin_1|GPIO_Pin_11);
uint8_t Key_GetNum(void)
        uint8_t KeyNum = 0;
        if(GPIO_ReadInputDataBit(GPIOB , GPIO_Pin_1)==0)
                delay_ms(20);
                while(GPIO_ReadInputDataBit(GPIOB , GPIO_Pin_1)==0);
                delay_ms(20);
                KeyNum=1;
        else if(GPIO_ReadInputDataBit(GPIOB , GPIO_Pin_11)==0)
                delay_ms(20);
                while(GPIO_ReadInputDataBit(GPIOB , GPIO_Pin_11)==0);
                delay_ms(20);
                KeyNum=2;
        return KeyNum;
仿真程序TIM2_out_compare_dc_motor.7z
314.64 KB, 下載次數: 16
ID:94031 發表于 2024-2-27 11:38 | 顯示全部樓層
Speed算出來的值沒有問題,應該是OLED顯示與仿真問題
