查看: 1737|回復: 0
stm32f103c8t6+sx1278無線433 lora程序分享
ID:1111542 發表于 2024-2-25 18:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
stm32f103c8t6+sx1278無線433lora程序分享,安信可sx1278模塊遠距離無線傳輸.
#include "stm32f10x.h"
#include "HAL_uart.h"
#include "usmart.h"
#include "string.h"
#include "radio.h"
#include "delay.h"
#define USE_BAND_433        // 選擇一個頻率
#define USE_MODEM_LORA        // 選擇lora模式
#if defined(USE_BAND_433)
#define RF_FREQUENCY 434000000 // Hz
#elif defined(USE_BAND_780)
#define RF_FREQUENCY 780000000 // Hz
#elif defined(USE_BAND_868)
#define RF_FREQUENCY 868000000 // Hz
#elif defined(USE_BAND_915)
#define RF_FREQUENCY 915000000 // Hz
#else
#error "Please define a frequency band in the compiler options."
#endif
#define TX_OUTPUT_POWER 20 // dBm
#if defined(USE_MODEM_LORA)
#define LORA_BANDWIDTH 0   // [0: 125 kHz, 1: 250 kHz,  2: 500 kHz, 3: 保留]
#define LORA_SPREADING_FACTOR 7  // [SF7..SF12]
#define LORA_CODINGRATE 1        // [1: 4/5, 2: 4/6, 3: 4/7, 4: 4/8]
#define LORA_PREAMBLE_LENGTH 8   // 發送和接收的前導碼長度相同
#define LORA_SYMBOL_TIMEOUT 5    // 符號
#define LORA_FIX_LENGTH_PAYLOAD_ON false
#define LORA_IQ_INVERSION_ON false
#elif defined(USE_MODEM_FSK)
#define FSK_FDEV 25e3             // Hz
#define FSK_DATARATE 50e3         // bps
#define FSK_BANDWIDTH 50e3        // Hz
#define FSK_AFC_BANDWIDTH 83.333e3 // Hz
#define FSK_PREAMBLE_LENGTH 5     // 發送和接收的前導碼長度相同
#define FSK_FIX_LENGTH_PAYLOAD_ON false
#else
#error "Please define a modem in the compiler options."
#endif
#define RX_TIMEOUT_VALUE 1000
#define BUFFER_SIZE 64 // 定義數據包大小
#define MSG "hello"
uint16_t BufferSize = BUFFER_SIZE;
uint8_t Buffer[BUFFER_SIZE];
int8_t RssiValue = 0;
int8_t SnrValue = 0;
* 定義射頻事件函數指針的結構體:RadioEvents
static RadioEvents_t RadioEvents;
* \brief 射頻發送完成事件處理函數
void OnTxDone(void);
* \brief 射頻接收完成事件處理函數
void OnRxDone(uint8_t *payload, uint16_t size, int16_t rssi, int8_t snr);
* \brief 射頻發送超時事件處理函數
void OnTxTimeout(void);
* \brief 射頻接收超時事件處理函數
void OnRxTimeout(void);
* \brief 射頻接收錯誤事件處理函數
void OnRxError(void);
* USART1回調函數,用于處理接收到的數據
void uart1callBackTest(uint8_t data);
* LED和按鍵初始化
void ledInit(void);
int main(void)
    bool isMaster = true; // 設定為主機
    // bool isMaster = false; // 設定為從機
    uint32_t count = 0;
    delay_init(); // 延時函數初始化
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); // 中斷優先級分組配置
    HALUart1Init(115200, uart1callBackTest);
    ledInit();
    if (isMaster)
        printf("This is master\r\n");
        printf("This is slave\r\n");
    // 使用usmart庫進行遠程調試
    usmart_dev.init(SystemCoreClock/1000000); // 初始化usmart
    // 射頻初始化
    Radio.Init(&RadioEvents);
    Radio.SetChannel(RF_FREQUENCY);
    Radio.SetTxConfig(MODEM_LORA, TX_OUTPUT_POWER, 0, LORA_BANDWIDTH,
                      LORA_SPREADING_FACTOR, LORA_CODINGRATE,
                      LORA_PREAMBLE_LENGTH, LORA_FIX_LENGTH_PAYLOAD_ON,
                      true, 0, 0, LORA_IQ_INVERSION_ON, 3000);
    Radio.SetRxConfig(MODEM_LORA, LORA_BANDWIDTH, LORA_SPREADING_FACTOR,
                      LORA_CODINGRATE, 0, LORA_PREAMBLE_LENGTH,
                      LORA_SYMBOL_TIMEOUT, LORA_FIX_LENGTH_PAYLOAD_ON,
                      0, true, 0, 0, LORA_IQ_INVERSION_ON, true);
    if (!isMaster)
        Radio.Rx(RX_TIMEOUT_VALUE);
    while (1)
        if (isMaster)
            count = 0;
            while (GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_13) == 0)
                delay_ms(2);
                if (count++ > 50)
                    // 按鍵被按下
                    printf("Sent message\r\n");
                    Radio.Send((uint8_t *)MSG, strlen(MSG));
                    delay_ms(3000);
* 射頻發送完成事件處理函數
void OnTxDone(void)
    Radio.Sleep();
    printf("TxDone\r\n");
* 射頻接收完成事件處理函數
    static bool ledStatus = false;
    Radio.Sleep();
    memset(Buffer, 0, BUFFER_SIZE);
    BufferSize = size;
    memcpy(Buffer, payload, BufferSize);
    RssiValue = rssi;
    SnrValue = snr;
    printf("RxDone\r\nrssi:%d\r\nsnr:%d\r\nsize:%d\r\ndata:payload:%s\r\n", rssi, snr, size, payload);
    if (strncmp((const char *)Buffer, (const char *)MSG, 4) == 0)
        if (ledStatus)
            GPIO_ResetBits(GPIOB, GPIO_Pin_12);
            GPIO_SetBits(GPIOB, GPIO_Pin_12);
        ledStatus = !ledStatus;
* 射頻發送超時事件處理函數
    Radio.Sleep();
    printf("TxTIMEOUT\r\n");
* 射頻接收超時事件處理函數
    Radio.Sleep();
    printf("RxTIMEOUT retry recive\r\n");
* 射頻接收錯誤事件處理函數
    Radio.Sleep();
    printf("RxError  retry recive\r\n");
    uint8_t Res;
    Res = USART_ReceiveData(USART1); // 讀取接收到的數據
    if ((USART_RX_STA & 0x8000) == 0) // 接收未完成
        if (USART_RX_STA & 0x4000) // 接收到了0x0d
            if (Res != 0x0a)
                USART_RX_STA = 0; // 接收錯誤,重新開始
                USART_RX_STA |= 0x8000; // 接收完成
        else // 還沒收到0X0D
            if (Res == 0x0d)
                USART_RX_STA |= 0x4000;
                USART_RX_BUF[USART_RX_STA & 0X3FFF] = Res;
                USART_RX_STA++;
                if (USART_RX_STA > (USART_REC_LEN - 1))
                    USART_RX_STA = 0; // 接收數據錯誤,重新開始接收
* LED和按鍵的初始化
void ledInit(void)
    // 初始化LED
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    // 初始化按鍵
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
原理圖: 無
仿真: 無
代碼: SX127xLED點對點控制demo.7z (462.08 KB, 下載次數: 20)
