查看: 1142|回復: 1
STM8單片機想用按鍵來控制PWM輸出頻率,現在寫好后發現按鍵無反應,求大佬
ID:792289 發表于 2024-2-18 13:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "STM8S.h"
unsigned char  a=20;
signed long int  pwm_duty;
void delay_ms (int ms) //延時函數
for (int i=0; i<=ms; i++)
for (int j=0; j<120; j++); // Nop = Fosc/4
void KEY(void)
GPIO_DeInit(GPIOC);//D口默認狀態
GPIO_Init(GPIOC, GPIO_PIN_5, GPIO_MODE_IN_FL_NO_IT);
GPIO_Init(GPIOC, GPIO_PIN_4, GPIO_MODE_IN_FL_NO_IT);
        if (GPIO_ReadInputPin(GPIOC,GPIO_PIN_5) == 0)        //加1按鍵有效
            delay_ms(20);
            //延時去抖 一般10-20ms
                while (GPIO_ReadInputPin(GPIOC,GPIO_PIN_5) == 0);
                if (a < 41)
                  a = a+1;
        if (GPIO_ReadInputPin(GPIOC,GPIO_PIN_4) == 0)        //減1按鍵有效
            delay_ms(20);
                while (GPIO_ReadInputPin(GPIOC,GPIO_PIN_4) == 0)
                if (a > 1)
                 a =a-1;
void PWM(void)
pwm_duty=2000000/a/30;
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);//  有些硬件會自動八分頻 導致后面的計算出現錯誤
CLK_HSICmd(ENABLE);    //打開內部的時鐘函數
TIM2_DeInit(); //TIM2回復默認
GPIO_Init(GPIOD,GPIO_PIN_4,GPIO_MODE_OUT_PP_LOW_FAST);//設置 Timer2 D4口輸出PWM模式
TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,pwm_duty/2,TIM2_OCPOLARITY_HIGH);
TIM2_TimeBaseInit(TIM2_PRESCALER_8,pwm_duty);//16M晶振
TIM2_OC2PreloadConfig(ENABLE);
TIM2_Cmd(ENABLE);//啟用Timer2定時器
void main(void)
  PWM();
  KEY();
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
代碼如上,百思不得其解!求大佬幫忙看看
ID:69038 發表于 2024-2-20 12:02 | 只看該作者
流程不對,你按對鍵后a值沒有反饋到PWM控制中去,a值變了還要pwm_duty才行。
好比你要請客,飯菜在灶臺,老是不端上桌子,客人能吃到熱乎的嗎?
