查看: 2335|回復: 6
STC8G1K08-16pin單片機的串口2通信,始終沒有信號反應
ID:1110466 發表于 2024-1-31 17:10 | 顯示全部樓層 |閱讀模式
#include "STC8G.h"
#include <intrins.h>
#include <string.h>
sbit TURN_UP = P1^1;
sbit TURN_DOWN = P1^0;
sbit TURN_LEFT = P1^6;
sbit TURN_RIGHT = P1^7;
sbit Flag_UP = P3^1;   //上轉限位
sbit Flag_DOWN = P3^0;  //下轉限位
sbit Flag_LEFT = P3^3;  //左轉限位
sbit Flag_RIGHT = P3^4; //右轉限位
sbit led = P3^5;                //照明燈
sbit led_R = P5^5;      //測試
bit busy=0;
char wptr;
char rptr;
char buffer[16];
unsigned char k_recvie=0;//接受數據
unsigned int up=0,down=0,left=0,right=0;
void Delay1ms()        //@12MHz
    unsigned char i, j;
    _nop_();
    _nop_();
    i = 12;
    j = 168;
    do
        while (--j);
    } while (--i);
void Delay100ms()        //@12MHz
    unsigned char i, j;
    i = 195;
    j = 138;
    do
        while (--j);
    } while (--i);
//串口接收處理函數
void Uart2Isr() interrupt 8
    if (S2CON & 0x02)
        S2CON &= ~0x02;
        busy = 0;
    if (S2CON & 0x01)
                S2CON &= ~0x01;
        k_recvie= S2BUF;
                if(k_recvie==0xA0)
                            up=1;
                            down=0;
                            left=0;
                            right=0;
                if(k_recvie==0xA1)
                            down=1;
                            up=0;
                            left=0;
                            right=0;
                if(k_recvie==0xA3)
                            left=1;
                            up=0;
                            down=0;
                            right=0;
                if(k_recvie==0xA4)
                            right=1;
                            up=0;
                            down=0;
                            left=0;
                if(k_recvie==0xF2)
                            up=0;
                            down=0;
                            left=0;
                            right=0;
                            TURN_UP=0;
                            TURN_DOWN=0;
                            TURN_LEFT=0;
                            TURN_RIGHT=0;
void UartInit(void)        //9600bps@11.0592MHz
        S2CON = 0x50;        //8位數據,可變波特率
        AUXR |= 0x04;        //定時器時鐘1T模式
        T2L = 0xE0;            //設置定時初始值
        T2H = 0xFE;            //設置定時初始值
        AUXR |= 0x10;        //定時器2開始計時
        busy = 0;
void Uart2Send(char dat)
    while (busy);
    busy = 1;
    S2BUF = dat;
void Uart2SendStr(char *p)
    while (*p)
        Uart2Send(*p++);
    P0M0 = 0xff; P0M1 = 0x00;
    P3M0 = 0x20; P3M1 = 0x00;
        P5M0 = 0x00; P5M1 = 0x00;
        TURN_UP=0;
        TURN_DOWN=0;
        TURN_LEFT=0;
        TURN_RIGHT=0;
        UartInit();
        IE2 = 0x01;
    EA = 1;
        led=1;
        led_R=0;
        Delay100ms();
        Delay100ms();
    Uart2SendStr("Uart Test !\r\n");
        if(Flag_UP==1&&up==1)
                TURN_UP=1;
        if(Flag_DOWN==1&&down==1)
                TURN_DOWN=1;
        if(Flag_LEFT==1&&left==1)
                TURN_LEFT=1;
        if(Flag_RIGHT==1&&right==1)
                TURN_RIGHT=1;
        Uart2Send(0x51);
    }//while
ID:213173 發表于 2024-2-1 08:18 | 顯示全部樓層
首先你初始化端口模式就錯了。串口2在P1.6、P1.7,必須在準雙向模式下工作。另外串口中斷只管接收,數據解析處理放在主函數里運行。
ID:1110466 發表于 2024-2-1 09:42 | 顯示全部樓層
哪位高手勞煩看看問題在哪,實在看不出來呀
ID:1110466 發表于 2024-2-1 11:06 | 顯示全部樓層
wulin 發表于 2024-2-1 08:18
首先你初始化端口模式就錯了。串口2在P1.6、P1.7,必須在準雙向模式下工作。另外串口中斷只管接收,數據解 ...
STC8G1K08-16這個單片機的串口在P3.6和P3.7,已配置成準雙向口,可還是不起作用的
ID:213173 發表于 2024-2-1 11:13 | 顯示全部樓層
sjcfly 發表于 2024-2-1 09:42
STC官方有示例
ID:1110466 發表于 2024-2-1 11:37 | 顯示全部樓層
按這個改的,沒有反應,硬件上直接接了485模塊,再通過CH340G,接電腦端口。單獨兩個CH340中間接485模塊測試,通信正常。另一端直接接串口,沒有數據
ID:1110466 發表于 2024-2-1 11:55 | 顯示全部樓層
找到原因了,這個STC8G1K08有兩組串口2的引腳口,使用時得進行一個切換選擇
