查看: 1666|回復: 2
STM32單片機bootloader IAP升級例程
ID:1109580 發表于 2024-1-18 12:32 | 顯示全部樓層 |閱讀模式
基于STM32F103ZET6芯片,實際使用沒有問題
  1. /** @addtogroup IAP
  2.   * @{
  3.   */
  4. /* Includes ------------------------------------------------------------------*/
  5. #include "common.h"
  6. #include "bsp.h"
  7. #include "cortexm3_macro.h"
  8. /* Private typedef -----------------------------------------------------------*/
  9. /* Private define ------------------------------------------------------------*/
  10. /* Private macro -------------------------------------------------------------*/
  11. /* Private variables ---------------------------------------------------------*/
  12. /* Private function prototypes -----------------------------------------------*/
  13. /*******************************************************************************
  14. * Function Name  : main
  15. * Description    : Main program.
  16. * Input          : None
  17. * Output         : None
  18. * Return         : None
  19. *******************************************************************************/
  20. int main(void)
  21. {
  22.     u8 flg = 0;
  23. #ifdef DEBUG
  24.     debug();
  25. #endif
  26.
  27.     BspInit();
  28.     CommonInit();
  29.     while (1)
  30.     {
  31.         CommonExec();
  32.
  33.         if (IS_TIMEOUT_1MS(eTim1, 1000))
  34.         {
  35.             flg? LedOn(LED_5) : LedOff(LED_5);
  36.             flg = !flg;
  37.         }
  38.     }
  39. }
  40. #ifdef  DEBUG
  41. /*******************************************************************************
  42. * Function Name  : assert_failed
  43. * Description    : Reports the name of the source file and the source line number
  44. *                  where the assert_param error has occurred.
  45. * Input          : - file: pointer to the source file name
  46. *                  - line: assert_param error line source number
  47. * Output         : None
  48. * Return         : None
  49. *******************************************************************************/
  50. void assert_failed(u8* file, u32 line)
  51. {
  52.   /* User can add his own implementation to report the file name and line number,
  53.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  54.   /* Infinite loop */
  55.   while (1)
  56.   {
  57.   }
  58. }
  59. #endif
原理圖: 無
仿真: 無
代碼(僅供參考,有錯誤請指出): bootloader.7z (198.05 KB, 下載次數: 28)
ID:164385 發表于 2024-1-25 23:11 | 顯示全部樓層
很好的介紹,謝謝了
ID:18591 發表于 2024-2-2 09:50 | 顯示全部樓層
非常好,謝謝樓主
