查看: 1468|回復: 6
請問單片機P1_1,P1_2,P1_3仿真無法按下的原因是什么?
ID:1104657 發表于 2024-1-12 17:56 | 顯示全部樓層 |閱讀模式
  1.     #include "main.h"
  2.     #include "lcd1602.h"
  3.     #include "key.h"
  4.     #include "motor_zhiliu.h"
  5.
  6.     uchar key_num = 0;
  7.     uchar flag_display = 0;
  8.     uint time_num = 0;
  9.     char display_buf[16];
  10.     bit flag_mode = 0;
  11.     extern bit flag_direction;
  12.     extern uchar pwm_num;
  13.     uchar flag_speed = 0;
  14.
  15.     void Delay_function(uint x);
  16.     void Key_function(void);
  17.     void Display_function(void);
  18.     void Manage_function(void);
  19.     uchar Simulation_Keyboard_Scan(void);
  20.
  21.     void main()
  22.     {
  23.             Lcd1602_Init();
  24.             Delay_function(50);
  25.             lcd1602_clean();
  26.             Delay_function(50);
  27.             Timer0_Init();
  28.             Delay_function(50);
  29.
  30.             while(1)
  31.             {
  32.                     Key_function();
  33.                     Display_function();
  34.                     Manage_function();
  35.                     Delay_function(10);
  36.                     time_num++;
  37.                     if(time_num == 5000)
  38.                     {
  39.                             time_num = 0;
  40.                     }
  41.             }
  42.     }
  43.
  44.     void Delay_function(uint x)
  45.     {
  46.             uint m,n;
  47.             for(m=x;m>0;m--)
  48.             for(n=110;n>0;n--);
  49.     }
  50.
  51.     uchar Simulation_Keyboard_Scan(void)
  52.     {
  53.         uchar key_value = 0;
  54.
  55.
  56.         key_value = ~P1 & 0x0F;
  57.
  58.
  59.
  60.
  61.         return key_value;
  62.     }
  63.     void Key_function(void)
  64.     {
  65.         #ifdef SIMULATION
  66.             key_num = Simulation_Keyboard_Scan();
  67.         #else
  68.             key_num = Chiclet_Keyboard_Scan(0);
  69.         #endif
  70.         if(key_num != 0)
  71.         {
  72.             switch(key_num)
  73.             {
  74.                 case 1:
  75.                     flag_direction = ~flag_direction;
  76.                     break;
  77.                 case 2:
  78.                     if(flag_speed < 3)
  79.                         flag_speed++;
  80.                     flag_mode = 1;
  81.                     break;
  82.                 case 3:
  83.                     if(flag_speed > 0)
  84.                         flag_speed--;
  85.                     flag_mode = 1;
  86.                     break;
  87.
  88.                 case 4:
  89.                     flag_speed = 0;
  90.                     flag_mode = 1;
  91.                     break;
  92.                 default:
  93.                     break;
  94.             }
  95.         }
  96.     }
  97.
  98.     void Display_function(void)
  99.     {
  100.             if(flag_direction == 0)
  101.                     lcd1602_display_str(2, 0, "D:Right");
  102.             else
  103.                     lcd1602_display_str(2, 0, "D:Lift ");
  104.
  105.             switch(flag_speed)
  106.             {
  107.                     case 0:
  108.                             lcd1602_display_str(2, 9, "S:Stop");
  109.                     break;
  110.
  111.                     case 1:
  112.                             lcd1602_display_str(2, 9, "S:Low ");
  113.                     break;
  114.
  115.                     case 2:
  116.                             lcd1602_display_str(2, 9, "S:Mid ");
  117.                     break;
  118.
  119.                     case 3:
  120.                             lcd1602_display_str(2, 9, "S:High");
  121.                     break;
  122.
  123.                     default:
  124.                     break;
  125.             }
  126.     }
  127.
  128.     void Manage_function(void)
  129.     {
  130.         if(flag_mode == 0)
  131.         {
  132.             flag_speed = 1;
  133.         }
  134.         else
  135.         {
  136.             switch(key_num)
  137.             {
  138.                 case 1:
  139.                     flag_direction = ~flag_direction;
  140.                     break;
  141.                 case 2:
  142.                     if(flag_speed < 3)
  143.                         flag_speed++;
  144.                     flag_mode = 1;
  145.                     break;
  146.                 case 3:
  147.                     if(flag_speed > 0)
  148.                         flag_speed--;
  149.                     flag_mode = 1;
  150.                     break;
  151.
  152.                 case 4:
  153.                     flag_speed = 0;
  154.                     flag_mode = 1;
  155.                     break;
  156.                 default:
  157.                     break;
  158.             }
  159.         }
  160.     }
ID:1104657 發表于 2024-1-12 17:57 | 顯示全部樓層
不懂怎么上傳代碼就亂碼了
ID:69038 發表于 2024-1-13 08:59 | 顯示全部樓層
你沒按到開關的點上當然按對不下了。
ID:44037 發表于 2024-1-13 12:07 | 顯示全部樓層
單片機P1_1,P1_2,P1_3仿真無法按下的原因是 按鍵處有"<TEXT>"  將其移開就正常了
ID:1104657 發表于 2024-1-13 13:40 | 顯示全部樓層
zhuls 發表于 2024-1-13 08:59
你沒按到開關的點上當然按對不下了。
不是這個原因,就算對準了開關,仍然無法按下P1_1,P1_2,P1_3,并且會顯示“測量時必須停止仿真”字樣
ID:1104657 發表于 2024-1-13 16:21 | 顯示全部樓層
我知道原因了!!!是仿真的四個按鍵靠太近了!!!!!
ID:1104657 發表于 2024-1-14 14:28 | 顯示全部樓層
by64214 發表于 2024-1-13 12:07
單片機P1_1,P1_2,P1_3仿真無法按下的原因是 按鍵處有""  將其移開就正常了
原來如此哈哈哈哈哈哈,好咧謝謝大佬!!!
