查看: 1185|回復: 0
PWM脈沖寬度調制與智能小車PWM直流電機調速程序2
ID:1108645 發表于 2024-1-9 15:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit pwm=P1^0;
uint cycle,high,low;
void delay(uint t)
        while(t--);
        cycle=800;
                for(high=1;high<=cycle;high++)
                        pwm=1;
                        delay(high);
                        pwm=0;
                        low=cycle-high;
                        delay(low);
                high=1;
                delay(60000);
