查看: 2242|回復(fù): 14
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
ID:1108632 發(fā)表于 2024-1-9 14:56 | 顯示全部樓層 |閱讀模式
大佬們 這個問題咋解決哦
完整代碼如下
#include<reg52.h>
#include<intrins.h>
        sbit Key1=P2^0;
        sbit Key2=P2^1;
        sbit Key3=P2^2;
        sbit Key4=P2^3;
        sbit LED=P2^6;
        sbit SPK=P2^7;
        void delay(uint ms);
        uchar count,shi,ge,countdown,state;
        uchar Buf[2]={0};
        uchar code DispBitCode[] = {0xfe,0xfd};
        uchar code DispCode[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xFF,0xBF} ;
        uchar Count=0;
        uint time=0;
        uint show_time=0;
        bit start = 0;
        bit alarm = 0;
void Delay(uint x)
                while(--x);
void DisPlay (uchar *DispBuf)
uchar k;
for(k=0; k<2; k++)
P1=DispBitCode[k];
P0=DispCode[DispBuf[k]];
Delay (500);
void KeyScan (void)
        if(Key1==0)
                        delay(15);
                TR0=0;
                state=1;
        if(state==1)
                delay(15);
        if(Key2==0)
                                delay(15);
                        if(Key2==0)
                                                if(start==0)
        if(time<59)
        time++;
        time=0;
        show_time=time;
        while(!Key2);
                                if(Key3==0)
                                delay(15);
                        if(Key3==0)
                                                if(start==0)
        if(time>0)
        time--;
        time=59;
        show_time=time;
        while(!Key3);
                if(Key4==0)
                        delay(15);
                        TR0=1;
                        state=0;
void TimerInit (void)
TMOD=0x11;
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
TH1=0xfe;
TL1=0x00;
TR1=0;
ET1=1;
TR0=0;
ET0=1;
EA=1;
void openAlarm (void)
TR1=1;
LED=0;
void closeAlarm(void)
TR1 = 0;
LED=1;
void Time_Init()
LED=1;
time=10;
show_time =time;
        Buf[0]= show_time%10;
        Buf[1]= show_time/10;
        DisPlay(Buf);
        KeyScan();
        if(1 == alarm)
                TR0 = 0;
        openAlarm();
         closeAlarm();
return;
void Timer0(void) interrupt 1
TH0=(5535 - 50000)/256;
TL0=(65535 - 50000)%256;
count++;
if(20==Count)
        Count = 0;
        show_time--;
        if(0==show_time)
         alarm=1;
void Timerl(void) interrupt 3
TH1=0xfd;
TL1=0x00;
SPK=~SPK;
ID:384109 發(fā)表于 2024-1-9 15:14 | 顯示全部樓層
只是一個函數(shù)未調(diào)用的警告而已,不影響的
ID:1108632 發(fā)表于 2024-1-9 15:19 | 顯示全部樓層
人中狼 發(fā)表于 2024-1-9 15:14
您好 Target not created. 是這個問題 就是我要構(gòu)建Hex格式的文件構(gòu)建不了 可以幫忙看一下嗎
ID:342822 發(fā)表于 2024-1-9 15:42 | 顯示全部樓層
void main ()??????
ID:342822 發(fā)表于 2024-1-9 16:00 | 顯示全部樓層
程序從哪個函數(shù)執(zhí)行??
ID:384109 發(fā)表于 2024-1-9 16:09 | 顯示全部樓層
把編譯結(jié)果信息都貼出來吧
無效樓層,該帖已經(jīng)被刪除
9#
無效樓層,該帖已經(jīng)被刪除
ID:1108632 發(fā)表于 2024-1-9 16:37 | 顯示全部樓層
人中狼 發(fā)表于 2024-1-9 16:09
把編譯結(jié)果信息都貼出來吧
Build target 'Target 1'
linking...
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
    SYMBOL:  COUNT
    MODULE:  .\Objects\main.obj (MAIN)
    SEGMENT: ?PR?TIMERINIT?MAIN
    SEGMENT: ?PR?TIME_INIT?MAIN
    SEGMENT: ?C_INITSEG
Program Size: data=8.2 xdata=15 code=631
Target not created.
Build Time Elapsed:  00:00:00
ID:883242 發(fā)表于 2024-1-9 16:51 | 顯示全部樓層
void Time_Init()
這個函數(shù)你寫了完整的代碼。
然而沒有任何地方引用過這個函數(shù)。
所以編譯器不知所措,把這個函數(shù)的代碼扔掉了,順便丟給你一個警告。
ID:1088185 發(fā)表于 2024-1-9 18:48 | 顯示全部樓層
    SYMBOL:  COUNT
這一條是你重復(fù)定義 COUNT
其它的沒問題, 因為你沒調(diào)用,所以編譯器告訴你這些函數(shù)不會編譯
ID:883242 發(fā)表于 2024-1-9 23:07 | 顯示全部樓層
2384298858 發(fā)表于 2024-1-9 16:37
linking...
所以你不要貼warning,要貼error才是問題所在。
你在你的文件里面搜“count”就知道問題在哪里了。
ID:161164 發(fā)表于 2024-1-9 23:09 | 顯示全部樓層
ID:1057978 發(fā)表于 2024-1-10 09:15 | 顯示全部樓層
不用看Warning,要看error,
提示你變量重復(fù)定義了,你讀讀編譯結(jié)果,不認識的單詞百度一下
ID:277550 發(fā)表于 2024-1-10 10:06 | 顯示全部樓層
2384298858 發(fā)表于 2024-1-9 15:19
在項目屬性中,選中創(chuàng)建HEX的選項
ID:1064915 發(fā)表于 2024-1-10 10:23 | 顯示全部樓層
沒有看到main
