查看: 1521|回復(fù): 2
做的單片機(jī)調(diào)速呼吸燈效果,調(diào)的時(shí)候速度不會(huì)變化,斷電重新上電才能看到變化
ID:879080 發(fā)表于 2023-12-18 19:13 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
調(diào)速時(shí)看不到快慢變化,重新上電才能看到。怎樣改才能實(shí)現(xiàn)實(shí)時(shí)變化?
#include <reg51.h>
#include "intrins.h"
uint zkb,pwm,time;
//bit max=0;
uchar RunMode;
sfr     P1M1    =   0x91;
sfr     P1M0    =   0x92;
sfr     P3M1    =   0xb1;
sfr     P3M0    =   0xb2;
sfr     WDT_CONTR   =   0xc1;
sfr IE2       = 0xaf;               //中斷使能寄存器2
sfr AUXR      = 0x8e;               //輔助寄存器
sfr T2H       = 0xD6;               //定時(shí)器2高8位
sfr T2L       = 0xD7;               //定時(shí)器2低8位
sfr     IAP_DATA    =   0xC2;
sfr     IAP_ADDRH   =   0xC3;
sfr     IAP_ADDRL   =   0xC4;
sfr     IAP_CMD     =   0xC5;
sfr     IAP_TRIG    =   0xC6;
sfr     IAP_CONTR   =   0xC7;
sfr     IAP_TPS     =   0xF5;
unsigned char RunMode;
void  cc(uint addr);
void  xcx(uint addr,uchar dat);
uchar dcx(uint addr);
void  Q0();
函數(shù):擦除某一扇區(qū)(每個(gè)扇區(qū)512字節(jié))
入口:addr = 某一扇區(qū)首地址
void cc(uint addr)// 0x83(晶振<5M)   0x82(晶振<10M)   0x81(晶振<20M)   0x80(晶振<40M)
    IAP_CONTR = 0x81;
    IAP_TPS = 12;
    IAP_CMD   = 3;
    IAP_ADDRL = addr;
    IAP_ADDRH = addr>>8;
        EA =0;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    _nop_();
    Q0();
函數(shù):寫一字節(jié)
入口:addr = 扇區(qū)單元地址 , dat = 待寫入數(shù)據(jù)
    IAP_CONTR = 0x81;
    IAP_TPS = 12;
    IAP_CMD   = 2;
    IAP_ADDRL = addr;
    IAP_DATA  = dat;
    EA = 0;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    _nop_();
    Q0();         // 關(guān)閉ISP/IAP
函數(shù):讀一字節(jié)
出口:dat  = 讀出的數(shù)據(jù)
    uchar dat;
        IAP_CONTR = 0x81;
        IAP_TPS = 12;
    IAP_CMD   = 1;         // 用戶可以對(duì)"Data Flash/EEPROM區(qū)"進(jìn)行字節(jié)讀
    IAP_ADDRL = addr;
    EA = 0;
    IAP_TRIG = 0x5a;
    IAP_TRIG = 0xa5;
    _nop_();
    dat = IAP_DATA;         // 取出數(shù)據(jù)
        return dat;
函數(shù):關(guān)閉ISP/IAP操作
void Q0()
    IAP_CONTR = 0;            // 關(guān)閉IAP功能
    IAP_CMD   = 0;            // 待機(jī)模式,無(wú)ISP操作
    IAP_TRIG  = 0;
        IAP_ADDRH=0x80;
        IAP_ADDRL=0;
        EA =1;            // 關(guān)閉IAP功能, 清與ISP有關(guān)的特殊功能寄存器
//**********************************System Fuction*************************************************
void Delay1ms( uint count)
            uint i,j;
        for(i=0;i<count;i++)
        for(j=0;j<120;j++);
uchar GetKey(void)
        uchar KeyTemp,CheckValue,Key = 0x00;
        CheckValue = P1&0x43;
        if(CheckValue==0x43)
                return 0x00;
        Delay1ms(10);
        KeyTemp = P1&0x43;
        if(KeyTemp==CheckValue)
                return 0x00;
        if(!(CheckValue&0x01))
                Key|=0x01;
        if(!(CheckValue&0x02))
                Key|=0x02;
        if(!(CheckValue&0x40))
                Key|=0x40;
        return Key;
uint TimerCount ,SystemSpeed,SystemSpeedIndex,outtime;
void InitialTimer0(void) //100us@11.0592MHZ
                AUXR &= 0x3F;                        //定時(shí)器時(shí)鐘12T模式
                 TMOD = 0x00;
         TL0 = (65536-1000)%256;                                //設(shè)置定時(shí)初始值
     TH0 = (65536-1000)/256;                                //設(shè)置定時(shí)初始值
     TL1 = (65536-time)%256;                                //設(shè)置定時(shí)初始值
     TH1 = (65536-time)/256;
        TR0 = 1;
    TR1=1;
        ET0=1;
        ET1=1;
        EA=1;
uint code SpeedCode[]={100,150,200,250,300,400,500,600,
                                           700,1000};
uint code pwmtime[]={10,15,20,25,30,35,40,45,50,55};
void pwmspeed(uchar speed1)
        time=pwmtime[speed1];
void SetSpeed( uchar Speed)
        SystemSpeed =SpeedCode[Speed];
void LEDShow( uint LEDStatus)
        P3 = (LEDStatus&0xFF);
void InitialCPU(void)
                        TimerCount = 0;
                 RunMode = dcx(0x0000);
        SystemSpeedIndex =dcx(0x0200);
                 //SystemSpeedIndex = 0;
                 if(SystemSpeedIndex > 10)
                  SystemSpeedIndex =1;
        P1 = 0xFF;
                P3 = 0xFF;
        Delay1ms(500);
        P1 = 0xFF;
        P3 = 0xFF;
        SetSpeed(SystemSpeedIndex);
                pwmspeed(SystemSpeedIndex);
unsigned int LEDIndex = 0;
bit LEDDirection = 1,LEDFlag = 1;
//Mode 0
void Mode_0(void)
         if(LEDDirection)
                LEDShow(~(0x0F<<LEDIndex));
                LEDShow(~(0xF0>>LEDIndex));
        if(LEDIndex==7)
                LEDDirection = !LEDDirection;
           LEDIndex = (LEDIndex+4)%8;
void Mode_1(void)
        LEDShow(~(0x01<<LEDIndex));
        LEDIndex = (LEDIndex+1)%3;
void Mode_2(void)
        LEDShow(0xff<<LEDIndex);
        LEDIndex = (LEDIndex+1)%4;
void Mode_3(void)
                if(pwm>zkb)
           LEDShow(LEDIndex=0xff);
                LEDShow(LEDIndex=0x00);
void TimerEventRun(void)
       if(RunMode==0x00)
                Mode_0();
         else if(RunMode ==0x01)
                Mode_1();
                else if(RunMode ==0x02)
                Mode_2();
void Timer0(void) interrupt 1 using 1
                if(++TimerCount>=SystemSpeed)
                           TimerCount = 0;
             TimerEventRun();
void Timer1(void) interrupt 3 using 1
                static uchar max=0;
                pwm++;
        if(pwm>200)
pwm=0;             //周期歸零
if(max==0){zkb++;}     //MAX占空比漸加漸減標(biāo)志位 默認(rèn)max為0.每一周期占空比漸加
if(max==1){zkb--;}      //MAX占空比漸加漸減標(biāo)志位 如果max為1.每一周期占空比漸減
if(zkb==200){max=1;}  //如果占空比的值為100      標(biāo)志位MAX置為1.漸減
if(zkb==0){max=0;}     //如果占空比的值為0         標(biāo)志位MAX置為0.漸加
    if(RunMode ==0x03)
                Mode_3();
unsigned char MusicIndex = 0;
void KeyDispose(unsigned char Key)
        if(Key&0x01)
                LEDDirection = 1;
                LEDIndex = 0;
                LEDFlag = 1;
                RunMode = (RunMode+1)%4;
                                /*if( RunMode == 4);
                                 cc(0x0000);
                                    xcx(0x0000, RunMode);
        if(Key&0x02)
                if(SystemSpeedIndex>0)
                        --SystemSpeedIndex;
                       cc(0x0200);
                                     xcx(0x0200,SystemSpeedIndex);
        if(Key&0x40)
                if(SystemSpeedIndex<9)
                       ++SystemSpeedIndex;
                                        cc(0x0200);
main()
         unsigned char Key;
    P1M0 = 0x00;
    P1M1 = 0x00;
    P3M0 = 0x00;
    P3M1 = 0x00;
        // WDT_CONTR = 0x27;
        InitialCPU();
        InitialTimer0();
                                 //WDT_CONTR = 0x37;
                Key = GetKey();
                if(Key!=0x00)
                        KeyDispose(Key);
ID:161164 發(fā)表于 2023-12-19 08:59 | 只看該作者
ID:879080 發(fā)表于 2023-12-19 20:38 | 只看該作者
非常感謝您的幫助!
