查看: 1001|回復: 2
請教一下,為什么lcd12864打點的時候會出現別的點
ID:1098678 發表于 2023-12-15 17:20 | 顯示全部樓層 |閱讀模式
這是lcd的一些函數
void delay(unsigned int xms)  //延時//
        unsigned char i,j;
        for(j = 0; j < xms; j++)
                for(i = 0;i < 110;i++);
bit LcdBusyCheck(){
          bit result;
          LCD12864_RS = 0;
          LCD12864_RW = 1;
          LCD12864_EN = 1;
                  delay(1);
          result = (bit)(DATA_PORT&0x80);
          LCD12864_EN = 0;
          return result;
void WriteCmdToLCD(unsigned char cmd)
          while(LcdBusyCheck());
//          delay(10);
          LCD12864_RS = 0;
          LCD12864_RW = 0;
          LCD12864_EN = 1;
                  delay(1);
          DATA_PORT = cmd;
//          delay(5);
          LCD12864_EN = 0;
//          delay(5);
//         LCD12864_EN = 1;
void WriteDatToLcd(unsigned char dat)
//          delay(10);
          LCD12864_RS = 1;
          LCD12864_RW = 0;
          LCD12864_EN = 1;
                  delay(1);
          DATA_PORT = dat;
//         delay(5);
          LCD12864_EN = 0;
//          delay(5);
//          LCD12864_EN = 1;
void WriteStrToLcd(unsigned char *str)
        while(*str != '\0')
            WriteDatToLcd(*str++);
            delay(5);
unsigned char ReadLcd(void)
       unsigned char dat;
       //DATA_PORT=0xff;
       LCD12864_RS=1;
           LCD12864_RW=1;
       LCD12864_EN=0;
           LCD12864_EN=1;
       dat=DATA_PORT;
       LCD12864_EN=0;
       return dat;
void DrawDots(unsigned char i,unsigned char j)//打點函數   //x,y為128*64 點陣的坐標
      unsigned char row,xlabel,xlabel_bit,x,y;
      unsigned char Read_H=0,Read_L=0;
          x = i+6;
          y = 64-j-5;
      WriteCmdToLCD(0x34);       //擴充指令
      WriteCmdToLCD(0x36);       //繪圖指令
      xlabel=x>>4;            //確定水平坐標地址
      xlabel_bit=x & 0x0F; // 細分水平坐標中的第幾位
      if(y<32) row=y;
      else {   row=y-32; xlabel+=8;      }
      WriteCmdToLCD(row+0x80);
      WriteCmdToLCD(xlabel+0x80);
      ReadLcd();
      Read_H=ReadLcd();
      Read_L=ReadLcd();
      WriteCmdToLCD(xlabel+0x80);   //水平坐標地址+基址=顯示的水平地址
      if(xlabel_bit<8)
       // Read_H &=(~(0x01<<(7-xlabel_bit))); //變暗
          Read_H |=(0x01<<(7-xlabel_bit)); //變亮
                // Read_H = Read_H;
          WriteDatToLcd(Read_H);
          WriteDatToLcd(Read_L);
       //Read_L &=(~(0x01<<(15-xlabel_bit))); //變暗
          Read_L |=(0x01<<(15-xlabel_bit)); //變亮
        //        Read_L=Read_L;
//         WriteDatToLcd(Read_H);
//     WriteDatToLcd(Read_L);
     WriteCmdToLCD(0x30);//恢復正常模式
void Clear_GDRAM()                //清除GDRAM
        unsigned char x,y;
        for(y=0;y<64;y++)
                for(x=0;x<16;x++)
                        WriteCmdToLCD(y+0x80);        //先送垂直地址
                        WriteCmdToLCD(x+0x80);        //后送水平地址
                        WriteCmdToLCD(0x30);        //基本指令
                        WriteDatToLcd(0x00);                //寫入數據0
這是主函數里面的循環打點
                          for(i=5;i<50;i++)
                            DrawDots(i,i);
                                delay(100);
ID:390438 發表于 2023-12-16 08:21 | 顯示全部樓層
可能延時不夠,或者打點過程中 被中斷打斷了
ID:1098678 發表于 2023-12-18 16:59 | 顯示全部樓層
檢查了一下發現是讀取數據函數的問題unsigned char ReadLcd()
       unsigned char dat = 0;
      DATA_PORT=0xff;
           LCD12864_EN=0;
       LCD12864_RS=1;
           LCD12864_RW=1;
           delay(1);
           LCD12864_EN=1;
           delay(1);
       dat=DATA_PORT;
           delay(1);
       LCD12864_EN=0;
       return dat;
但是不知道怎么糾正
