- #include <REGX52.H>
- #include "Delay.h"
- #include "Timer0.h"
- //蜂鳴器端口定義
- sbit Buzzer=P1^5;
- //播放速度,值為四分音符的時長(ms)
- #define SPEED 500
- //音符與索引對應表,P:休止符,L:低音,M:中音,H:高音,下劃線:升半音符號#
- #define P 0
- #define L1 1
- #define L1_ 2
- #define L2 3
- #define L2_ 4
- #define L3 5
- #define L4 6
- #define L4_ 7
- #define L5 8
- #define L5_ 9
- #define L6 10
- #define L6_ 11
- #define L7 12
- #define M1 13
- #define M1_ 14
- #define M2 15
- #define M2_ 16
- #define M3 17
- #define M4 18
- #define M4_ 19
- #define M5 20
- #define M5_ 21
- #define M6 22
- #define M6_ 23
- #define M7 24
- #define H1 25
- #define H1_ 26
- #define H2 27
- #define H2_ 28
- #define H3 29
- #define H4 30
- #define H4_ 31
- #define H5 32
- #define H5_ 33
- #define H6 34
- #define H6_ 35
- #define H7 36
- //索引與頻率對照表
- unsigned int FreqTable[]={
- 0,
- 63628,63731,63835,63928,64021,64103,64185,64260,64331,64400,64463,64528,
- 64580,64633,64684,64732,64777,64820,64860,64898,64934,64968,65000,65030,
- 65058,65085,65110,65134,65157,65178,65198,65217,65235,65252,65268,65283,
- //樂譜
- unsigned char code Music[]={
- //音符,時值,
- //1
- P, 4,
- P, 4,
- P, 4,
- M6, 2,
- M7, 2,
- H1, 4+2,
- M7, 2,
- H1, 4,
- H3, 4,
- M7, 4+4+4,
- M3, 2,
- M3, 2,
- //2
- M6, 4+2,
- M5, 2,
- M6, 4,
- H1, 4,
- M5, 4+4+4,
- M3, 4,
- M4, 4+2,
- M3, 2,
- M4, 4,
- H1, 4,
- //3
- M3, 4+4,
- P, 2,
- H1, 2,
- H1, 2,
- H1, 2,
- M7, 4+2,
- M4_,2,
- M4_,4,
- M7, 4,
- M7, 8,
- P, 4,
- M6, 2,
- M7, 2,
- //4
- H1, 4+2,
- M7, 2,
- H1, 4,
- H3, 4,
- M7, 4+4+4,
- M3, 2,
- M3, 2,
- M6, 4+2,
- M5, 2,
- M6, 4,
- H1, 4,
- //5
- M5, 4+4+4,
- M2, 2,
- M3, 2,
- M4, 4,
- H1, 2,
- M7, 2+2,
- H1, 2+4,
- H2, 2,
- H2, 2,
- H3, 2,
- H1, 2+4+4,
- //6
- H1, 2,
- M7, 2,
- M6, 2,
- M6, 2,
- M7, 4,
- M5_,4,
- M6, 4+4+4,
- H1, 2,
- H2, 2,
- H3, 4+2,
- H2, 2,
- H3, 4,
- H5, 4,
- //7
- H2, 4+4+4,
- M5, 2,
- M5, 2,
- H1, 4+2,
- M7, 2,
- H1, 4,
- H3, 4,
- H3, 4+4+4+4,
- //8
- M6, 2,
- M7, 2,
- H1, 4,
- M7, 4,
- H2, 2,
- H2, 2,
- H1, 4+2,
- M5, 2+4+4,
- H4, 4,
- H3, 4,
- H3, 4,
- H1, 4,
- //9
- H3, 4+4+4,
- H3, 4,
- H6, 4+4,
- H5, 4,
- H5, 4,
- H3, 2,
- H2, 2,
- H1, 4+4,
- P, 2,
- H1, 2,
- //10
- H2, 4,
- H1, 2,
- H2, 2,
- H2, 4,
- H5, 4,
- H3, 4+4+4,
- H3, 4,
- H6, 4+4,
- H5, 4+4,
- //11
- H3, 2,
- H2, 2,
- H1, 4+4,
- P, 2,
- H1, 2,
- H2, 4,
- H1, 2,
- H2, 2+4,
- M7, 4,
- M6, 4+4+4,
- P, 4,
- 0xFF //終止標志
- unsigned char FreqSelect,MusicSelect;
- void main()
- Timer0Init();
- while(1)
- if(Music[MusicSelect]!=0xFF) //如果不是停止標志位
- FreqSelect=Music[MusicSelect]; //選擇音符對應的頻率
- MusicSelect++;
- Delay(SPEED/4*Music[MusicSelect]); //選擇音符對應的時值
- MusicSelect++;
- TR0=0;
- Delay(5); //音符間短暫停頓
- TR0=1;
- else //如果是停止標志位
- TR0=0;
- while(1);
- void Timer0_Routine() interrupt 1
- if(FreqTable[FreqSelect]) //如果不是休止符
- /*取對應頻率值的重裝載值到定時器*/
- TL0 = FreqTable[FreqSelect]%256; //設置定時初值
- TH0 = FreqTable[FreqSelect]/256; //設置定時初值
- Buzzer=!Buzzer; //翻轉蜂鳴器IO口
原理圖: 無
仿真: 無
代碼:
11-2 蜂鳴器播放音樂.zip
(35.75 KB, 下載次數: 14)
2023-12-5 18:40 上傳
下載積分: 黑幣 -5
