查看: 1944|回復: 0
單片機數(shù)碼管動態(tài)顯示生日代碼
ID:1102558 發(fā)表于 2023-12-5 18:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <REGX51.H>
#define SEG P0
sbit LEDA=P2^2;
sbit LEDB=P2^3;
sbit LEDC=P2^4;
uchar SMGduan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint ms);
void display(uchar Location,Number);
        TMOD=0x01;
                display(1,2);    //第一個數(shù)碼管顯示2
                display(2,0);
                display(3,0);
                display(4,5);
                display(5,0);
                display(6,1);
                display(7,0);
                display(8,4);
void delay(uint ms)
        uint n;
        for(n=0;n<ms;n++)
                TH0=(65536-1000)/256;                 //1ms
            TL0=(65536-1000)%256;
                TR0=1;
                while(!TF0);
                TF0=0;
                switch(Location)
                        case(1):LEDA=1;LEDB=1;LEDC=1;break;  //LED8第1個數(shù)碼管顯示2 C>B>A 000  取反
                        case(2):LEDA=0;LEDB=1;LEDC=1;break;  //LED7第2個數(shù)碼管顯示0 C>B>A 001
                        case(3):LEDA=1;LEDB=0;LEDC=1;break;  //LED6第3個數(shù)碼管顯示0 C>B>A 010
                        case(4):LEDA=0;LEDB=0;LEDC=1;break;  //LED5第4個數(shù)碼管顯示5 C>B>A 011
                        case(5):LEDA=1;LEDB=1;LEDC=0;break;  //LED4第5個數(shù)碼管顯示0 C>B>A 100
                        case(6):LEDA=0;LEDB=1;LEDC=0;break;  //LED3第6個數(shù)碼管顯示1 C>B>A 101
                        case(7):LEDA=1;LEDB=0;LEDC=0;break;  //LED2第7個數(shù)碼管顯示0 C>B>A 110
                        case(8):LEDA=0;LEDB=0;LEDC=0;break; //LED1第8個數(shù)碼管顯示4 C>B>A 111
        SEG=SMGduan[Number];    //20050104
        delay(1);
        SEG=0x00;   //數(shù)碼管消隱
