只需一步,快速開(kāi)始
查看: 2525|回復(fù): 7
LCD1602顯示,在實(shí)驗(yàn)室使用單片機(jī)板成功 在仿真上無(wú)法顯示
ID:1096616 發(fā)表于 2023-11-17 09:16 | 顯示全部樓層 |閱讀模式
這個(gè)需要到LCD顯示,但是我在單片機(jī)板上顯示成功,但是在仿真上無(wú)法顯示,電路連接應(yīng)該沒(méi)有錯(cuò)
#include <reg52.h>
#define uchar  unsigned   char
#define uint  unsigned         int
#define out P2
sbit LED =P1^4;
sbit key1=P3^2;
sbit key2=P3^3;
sbit key3=P3^4;
sbit key4=P3^5;
sbit lcdrs=P0^5;
sbit lcdrw=P0^6;
sbit lcden=P0^7;
void check_busy();
void write_cmd(uchar cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void T0_init();//T0初始化
void display(uchar date);
void keyscan();
void delay(uint z);
uchar sec=0,count=0,flag=0,keyflag=0;
{  T0_init();
  lcd_init();
   write_cmd(0x82);
   write_str("sec:");
  {         keyscan();
  switch(keyflag)
  {  case 1:TR0=1;LED=0;break;
     case 2:TR0=0;LED=1;break;
    display(sec);
void T0_init()
{          TMOD=0X01;
          TH0=(65536-50000)/256;
          TL0=(65536-50000)%256;
          ET0=1;
          EA=1;
void lcd_init()
{ write_cmd(0x38);
   write_cmd(0x0c);
   write_cmd(0x06);
   write_cmd(0x01);
   delay(1);
{          check_busy();
          lcdrs=0;
          lcdrw=0;
          lcden=0;
          out=cmd;
          lcden=1;
          delay(1);
          lcden=0;
          delay(1);
void check_busy()
{  uchar dt;
   do
   {dt=0xff;
    lcdrs=0;
        lcdrw=1;
        lcden=0;
        lcden=1;
        dt=out;
   }while(dt&0x80);
   lcden=0;
{         lcdrs=1;
         lcdrw=0;
         lcden=0;
         out=dat;
         lcden=1;
         delay(1);
         lcden=0;
         delay(1);
void delay(uint z)
{ uint i,j;
  for(j=z;j>0;j--)
   for(i=110;i>0;i--);
{  while(*str!='\0')
           write_data(*str++);
           delay(5);
void T0_it()interrupt 1
         count++;
         if(count>=20)
         {   count=0;
             sec++;
         if(sec>=60)
         {sec=0;flag=1;  }
{        write_cmd(0x88);
    write_data(date/10+0x30);
        write_cmd(0x89);
        write_data(date%10+0x30);
void keyscan()
{         key1=1;
    if(key1==0)
        {        delay(10);
           if(key1==0)
           {   while(!key1);
               keyflag=1;
        key2=1;
    if(key2==0)
        {        delay(10);
           if(key2==0)
           {   while(!key2);
               keyflag=2;
        if(key3==0)
        {sec++;
         if(sec==60)sec=60;}
        if(key4==0)
        {sec--;
         if(sec<=0)sec=0;}
ID:94031 發(fā)表于 2023-11-17 10:58 | 顯示全部樓層
LCD有多種驅(qū)動(dòng),實(shí)體顯示成功仿真不成功很正常。
ID:180919 發(fā)表于 2023-11-17 12:04 | 顯示全部樓層
仿真正在的,檢查下1602的連線
ID:180919 發(fā)表于 2023-11-17 13:39 | 顯示全部樓層
仿真電路MCU的P2口與P1口的網(wǎng)絡(luò)重復(fù)了
ID:213173 發(fā)表于 2023-11-17 15:06 | 顯示全部樓層
除了地板指出的P2口與P1口的網(wǎng)絡(luò)重復(fù)了,另外P0.5、P0.6、P0.7還要外接上拉電阻。 無(wú)標(biāo)題.jpg
ID:1096616 發(fā)表于 2023-11-17 22:30 | 顯示全部樓層
wulin 發(fā)表于 2023-11-17 15:06
哦,原來(lái)問(wèn)題出現(xiàn)在這里,我明白了,不過(guò)為什么一定要外接電阻lcd才可以正常顯示呢?
ID:213173 發(fā)表于 2023-11-18 06:55 | 顯示全部樓層
深層次 發(fā)表于 2023-11-17 22:30
仿真用的AT89C52的P0與其它端口不同,是開(kāi)漏模式,內(nèi)部沒(méi)有上拉電阻。外部器件如不能提供高電平條件就得外加上拉電阻。
ID:1099277 發(fā)表于 2023-11-18 19:11 | 顯示全部樓層
需要加上拉電阻才能驅(qū)動(dòng)lcd顯示
