查看: 2187|回復: 2
單片機60秒計時秒表(仿真+程序)
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. unsigned char table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
  5. sbit shi=P0^0;
  6. sbit ge=P0^1;
  7. sbit key0 = P1^5;
  8. sbit key1 = P1^6;
  9. sbit key2 = P1^7;
  10. uint num = 0;
  11. bit key0_enter=0;
  12. bit key1_enter=0;
  13. bit key2_enter=0;
  14. void init(void)
  15. {
  16.         ge = 1;
  17.         shi = 1;
  18.         EA = 1;
  19.         IT0 = 1;
  20. }
  21. void delay(uchar ms)
  22. {
  23. uchar i ,j;
  24. for (i=0;i<ms;i++)
  25.          for(j=101;j>0;j--);
  26. }
  27. void key_loop()
  28. {
  29.         if ((key0==0)&&(key0_enter==0))
  30.         {
  31.                 key0_enter=1;
  32.                 EX0=1;
  33.         }
  34.         if(key0==1)
  35.         {
  36.          key0_enter=0;
  37.         }
  38.         if ((key1==0)&&(key1_enter==0))
  39.         {
  40.                 key1_enter=1;
  41.                 EX0=0;
  42.         }
  43.         if(key1==1)
  44.         {
  45.          key1_enter=0;
  46.         }
  47.         if ((key2==0)&&(key2_enter==0))
  48.         {
  49.                 key2_enter=1;
  50.                 num = 0;
  51.         }
  52.         if(key2==1)
  53.         {
  54.          key2_enter=0;
  55.         }
  56. }
  57. void display()
  58. {
  59.         static uchar nms=0;
  60.         static bit wei=0;
  61.          uchar ges=0;
  62.          uchar shis=0;
  63.         nms++;
  64.         if(nms>5)
  65.         {
  66.          nms=0;
  67.
  68.
  69.          if(wei)
  70.          {
  71.            shis=(num/10)%10;
  72.                    ge=0;
  73.                 shi=0;
  74.                 P2=table[shis];
  75.                 shi=1;
  76.                 wei=0;
  77.          }
  78.          else
  79.          {
  80.            ges=num%10;
  81.                 ge=0;
  82.                 shi=0;
  83.                  P2=table[ges];
  84.                            ge=1;
  85.          wei=1;
  86.          }        }
  87. }
  88. void main()
  89. {
  90.   init();
  91.   for(;;)
  92.   {
  93.         key_loop();
  94.         display();
  95.         delay(1);
  96.   }
  97. }
  98. void waibu() interrupt 0
  99. {
  100.         num++;
  101. }
仿真程序51hei附件下載:
共陽極單片機.7z (69.93 KB, 下載次數: 29)
收藏收藏2 分享淘帖 頂1 踩
ID:1101845 發表于 2024-1-3 19:33 | 只看該作者
這是AT89C51板子嗎
ID:1107942 發表于 2024-1-4 12:54 | 只看該作者
這個就是at89c51的
