查看: 565|回復: 0
DHT11溫濕度模塊 單片機程序不完整
資料代碼分享
  1. #include "DHT11.h"
  2. extern unsigned char temperature,humidity;
  3. //選擇PA4作為 data線
  4. void SET_PA4_OUTPUT(void)
  5. {
  6.         //Gec_GPIO_Init(GPIOA, GPIO_Pin_4, GPIO_MODE_OUT_PP);
  7.         GPIO_InitTypeDef g;
  8.         RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOA,  ENABLE);
  9.         g.GPIO_Pin = GPIO_Pin_4;
  10.         g.GPIO_Mode = GPIO_Mode_OUT;
  11.         g.GPIO_OType = GPIO_OType_PP;
  12.         g.GPIO_Speed = GPIO_Speed_50MHz;
  13.         GPIO_Init( GPIOA, &g);
  14. }
  15. void  SET_PA4_INPUT(void)
  16. {
  17.         // Gec_GPIO_Init(GPIOA, GPIO_Pin_4, GPIO_MODE_IN_PULLUP);
  18.         GPIO_InitTypeDef g;
  19.
  20.         RCC_AHB1PeriphClockCmd( RCC_AHB1Periph_GPIOA,  ENABLE);
  21.         g.GPIO_Pin = GPIO_Pin_4;
  22.         g.GPIO_Mode = GPIO_Mode_IN;
  23.         g.GPIO_PuPd = GPIO_PuPd_NOPULL;
  24.         //g.GPIO_OType = GPIO_OType_PP;
  25.         //g.GPIO_Speed = GPIO_Speed_50MHz;
  26.         GPIO_Init( GPIOA, &g);
  27.
  28. }
  29. static unsigned char Read_Byte(void)
  30. {
  31.         SET_PA4_INPUT();
  32.         unsigned char i,ByteData=0;
  33.         for(i=0;i<8;i++)
  34.         {
  35.                 ByteData <<= 1;//先左移一位,因為數據是高位先出
  36.                 while(!(PAin(4)==0));//每個bit都是從50us的低電平開始
  37.                 while(!(PAin(4)==1));//等待變為高電平
  38.                 udelay(30);//延時30us
  39.
  40.                 if(PAin(4) == 1)//說明該Bit位就是1
  41.                 {
  42.                         ByteData |=  1;//把最低位變為1
  43.                 }
  44.         }
  45.         return ByteData;
  46. }
  47. /*
  48. Read_DHT11:向DHT11發送命令,讀取溫濕度數據
  49. 參數:
  50. 返回值:
  51. 讀取成功返回1,失敗返回0
  52. */
  53. int Read_DHT11(void)
  54. {
  55.         unsigned char ReadBuf[5];
  56.         /*主機發送開始信號*/
  57.         SET_PA4_OUTPUT();//設置為輸出模式
  58.         PAout(4) = 0;
  59.         udelay(20000);//至少18ms
  60.         /*主機拉高20~40us*/
  61.         PAout(4) = 1;
  62.         udelay(40);
  63.         /*等待DHT11回響應信號*/
  64.         SET_PA4_INPUT();//設置為輸入模式
  65.         while(!(PAin(4)==0));//等待總線變為低電平(響應信號)
  66.         /*等待DHT11拉高80us,DHT11開始傳輸數據*/
  67.         while(!(PAin(4)==1));
  68.         /*數據總共有40bits,即5個字節*/
  69.         ReadBuf[0] = Read_Byte();
  70.         ReadBuf[1] = Read_Byte();
  71.         ReadBuf[2] = Read_Byte();
  72.         ReadBuf[3] = Read_Byte();
  73.         ReadBuf[4] = Read_Byte();
  74.         /*校驗*/
  75.         if((ReadBuf[0]+ReadBuf[1]+ReadBuf[2]+ReadBuf[3])%256 == ReadBuf[4])//校驗成功
  76.         {
  77.                 humidity = ReadBuf[0];
  78.                 temperature = ReadBuf[2];
  79.                 return 1;
  80.         }
  81.         else
  82.         {
  83.                 return 0;
  84.         }
  85. }
下載: DHT11.zip (2 MB, 下載次數: 0)
