- /* RFID_RC522門禁系統(tǒng) */
- /* 接線: RC522模塊:RST接PB11;MISO接PB10; MOSI接PB1;SCK接PB0;SDA接PA7;
- 0.96寸OLED:scl接PB8,sda接PB9
- 有源蜂鳴器:I/O接PA3
- 180度舵機:信號線接PA1(5V電源驅(qū)動)
- 按鍵1:PB12; 按鍵2:PB14;按鍵3:PA9;按鍵4:PA12;
- 具體功能描述:
- 讀模式: 上電后默認為讀模式,按下2鍵后進入寫模式,按下3鍵進入刪模式
- 寫模式: 在寫模式下將靠近感應(yīng)區(qū)即可寫成功,已錄入的不能重復(fù)錄入,在寫模式下按下1鍵進入尋模式,按下3鍵進入刪模式
- 刪模式: 在刪`模式下按下1鍵或2鍵選擇要刪除的,按下3鍵確認刪除,按下4鍵返回到讀模式。
- #include "stm32f10x.h" // Device header
- #include "RC522.H"
- uint8_t UID[4],Temp[4];
- uint8_t UI0[4]={0xFF,0xFF,0xFF,0xFF}; //0ID號
- uint8_t UI1[4]={0xFF,0xFF,0xFF,0xFF}; //1ID號
- uint8_t UI2[4]={0xFF,0xFF,0xFF,0xFF}; //2ID號
- uint8_t UI3[4]={0xFF,0xFF,0xFF,0xFF}; //3ID號
- //RC522端口定義
- void PcdInit()
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Enable the GPIO Clock */
- RCC_APB2PeriphClockCmd(MF522_RST_CLK, ENABLE);
- /* Configure the GPIO pin */
- GPIO_InitStructure.GPIO_Pin = MF522_RST_PIN;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_Init(MF522_RST_PORT, &GPIO_InitStructure);
- RCC_APB2PeriphClockCmd(MF522_MISO_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MF522_MISO_PIN;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- GPIO_Init(MF522_MISO_PORT, &GPIO_InitStructure);
- RCC_APB2PeriphClockCmd(MF522_MOSI_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MF522_MOSI_PIN;
- GPIO_Init(MF522_MOSI_PORT, &GPIO_InitStructure);
- RCC_APB2PeriphClockCmd(MF522_SCK_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MF522_SCK_PIN;
- GPIO_Init(MF522_SCK_PORT, &GPIO_InitStructure);
- RCC_APB2PeriphClockCmd(MF522_NSS_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = MF522_NSS_PIN;
- GPIO_Init(MF522_NSS_PORT, &GPIO_InitStructure);
- ///////////////////////以下為RC522驅(qū)動函數(shù)/////////////////////////
- //功 能:尋
- //參數(shù)說明: req_code[IN]:尋方式
- // 0x52 = 尋感應(yīng)區(qū)內(nèi)所有符合14443A標(biāo)準的
- // 0x26 = 尋未進入休眠狀態(tài)的
- // pTagType[OUT]:片類型代碼
- // 0x4400 = Mifare_UltraLight
- // 0x0400 = Mifare_One(S50)
- // 0x0200 = Mifare_One(S70)
- // 0x0800 = Mifare_Pro(X)
- // 0x4403 = Mifare_DESFire
- //返 回: 成功返回MI_OK
- char PcdRequest(unsigned char req_code,unsigned char *pTagType)
- char status;
- unsigned int unLen;
- unsigned char ucComMF522Buf[MAXRLEN];
- // unsigned char xTest ;
- ClearBitMask(Status2Reg,0x08);
- WriteRawRC(BitFramingReg,0x07);
- // xTest = ReadRawRC(BitFramingReg);
- // if(xTest == 0x07 )
- // { LED_GREEN =0 ;}
- // else {LED_GREEN =1 ;while(1){}}
- SetBitMask(TxControlReg,0x03);
- ucComMF522Buf[0] = req_code;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);
- // if(status == MI_OK )
- // else {LED_GREEN =1 ;}
- if ((status == MI_OK) && (unLen == 0x10))
- *pTagType = ucComMF522Buf[0];
- *(pTagType+1) = ucComMF522Buf[1];
- else
- { status = MI_ERR; }
- return status;
- //功 能:防沖撞
- //參數(shù)說明: pSnr[OUT]:片序列號,4字節(jié)
- //返 回: 成功返回MI_OK
- char PcdAnticoll(unsigned char *pSnr)
- char status;
- unsigned char i,snr_check=0;
- WriteRawRC(BitFramingReg,0x00);
- ClearBitMask(CollReg,0x80);
- ucComMF522Buf[0] = PICC_ANTICOLL1;
- ucComMF522Buf[1] = 0x20;
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
- if (status == MI_OK)
- for (i=0; i<4; i++)
- *(pSnr+i) = ucComMF522Buf[ i];
- snr_check ^= ucComMF522Buf[ i];
- if (snr_check != ucComMF522Buf[ i])
- SetBitMask(CollReg,0x80);
- return status;
- //功 能:選定片
- //參數(shù)說明: pSnr[IN]:片序列號,4字節(jié)
- //返 回: 成功返回MI_OK
- char PcdSelect(unsigned char *pSnr)
- char status;
- unsigned char i;
- ucComMF522Buf[1] = 0x70;
- ucComMF522Buf[6] = 0;
- ucComMF522Buf[i+2] = *(pSnr+i);
- ucComMF522Buf[6] ^= *(pSnr+i);
- CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x18))
- { status = MI_OK; }
- else
- return status;
- //功 能:驗證片密碼
- //參數(shù)說明: auth_mode[IN]: 密碼驗證模式
- // 0x60 = 驗證A密鑰
- // 0x61 = 驗證B密鑰
- // addr[IN]:塊地址
- // pKey[IN]:密碼
- // pSnr[IN]:片序列號,4字節(jié)
- //返 回: 成功返回MI_OK
- char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
- char status;
- unsigned char i,ucComMF522Buf[MAXRLEN];
- ucComMF522Buf[0] = auth_mode;
- ucComMF522Buf[1] = addr;
- for (i=0; i<6; i++)
- { ucComMF522Buf[i+2] = *(pKey+i); }
- { ucComMF522Buf[i+8] = *(pSnr+i); }
- // memcpy(&ucComMF522Buf[2], pKey, 6);
- // memcpy(&ucComMF522Buf[8], pSnr, 4);
- status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
- if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
- return status;
- //功 能:讀取M1一塊數(shù)據(jù)
- //參數(shù)說明: addr[IN]:塊地址
- // pData[OUT]:讀出的數(shù)據(jù),16字節(jié)
- //返 回: 成功返回MI_OK
- char PcdRead(unsigned char addr,unsigned char *pData)
- char status;
- ucComMF522Buf[0] = PICC_READ;
- CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
- if ((status == MI_OK) && (unLen == 0x90))
- // { memcpy(pData, ucComMF522Buf, 16); }
- for (i=0; i<16; i++)
- { *(pData+i) = ucComMF522Buf[ i]; }
- else
- return status;
- //功 能:寫數(shù)據(jù)到M1一塊
- // pData[IN]:寫入的數(shù)據(jù),16字節(jié)
- //返 回: 成功返回MI_OK
- char PcdWrite(unsigned char addr,unsigned char *pData)
- char status;
- ucComMF522Buf[0] = PICC_WRITE;
- if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
- //memcpy(ucComMF522Buf, pData, 16);
- { ucComMF522Buf[ i] = *(pData+i); }
- CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
- status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
- return status;
- //功 能:命令片進入休眠狀態(tài)
- //返 回: 成功返回MI_OK
- char PcdHalt(void)
- ucComMF522Buf[0] = PICC_HALT;
- ucComMF522Buf[1] = 0;
- PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
- return MI_OK;
- //用MF522計算CRC16函數(shù)
- void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
- unsigned char i,n;
- ClearBitMask(DivIrqReg,0x04);
- WriteRawRC(CommandReg,PCD_IDLE);
- SetBitMask(FIFOLevelReg,0x80);
- for (i=0; i<len; i++)
- { WriteRawRC(FIFODataReg, *(pIndata+i)); }
- WriteRawRC(CommandReg, PCD_CALCCRC);
- i = 0xFF;
- do
- n = ReadRawRC(DivIrqReg);
- i--;
- while ((i!=0) && !(n&0x04));
- pOutData[0] = ReadRawRC(CRCResultRegL);
- pOutData[1] = ReadRawRC(CRCResultRegM);
- //功 能:復(fù)位RC522
- //返 回: 成功返回MI_OK
- char PcdReset(void)
- RST_H;
- delay_10ms(1);
- RST_L;
- delay_10ms(1);
- RST_H;
- delay_10ms(10);
- if(ReadRawRC(0x02) == 0x80)
- WriteRawRC(CommandReg,PCD_RESETPHASE);
- WriteRawRC(ModeReg,0x3D); //和Mifare通訊,CRC初始值0x6363
- WriteRawRC(TReloadRegL,30);
- WriteRawRC(TReloadRegH,0);
- WriteRawRC(TModeReg,0x8D);
- WriteRawRC(TPrescalerReg,0x3E);
- WriteRawRC(TxAutoReg,0x40);
- return MI_OK;
- //設(shè)置RC632的工作方式
- char M500PcdConfigISOType(unsigned char type)
- if (type == 'A') //ISO14443_A
- /* WriteRawRC(CommandReg,0x20); //as default
- WriteRawRC(ComIEnReg,0x80); //as default
- WriteRawRC(DivlEnReg,0x0); //as default
- WriteRawRC(ComIrqReg,0x04); //as default
- WriteRawRC(DivIrqReg,0x0); //as default
- WriteRawRC(Status2Reg,0x0);//80 //trun off temperature sensor
- WriteRawRC(WaterLevelReg,0x08); //as default
- WriteRawRC(ControlReg,0x20); //as default
- WriteRawRC(CollReg,0x80); //as default
- WriteRawRC(ModeReg,0x3D);//3F
- /* WriteRawRC(TxModeReg,0x0); //as default???
- WriteRawRC(RxModeReg,0x0); //as default???
- WriteRawRC(TxControlReg,0x80); //as default???
- WriteRawRC(TxSelReg,0x10); //as default???
- WriteRawRC(RxSelReg,0x86);//84
- // WriteRawRC(RxThresholdReg,0x84);//as default
- // WriteRawRC(DemodReg,0x4D); //as default
- // WriteRawRC(ModWidthReg,0x13);//26
- WriteRawRC(RFCfgReg,0x7F); //4F
- /* WriteRawRC(GsNReg,0x88); //as default???
- WriteRawRC(CWGsCfgReg,0x20); //as default???
- WriteRawRC(ModGsCfgReg,0x20); //as default???
- WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
- // PcdSetTmo(106);
- delay_10ms(1);
- PcdAntennaOn();
- else{ return (char)-1; }
- return MI_OK;
- //功 能:讀RC632寄存器
- //參數(shù)說明:Address[IN]:寄存器地址
- //返 回:讀出的值
- unsigned char ReadRawRC(unsigned char Address)
- unsigned char i, ucAddr;
- unsigned char ucResult=0;
- NSS_L;
- ucAddr = ((Address<<1)&0x7E)|0x80;
- for(i=8;i>0;i--)
- SCK_L;
- if(ucAddr&0x80)
- MOSI_H;
- else
- MOSI_L;
- SCK_H;
- ucAddr <<= 1;
- for(i=8;i>0;i--)
- SCK_L;
- ucResult <<= 1;
- SCK_H;
- if(READ_MISO == 1)
- ucResult |= 1;
- NSS_H;
- SCK_H;
- return ucResult;
- //功 能:寫RC632寄存器
- // value[IN]:寫入的值
- void WriteRawRC(unsigned char Address, unsigned char value)
- SCK_L;
- NSS_L;
- ucAddr = ((Address<<1)&0x7E);
- for(i=8;i>0;i--)
- if(ucAddr&0x80)
- MOSI_H;
- else
- MOSI_L;
- SCK_H;
- ucAddr <<= 1;
- SCK_L;
- for(i=8;i>0;i--)
- if(value&0x80)
- MOSI_H;
- else
- MOSI_L;
- SCK_H;
- value <<= 1;
- SCK_L;
- NSS_H;
- SCK_H;
- //功 能:置RC522寄存器位
- //參數(shù)說明:reg[IN]:寄存器地址
- // mask[IN]:置位值
- void SetBitMask(unsigned char reg,unsigned char mask)
- char tmp = 0x0;
- tmp = ReadRawRC(reg);
- WriteRawRC(reg,tmp | mask); // set bit mask
- //功 能:清RC522寄存器位
- // mask[IN]:清位值
- void ClearBitMask(unsigned char reg,unsigned char mask)
- char tmp = 0x0;
- WriteRawRC(reg, tmp & ~mask); // clear bit mask
- //功 能:通過RC522和ISO14443通訊
- //參數(shù)說明:Command[IN]:RC522命令字
- // pInData[IN]:通過RC522發(fā)送到片的數(shù)據(jù)
- // InLenByte[IN]:發(fā)送數(shù)據(jù)的字節(jié)長度
- // pOutData[OUT]:接收到的片返回數(shù)據(jù)
- // *pOutLenBit[OUT]:返回數(shù)據(jù)的位長度
- char PcdComMF522(unsigned char Command,
- unsigned char *pInData,
- unsigned char InLenByte,
- unsigned char *pOutData,
- unsigned int *pOutLenBit)
- char status = MI_ERR;
- unsigned char irqEn = 0x00;
- unsigned char waitFor = 0x00;
- unsigned char lastBits;
- unsigned char n;
- unsigned int i;
- switch (Command)
- case PCD_AUTHENT:
- irqEn = 0x12;
- waitFor = 0x10;
- break;
- case PCD_TRANSCEIVE:
- irqEn = 0x77;
- waitFor = 0x30;
- break;
- default:
- break;
- WriteRawRC(ComIEnReg,irqEn|0x80);
- ClearBitMask(ComIrqReg,0x80);
- for (i=0; i<InLenByte; i++)
- { WriteRawRC(FIFODataReg, pInData[ i]); }
- WriteRawRC(CommandReg, Command);
- if (Command == PCD_TRANSCEIVE)
- { SetBitMask(BitFramingReg,0x80); }
- // i = 600;//根據(jù)時鐘頻率調(diào)整,操作M1最大等待時間25ms
- i = 2000;
- do
- n = ReadRawRC(ComIrqReg);
- i--;
- while ((i!=0) && !(n&0x01) && !(n&waitFor));
- ClearBitMask(BitFramingReg,0x80);
- if (i!=0)
- if(!(ReadRawRC(ErrorReg)&0x1B))
- status = MI_OK;
- if (n & irqEn & 0x01)
- { status = MI_NOTAGERR; }
- n = ReadRawRC(FIFOLevelReg);
- lastBits = ReadRawRC(ControlReg) & 0x07;
- if (lastBits)
- { *pOutLenBit = (n-1)*8 + lastBits; }
- else
- { *pOutLenBit = n*8; }
- if (n == 0)
- { n = 1; }
- if (n > MAXRLEN)
- { n = MAXRLEN; }
- for (i=0; i<n; i++)
- { pOutData[ i] = ReadRawRC(FIFODataReg); }
- else
- SetBitMask(ControlReg,0x80); // stop timer now
- return status;
- //開啟天線
- //每次啟動或關(guān)閉天險發(fā)射之間應(yīng)至少有1ms的間隔
- void PcdAntennaOn()
- unsigned char i;
- i = ReadRawRC(TxControlReg);
- if (!(i & 0x03))
- SetBitMask(TxControlReg, 0x03);
- //關(guān)閉天線
- void PcdAntennaOff()
- ClearBitMask(TxControlReg, 0x03);
- //等待離開
- void WaitCardOff(void)
- char status;
- unsigned char TagType[2];
- while(1)
- status = PcdRequest(REQ_ALL, TagType);
- if(status)
- if(status)
- if(status)
- return;
- delay_10ms(10);
- // Delay 10ms
- void delay_10ms(unsigned int _10ms)
- unsigned int i, j;
- for(i=0; i<_10ms; i++)
- for(j=0; j<60000; j++);
- ///////////////////////以上為RC522驅(qū)動函數(shù)/////////////////////////
- //RFID模塊初始化
- void RFID_Init(void)
- PcdInit(); //RC522端口定義
- PcdReset(); //復(fù)位RC522
- PcdAntennaOff(); //關(guān)天線
- PcdAntennaOn(); //開天線
- M500PcdConfigISOType('A');
- //獲取編號函數(shù),返回編號1-3,非系統(tǒng)錄入返回0,沒有識別到返回5或6
- uint8_t Rc522Test(void)
- uint8_t cardno;
- if (PcdRequest(REQ_ALL, Temp) == MI_OK)//尋
- if (PcdAnticoll(UID) == MI_OK)//防沖撞
- cardno=0;
- if(UID[0]==UI0[0]&&UID[1]==UI0[1]&&UID[2]==UI0[2]&&UID[3]==UI0[3])
- cardno=1;
- else if(UID[0]==UI1[0]&&UID[1]==UI1[1]&&UID[2]==UI1[2]&&UID[3]==UI1[3])
- cardno=2;
- else if(UID[0]==UI2[0]&&UID[1]==UI2[1]&&UID[2]==UI2[2]&&UID[3]==UI2[3])
- cardno=3;
- else if(UID[0]==UI3[0]&&UID[1]==UI3[1]&&UID[2]==UI3[2]&&UID[3]==UI3[3])
- cardno=4;
- else cardno = 0;
- else cardno = 5;
- else cardno = 6;
- return cardno;
原理圖: 無
仿真: 無
代碼:
NFC門禁系統(tǒng).zip
(332.47 KB, 下載次數(shù): 19)
2023-10-20 12:19 上傳
下載積分: 黑幣 -5
