查看: 1417|回復: 3
哪里錯了error C267: 'matrix_showcol': requires ANSI-style prototype
ID:1096113 發表于 2023-10-15 13:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <regx52.h>
#include"matrix.h"
unsigned char code donghua[]=
0x18,0x18,0x3D,0x5A,0x98,0x28,0x28,0x28,
0x5A,0x5A,0x3C,0x18,0x18,0x28,0x18,0x08,
0x30,0x18,0x3C,0x1C,0x18,0x18,0x18,0x08,
0x30,0x98,0x7C,0x18,0x18,0x28,0x18,0x08,
0x10,0x18,0x3C,0x3C,0x18,0x28,0x28,0x08,
0x30,0x18,0x3C,0x3C,0x18,0x24,0x24,0x44,
0x30,0x18,0x3C,0x38,0x18,0x28,0x24,0x44,
0x18,0x0C,0x1E,0x1C,0x0C,0x14,0x24,0x44,
0x00,0x30,0x18,0x3C,0x1C,0x38,0x28,0x44,
0x00,0xC0,0x60,0xF0,0xF0,0x30,0x48,0x44,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
int main()
        unsigned char i,offset,count=0;
        void matrix_init();
                for(i=0;i<8;i++)
                        matrix_showcol(i,donghua[i+offset]);
                count++;
                if(count>40)
                        count=0;
                        offset+=8;
                        if(offset>160)
                        {offset=0;}
main.c(2): warning C318: can't open file 'matrix.h'
main.c(40): warning C206: 'matrix_showcol': missing function-prototype
main.c(40): error C267: 'matrix_showcol': requires ANSI-style prototype
Target not created.
Build Time Elapsed:  00:00:00
ID:655210 發表于 2023-10-15 15:08 | 只看該作者
看樣子是matrix.h沒有加入到項目中
ID:883242 發表于 2023-10-15 15:30 | 只看該作者
問題在第一個錯誤,后面都是連鎖反應,解決了h文件找不到的問題,后面都會迎刃而解。h文件在哪里除了你別人都不可能知道。
ID:57657 發表于 2023-10-15 18:18 | 只看該作者
你要將頭文件  matrix.h 里的代碼貼出來,問題才可以解決。
