用定時器按一定時間間隔掃描按鍵
- #include "main.h"
- #define A3_OFF GPIO_SetBits(GPIOA,GPIO_Pin_3);
- #define A3_ON GPIO_ResetBits(GPIOA,GPIO_Pin_3);
- #define u8 uint8_t
- #define KEY0_Read GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_1)
- unsigned char key0_flag = RESET;
- #define BSRR_VAL 0x0006
- uint8_t a=9;
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- GPIO_InitTypeDef GPIO_InitStructure;
- u8 Key_left=1,Key_up,Key_right, Key_down;
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- static uint8_t fac_us = 0;
- static uint16_t fac_ms = 0;
- * @brief Main program.
- * @param None
- * @retval None
- void KEY_Scan(void);
- void Delay(__IO uint32_t nCount)
- for(; nCount != 0; nCount--);
- void delay_ms(uint16_t nms)
- uint32_t temp;
- SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
- fac_us = SystemCoreClock/8000000;
- fac_ms = (uint16_t)fac_us*1000;
- if( nms > 0 )
- SysTick->LOAD=(uint32_t)nms*fac_ms; //時間加載(SysTick->LOAD為24bit)
- SysTick->VAL =0x00; //清空計數(shù)器
- SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk ; //開始倒數(shù)
- do
- temp=SysTick->CTRL;
- while(temp&0x01&&!(temp&(1<<16))); //等待時間到達
- SysTick->CTRL&=~SysTick_CTRL_ENABLE_Msk; //關閉計數(shù)器
- SysTick->VAL =0X00; //清空計數(shù)器
- void KEY_GPIO_Init(void)
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
- GPIO_InitStructure.GPIO_Schmit = GPIO_Schmit_Disable;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- void GPIO_CONIG()
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7| GPIO_Pin_2| GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- void TIM2_Configuration(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
- /* Time base configuration */
- TIM_TimeBaseStructure.TIM_Period = 842; // 32M/38K = 842.10
- TIM_TimeBaseStructure.TIM_Prescaler = 0;
- TIM_TimeBaseStructure.TIM_ClockDivision = 0;
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
- TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
- TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
- /* PWM1 Mode configuration: Channel2 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
- TIM_OCInitStructure.TIM_Pulse =421;
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
- TIM_OC1Init(TIM2, &TIM_OCInitStructure);
- TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
- TIM_ARRPreloadConfig(TIM2, ENABLE);
- //中斷優(yōu)先級NVIC設置
- NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
- TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
- /* TIM2 enable counter */
- TIM_Cmd(TIM2, ENABLE);
- TIM_CtrlPWMOutputs(TIM2, ENABLE);
- //定時器3中斷服務程序
- void TIM2_IRQHandler(void) //TIM2中斷
- if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //檢查TIM2更新中斷發(fā)生與否
- TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //清除TIMx更新中斷標志
- // NEC_IR_Remote_Periodic_Task();
- KEY_Scan();
- static unsigned int key0_cnt = 0;
- if( RESET == KEY0_Read )
- key0_cnt ++;
- if( 380 == key0_cnt )
- key0_flag =1;
- if( key0_cnt > 38000 )
- key0_cnt = 38000;
- else
- key0_cnt = 0;
- int main(void)
- KEY_GPIO_Init();
- TIM2_Configuration();
- GPIO_CONIG();
- GPIO_SetBits(GPIOC,GPIO_Pin_7);
- while(1)
- // GPIO_SetBits(GPIOC,GPIO_Pin_7);
- // Delay(838709);//500ms
- // Delay(838709);
- //else if(key!=1)
- // GPIO_ResetBits(GPIOC,GPIO_Pin_7);
- if( 1 == key0_flag )
- GPIO_Toggle(GPIOC,GPIO_Pin_7); key0_flag=0;
原理圖: 無
仿真: 無
代碼:
GPIO_IOToggle.7z
(19.72 KB, 下載次數(shù): 1)
2023-9-24 21:48 上傳
