查看: 2933|回復: 7
STM32單片機外部中斷按鍵抖動不好消除,有什么辦法解決?
ID:302293 發表于 2023-9-20 16:52 | 顯示全部樓層 |閱讀模式
  * @file    main.c
  * @author  Alexander
  * @version V1.0.0
  * @date    04-January-2023
  * @brief   Main program body
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup HK32F030Mxx_StdPeriph_Examples
/** @addtogroup EXTI_Example
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
/* Private function prototypes -----------------------------------------------*/
static void EXTI4_Config(void);
static void EXTI1_Config(void);
void Delay(__IO uint32_t nCount)
  for(; nCount != 0; nCount--);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (KEIL_startup_hk32f030m.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_hk32f030m.c file
  /* Initialize LEDs mounted on EVAL board        */
  HK_EVAL_LEDInit(LED1);
        HK_EVAL_LEDInit(LED2);
        HK_EVAL_LEDInit(LED3);
        /* Configure PC4 in interrupt mode */
        EXTI4_Config();
        /* Configure PA1 in interrupt mode */
        EXTI1_Config();
  /*  Delay(838709/5);Infinite loop */
  while (1)
Delay(838709/5);
  * @brief  Configure PC4 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOC clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
  /* Configure PC4 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* Enable SYSCFG clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  /* Connect EXTI4 Line to PA0 pin */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource4);
  /* Configure EXTI4 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line4;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI4 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0x00;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  * @brief  Configure PA1 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOA clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  /* Configure PA1 pins as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Connect EXTI1 Line to PA1 pin */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource1);
  /* Configure EXTI1 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line1;
  /* Enable and set EXTI1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI1_IRQn;
void EXTI1_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line1) != RESET)
                /* Toggle LED2 */
    HK_EVAL_LEDToggle(LED2);
    /* Clear the EXTI line 0 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line1);
  * @brief  This function handles External line 4 interrupt request.
  * @param  None
  * @retval None
void EXTI4_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line4) != RESET)
    /* Toggle LED1 */
    HK_EVAL_LEDToggle(LED1);
    /* Clear the EXTI line 4 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line4);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
ID:634587 發表于 2023-9-21 08:32 | 顯示全部樓層
加個時間判斷,一定毫秒內的觸發忽略掉。
ID:161164 發表于 2023-9-21 09:51 | 顯示全部樓層
按鍵用啥中斷?用定時掃描不是更好嗎?
一定要用中斷就在進中斷后關閉中斷
等引腳電平恢復空閑時再開啟中斷
ID:829222 發表于 2023-9-22 10:09 | 顯示全部樓層
按鈕電平狀態為0時,觸發狀態ButtonFlag為1,然后再在定時器中斷中進行時鐘累加,如果在任意時刻,按鈕狀態為1,復位ButtonFlag為0,清空定時器累加數據,當定時器累加數據大于設定閾值,判斷為按鈕按下有效,我一直都是這么處理的
ID:517951 發表于 2023-9-25 07:28 | 顯示全部樓層
可以增加一個1nf的電容到地, 做下硬件濾波. 成本沒多少, 效果還可以,對軟件延時就沒那么要求高了.
ID:883242 發表于 2023-9-25 16:41 | 顯示全部樓層
就不應該用EXTI,用TIM。
ID:1034262 發表于 2023-9-25 17:19 | 顯示全部樓層
按鍵這種慢速事件就不應該用外中斷。
ID:1080935 發表于 2023-9-26 08:32 | 顯示全部樓層
確實不該用中斷處理按鍵,狀態機解決,定時或延時均可,延時可以用循環中程序的時間。
