查看: 1889|回復: 0
STC15單片機讀取BMP180氣壓傳感器數據并在串口打印
ID:759974 發表于 2023-9-12 23:38 | 顯示全部樓層 |閱讀模式
STC15單片機
實驗名稱:讀取BMP180氣壓傳感器,并在UART串口打印數值
實驗內容:
        UART串口9600波特率
        printf函數打印信息(putchar)
        #define FOSC 22118400L  //晶振頻率 22.1184MHz
實驗器材:
        STC15W408AS_DIP16 x1
        BMP180氣壓傳感器 x1
實驗心得:
主要參考 BMP085 arduino測試代碼
注意 BMP180 的 IIC 地址是 0xEE
        BMP180 讀寫部分
        參考bmp180.ino
void bmp180_init()
        i2c_bmp180_start();
        bmp180_calibration();
        i2c_bmp180_stop();
打印信息:
[17:16:37.017]接收←>New Messages...
                    ### BMP180 Calibration Data ###
                    ac1  ac2  ac3  ac4  ac5  ac6
                    001a 0006 00fc 0044 00c6 00ff
                    b1   b2   b5   mb   mc   md
                    0019 0073 0000 001c 0000 0000
                    ### BMP180 Read Data ###
                    read_ut: 27466
                    read_up: 0
                    ### BMP180 Cal Data ###
                    T: 32.1 C
                    P: 1000.3 hPa
                    Altitude: 108.4 m
main.c
  1. #include "config.h"
  2. #include "delay.h"
  3. #include "uart.h"
  4. #include "i2c_bmp180.h"
  5. #define LED_ON        P12 = 0
  6. #define LED_OFF        P12 = 1
  7. bit timer_flag_5s        = 0;        //5s定時觸發標志位
  8. uint8 delay_count        = 0;        //delay延遲計數器
  9. void bmp180_loop()
  10. {
  11.         uint16 read_ut;
  12.         uint32 read_up;
  13.         float temperature, pressure, atm, altitude;
  14.
  15.         i2c_bmp180_start();
  16.         read_ut = bmp180_read_ut();        //MUST be called first
  17.         read_up = bmp180_read_up();
  18.         i2c_bmp180_stop();
  19.         pressure        = bmp180_calc_pval(read_up);
  20.         temperature        = bmp180_calc_tval(read_ut);
  21.         atm = pressure / 101325; // "standard atmosphere"
  22.         altitude = bmp180_calc_altitude(pressure); //Uncompensated caculation - in Meters
  23.         i2c_bmp180_stop();
  24.         if(DEBUG_MODE) printf(">New Messages...\r\n");
  25.         if(DEBUG_MODE) printf("\r\n### BMP180 Calibration Data ###\r\n");
  26.         if(DEBUG_MODE) printf("ac1  ac2  ac3  ac4  ac5  ac6\r\n");
  27.         if(DEBUG_MODE) printf("%04bx %04bx %04bx %04bx %04bx %04bx\r\n", t_bmp180_cal_dat.ac1, t_bmp180_cal_dat.ac2, t_bmp180_cal_dat.ac3, t_bmp180_cal_dat.ac4, t_bmp180_cal_dat.ac5, t_bmp180_cal_dat.ac6);
  28.         if(DEBUG_MODE) printf("b1   b2   b5   mb   mc   md\r\n");
  29.         if(DEBUG_MODE) printf("%04bx %04bx %04bx %04bx %04bx %04bx\r\n", t_bmp180_cal_dat.b1, t_bmp180_cal_dat.b2, t_bmp180_cal_dat.b5, t_bmp180_cal_dat.mb, t_bmp180_cal_dat.mc, t_bmp180_cal_dat.md);
  30.         if(DEBUG_MODE) printf("\r\n### BMP180 Read Data ###\r\n");
  31.         if(DEBUG_MODE) printf("read_ut: %u\r\n", read_ut);
  32.         if(DEBUG_MODE) printf("read_up: %u\r\n", read_up);
  33.         if(DEBUG_MODE) printf("\r\n### BMP180 Cal Data ###\r\n");
  34.         if(DEBUG_MODE) printf("T: %4.1f C\r\n", temperature);
  35.         if(DEBUG_MODE) printf("P: %6.1f hPa\r\n", pressure/100.0f);
  36.         //if(DEBUG_MODE) printf("Std P: %6.1f hPa\r\n", atm);
  37.         if(DEBUG_MODE) printf("Altitude: %4.1f m\r\n", altitude);
  38. }
  39. //主函數
  40. void main(void)
  41. {
  42.         //設置STC15W408AS單片機端口為標準模式
  43.         Config_Port();
  44.         //串口初始化,波特率9600
  45.         UART_Config(9600);
  46.         //初始化bmp180傳感器
  47.         bmp180_init();
  48.         LED_OFF; //LED指示燈熄滅
  49.
  50.         // 事件處理循環
  51.         while(1)
  52.         {
  53.         if (timer_flag_5s)  //每隔5s執行以下分支
  54.         {
  55.                         LED_ON; //LED指示燈點亮
  56.                         bmp180_loop(); //讀取bmp180數據
  57.                         LED_OFF; //LED指示燈熄滅
  58.             timer_flag_5s = 0;
  59.                 }
  60.                 //延時周期200ms
  61.                 delay_x_ms(200);
  62.                 //5s定時觸發標志位
  63.                 if(25 == ++delay_count)
  64.                 {
  65.                         delay_count = 0;
  66.                         timer_flag_5s = 1;
  67.                 }
  68.         }
  69. }
原理圖: 無
仿真: 無
代碼: UART_PRINTF_BMP180_STC15W408AS.zip (11.88 KB, 下載次數: 21)
