GYJ-0023 某一個寶描述484.png (902.2 KB, 下載次數: 51)
2023-8-31 12:56 上傳
GYJ-0023 某一個寶描述492.png (869.68 KB, 下載次數: 55)
2023-8-31 12:56 上傳
GYJ-0023 某一個寶描述511.png (943.41 KB, 下載次數: 62)
2023-8-31 12:56 上傳
【聲明】此程序僅用于學習與參考,引用請注明版權和作者信息!
一次最多發送20組數據,大于這個數據就不再發送
#include <STC12C5A60S2.H>
unsigned char T0RH = 0; //T0重載值的高字節
unsigned char T0RL = 0; //T0重載值的低字節
extern void UartDriver(); //串口驅動函數,監測數據幀的接收,調度功能函數,需在主循環中調用
extern void ConfigUART(unsigned int baud); //串口配置函數,baud-通信波特率
extern void ConfigUART1(unsigned int baud1); //串口配置函數,baud-通信波特率
extern void UartRxMonitor(unsigned char ms); //串口接收監控,由空閑時間判定幀結束,需在定時中斷中調用,ms-定時間隔
extern void SendString(char *s) ;
extern void UartWrite(unsigned char *buf, unsigned char len); //串口數據寫入,即串口發送函數,buf-待發送數據的指針,len-指定的發送長度
extern void fengming();
uchar zh[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar jieshou[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar jj = 0;
sbit out0 = P2^0;
sbit out1 = P2^1;
sbit out2 = P2^2;
sbit out3 = P2^3;
sbit in0 = P2^4;
sbit in1 = P2^5;
sbit in2 = P2^6;
sbit in3 = P2^7;
sbit smgk = P3^6;
sbit boma1 = P1^1;
sbit boma2 = P1^0;
bit d1 = 1;
bit d2 = 1;
sbit in4 = P1^6;
sbit in5 = P1^5;
uchar code xianshi [] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf};
uchar dangqianzhuangtai[4][4] = {{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
void t0 () interrupt 1
uchar i;
static uchar lie = 0;
static uchar sao[2] = {1,1};
static uchar saomiaobaocun [4][4] = {{0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff}};
TH0 = 0xfc;
TL0 = 0x67;
UartRxMonitor(1); //串口接收監控
sao[0] = (sao[0]<<1) |in4;
sao[1] = (sao[1]<<1) |in5;
saomiaobaocun [lie][0] = (saomiaobaocun [lie][0]<<1) | in0;
saomiaobaocun [lie][1] = (saomiaobaocun [lie][1]<<1) | in1;
saomiaobaocun [lie][2] = (saomiaobaocun [lie][2]<<1) | in2;
saomiaobaocun [lie][3] = (saomiaobaocun [lie][3]<<1) | in3;
if(sao[0] == 0x00)
d1 = 0;
else if(sao[0] == 0xff)
d1 = 1;
if(sao[1] == 0x00)
d2 = 0;
else if(sao[1] == 0xff)
d2 = 1;
for (i=0;i<4;i++)
if ((saomiaobaocun [lie] & 0x0f) == 0x00)
dangqianzhuangtai[lie] = 0;
else if ((saomiaobaocun [lie] & 0x0f) == 0x0f)
dangqianzhuangtai[lie] = 1;
lie++;
lie = lie & 0x03;
switch (lie)
case 0 : out1 = 1; out2 = 1; out3 = 1; out0 = 0; break;
case 1 : out0 = 1; out2 = 1; out3 = 1; out1 = 0; break;
case 2 : out0 = 1; out1 = 1; out3 = 1; out2 = 0; break;
case 3 : out0 = 1; out1 = 1; out2 = 1; out3 = 0; break;
void main ()
uchar i,j;
bit q1 = 1;
bit q2 = 1;
uchar qianyicizhuangtai[4][4] = {{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
smgk = 0;
TMOD = 0x01;
TH0 = 0xfc;
TL0 = 0x67;
TR0 = 1;
EA = 1;
ET0 = 1;
P0 = xianshi[16];
// ConfigUART(9600); //配置波特率為9600
while (1)
UartDriver(); //調用串口驅動
if((boma1 == 0)&&(boma2 != 0))
ConfigUART(2400); //配置波特率為1200
if((boma2 == 0)&&(boma1 != 0))
ConfigUART(4800); //配置波特率為4800
if((boma1 == 0)&&(boma2 == 0))
if((boma1 != 0)&&(boma2 != 0))
ConfigUART1(19200); //配置波特率為19200
if(d1 != q1)
q1 = d1;
if(d1 == 0)
if((jj != 0)&&(jj <= 2))
zh[0] = jieshou[0] | jieshou[1];
UartWrite(zh, 1);
fengming();
if((jj > 2)&&(jj <= 4))
zh[1] = jieshou[2] | jieshou[3];
UartWrite(zh, 2);
fengming();
if((jj > 4)&&(jj <= 6))
zh[2] = jieshou[4] | jieshou[5];
UartWrite(zh, 3);
fengming();
if((jj > 6)&&(jj <= 8))
zh[3] = jieshou[6] | jieshou[7];
UartWrite(zh, 4);
fengming();
if((jj > 8)&&(jj <= 10))
zh[4] = jieshou[8] | jieshou[9];
UartWrite(zh, 5);
fengming();
if((jj > 10)&&(jj <= 12))
zh[5] = jieshou[10] | jieshou[11];
UartWrite(zh, 6);
fengming();
if((jj > 12)&&(jj <= 14))
zh[6] = jieshou[12] | jieshou[13];
UartWrite(zh, 7);
fengming();
if((jj > 14)&&(jj <= 16))
zh[7] = jieshou[14] | jieshou[15];
UartWrite(zh, 8);
fengming();
if((jj > 16)&&(jj <= 18))
zh[8] = jieshou[16] | jieshou[17];
UartWrite(zh, 9);
fengming();
if((jj > 18)&&(jj <= 20))
zh[9] = jieshou[18] | jieshou[19];
UartWrite(zh, 10);
fengming();
if(d2 != q2)
q2 = d2;
if(d2 == 0)
jj = 0;
jieshou[0] = 0x00;
jieshou[1] = 0x00;
jieshou[2] = 0x00;
jieshou[3] = 0x00;
jieshou[4] = 0x00;
jieshou[5] = 0x00;
jieshou[6] = 0x00;
jieshou[7] = 0x00;
jieshou[8] = 0x00;
jieshou[9] = 0x00;
P0 = xianshi[16];
fengming();
for (i=0;i<4;i++)
for (j=0;j<4;j++)
if(dangqianzhuangtai[j] != qianyicizhuangtai[j] )
qianyicizhuangtai[j] = dangqianzhuangtai[j];
if(qianyicizhuangtai[j] != 0)
jj++;
if((i*4+j) < 9)
P0 = xianshi[i*4+j+1];
if((i*4+j) == 9)
P0 = xianshi[0];
if((i*4+j) > 9)
P0 = xianshi[i*4+j];
fengming();
/******************1組**************************/
if(jj == 1)
//jieshou[0] = i*4+j;
//jieshou[0] = jieshou[0] << 4;
if((i*4+j) < 9)
jieshou[0] = i*4+j+1;
if((i*4+j) == 9)
jieshou[0] = 0;
if((i*4+j) > 9)
jieshou[0] = i*4+j;
if(jj == 2)
//jieshou[1] = i*4+j;
if((i*4+j) < 9)
jieshou[1] = i*4+j+1;
if((i*4+j) == 9)
jieshou[1] = 0;
if((i*4+j) > 9)
jieshou[1] = i*4+j;
/******************2組**************************/
if(jj == 3)
//jieshou[2] = i*4+j;
if((i*4+j) < 9)
jieshou[2] = i*4+j+1;
if((i*4+j) == 9)
jieshou[2] = 0;
if((i*4+j) > 9)
jieshou[2] = i*4+j;
jieshou[2] = jieshou[2] << 4;
if(jj == 4)
//jieshou[3] = i*4+j;
if((i*4+j) < 9)
jieshou[3] = i*4+j+1;
if((i*4+j) == 9)
jieshou[3] = 0;
if((i*4+j) > 9)
jieshou[3] = i*4+j;
/******************3組**************************/
if(jj == 5)
//jieshou[4] = i*4+j;
if((i*4+j) < 9)
jieshou[4] = i*4+j+1;
if((i*4+j) == 9)
jieshou[4] = 0;
if((i*4+j) > 9)
jieshou[4] = i*4+j;
jieshou[4] = jieshou[4] << 4;
if(jj == 6)
//jieshou[5] = i*4+j;
if((i*4+j) < 9)
jieshou[5] = i*4+j+1;
if((i*4+j) == 9)
jieshou[5] = 0;
if((i*4+j) > 9)
jieshou[5] = i*4+j;
/******************4組**************************/
if(jj == 7)
//jieshou[6] = i*4+j;
if((i*4+j) < 9)
jieshou[6] = i*4+j+1;
if((i*4+j) == 9)
jieshou[6] = 0;
if((i*4+j) > 9)
jieshou[6] = i*4+j;
jieshou[6] = jieshou[6] << 4;
if(jj == 8)
//jieshou[7] = i*4+j;
if((i*4+j) < 9)
jieshou[7] = i*4+j+1;
if((i*4+j) == 9)
jieshou[7] = 0;
if((i*4+j) > 9)
jieshou[7] = i*4+j;
/******************5組**************************/
if(jj == 9)
//jieshou[8] = i*4+j;
if((i*4+j) < 9)
jieshou[8] = i*4+j+1;
if((i*4+j) == 9)
jieshou[8] = 0;
if((i*4+j) > 9)
jieshou[8] = i*4+j;
jieshou[8] = jieshou[8] << 4;
if(jj == 10)
//jieshou[9] = i*4+j;
if((i*4+j) < 9)
jieshou[9] = i*4+j+1;
if((i*4+j) == 9)
jieshou[9] = 0;
if((i*4+j) > 9)
jieshou[9] = i*4+j;
/******************6組**************************/
if(jj == 11)
//jieshou[10] = i*4+j;
if((i*4+j) < 9)
jieshou[10] = i*4+j+1;
if((i*4+j) == 9)
jieshou[10] = 0;
if((i*4+j) > 9)
jieshou[10] = jieshou[10] << 4;
if(jj == 12)
//jieshou[11] = i*4+j;
if((i*4+j) < 9)
jieshou[11] = i*4+j+1;
if((i*4+j) == 9)
jieshou[11] = 0;
if((i*4+j) > 9)
/******************7組**************************/
if(jj == 13)
//jieshou[12] = i*4+j;
if((i*4+j) < 9)
jieshou[12] = i*4+j+1;
if((i*4+j) == 9)
jieshou[12] = 0;
if((i*4+j) > 9)
jieshou[12] = jieshou[12] << 4;
if(jj == 14)
//jieshou[13] = i*4+j;
if((i*4+j) < 9)
jieshou[13] = i*4+j+1;
if((i*4+j) == 9)
jieshou[13] = 0;
if((i*4+j) > 9)
/******************8組**************************/
if(jj == 15)
//jieshou[14] = i*4+j;
if((i*4+j) < 9)
jieshou[14] = i*4+j+1;
if((i*4+j) == 9)
jieshou[14] = 0;
if((i*4+j) > 9)
jieshou[14] = jieshou[14] << 4;
if(jj == 16)
//jieshou[15] = i*4+j;
if((i*4+j) < 9)
jieshou[15] = i*4+j+1;
if((i*4+j) == 9)
jieshou[15] = 0;
if((i*4+j) > 9)
/******************9組**************************/
if(jj == 17)
//jieshou[16] = i*4+j;
if((i*4+j) < 9)
jieshou[16] = i*4+j+1;
if((i*4+j) == 9)
jieshou[16] = 0;
if((i*4+j) > 9)
jieshou[16] = jieshou[16] << 4;
if(jj == 18)
//jieshou[17] = i*4+j;
if((i*4+j) < 9)
jieshou[17] = i*4+j+1;
if((i*4+j) == 9)
jieshou[17] = 0;
if((i*4+j) > 9)
/******************10組**************************/
if(jj == 19)
//jieshou[18] = i*4+j;
if((i*4+j) < 9)
jieshou[18] = i*4+j+1;
if((i*4+j) == 9)
jieshou[18] = 0;
if((i*4+j) > 9)
jieshou[18] = jieshou[18] << 4;
if(jj == 20)
//jieshou[19] = i*4+j;
if((i*4+j) < 9)
jieshou[19] = i*4+j+1;
if((i*4+j) == 9)
jieshou[19] = 0;
if((i*4+j) > 9)
void UartAction(unsigned char *buf, unsigned char len)
//在接收到的數據幀后添加換車換行符后發回
// buf[len++] = '\r';
//buf[len++] = '\n';
UartWrite(buf, (len-2));
