一、系統(tǒng)方案
2023-8-29 15:44 上傳
2023-8-29 15:44 上傳
二、硬件設(shè)計原理圖如下:
2023-8-29 15:45 上傳
三、單片機軟件設(shè)計
1、首先是系統(tǒng)初始化
void timer0_init() //定時器初始化
TCCR0=0x07; //普通模式,OC0不輸出,1024分頻
TCNT0=f_count; //初值,定時為10ms
TIFR=0x01; //清中斷標志位
TIMSK=0x01; //使能定時器0溢出中斷
SREG|=0x80; //開啟全局中斷
2、數(shù)碼管顯示程序
void Smg_Dispaly(uchar Value1,uchar Value2,uchar Num)
if(SmgCnt == 0)
PORTB = 0xFF;
PORTB = Smg_Duan[Value1/10];
PORTA = Smg_Wei[0];
else if(SmgCnt == 1)
PORTB = 0xFF;
PORTB = Smg_Duan[Value1%10];
PORTA = Smg_Wei[1];
else if(SmgCnt == 2)
else if(SmgCnt == 3)
PORTB = 0xFF;
PORTB = Smg_Duan[Value2/10];
PORTA = Smg_Wei[3];
else if(SmgCnt == 4)
PORTB = 0xFF;
PORTB = Smg_Duan[Value2%10];
PORTA = Smg_Wei[4];
else if(SmgCnt == 5)
else if(SmgCnt == 6)
else if(SmgCnt == 7)
PORTB = 0xFF;
PORTB = Smg_Duan[Num];
PORTA = Smg_Wei[7];
if(++SmgCnt >= 8)
SmgCnt = 0;
3、按鍵程序
if(PINC == 0xFF)
Kcnt = 0;Kflag = 0;
else if(Kflag == 0)
if(++Kcnt >= 3)
Kflag = 1;Kcnt = 0;timer = 0;
PORTE =~ PORTE;
if(DownCnt == 0)
switch(PINC)
case 0xFE: ValueNum = 1; ValueFlag = 1;break;
case 0xFD: ValueNum = 2; ValueFlag = 1;break;
case 0xFB: ValueNum = 3; ValueFlag = 1;break;
case 0xF7: ValueNum = 4; ValueFlag = 1;break;
case 0xEF: ValueNum = 5; ValueFlag = 1;break;
case 0xDF: ValueNum = 6; ValueFlag = 1;break;
case 0xBF: ValueNum = 7; ValueFlag = 1;break;
case 0x7F: ValueNum = 8; ValueFlag = 1;break;
default: break;
4、核心算法程序
#pragma interrupt_handler timer1_ovf_isr:15
void timer1_ovf_isr(void)
static uchar cnt = 0;
if(StartFlag == 0)
cnt = 0;
if(++cnt >= 200)
cnt = 0; // 定時器定時5ms,計數(shù)200次為1s
if(StartData == 0)
SecFlag = 1; // 秒信號
TCNT1H = (65535-500)/256;
TCNT1L = (65535-500)%256;
Smg_Dispaly(ValueCnt,ValueTmr,ValueNum);
四、proteus仿真設(shè)計Proteus軟件是一款應(yīng)用比較廣泛的工具,它可以在沒有硬件平臺的基礎(chǔ)上通過自身的軟件仿真出硬件平臺的運行情況,這樣就可以通過軟件仿真來驗證我們設(shè)計的方案有沒有問題,如果有問題,可以重新選擇器件,連接器件,直到達到我們設(shè)定的目的,避免我們搭建實物的時候,如果當(dāng)初選擇的方案有問題,我們器件都已經(jīng)焊接好了,再去卸載下去,再去焊接新的方案的器件,測試,這樣會浪費人力和物力,也給開發(fā)者帶來一定困惑,Proteus仿真軟件就很好的解決這個問題,我們在設(shè)計之初,就使用該軟件進行模擬仿真,測試,選擇滿足我們設(shè)計的最優(yōu)方案。最后根據(jù)測試沒問題的仿真圖紙,焊接實物,調(diào)試,最終完成本設(shè)計的作品。
2023-8-29 15:45 上傳
