查看: 3054|回復: 12
1602不顯示內容僅顯示白方塊
ID:1092057 發表于 2023-8-27 20:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
求助大佬幫忙看看,目的是做一個檢測光亮度的器件,目前檢測系統沒有問題,但原定的顯示部分(1602)無法正常顯示代碼如下
  1. #include <REG52.H>
  2. #include <math.h>
  3. #include <stdio.h>
  4. #include <INTRINS.H>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7. #define DataPort P0
  8. sbit    LCM_RS=P2^7;
  9. sbit    LCM_RW=P2^6;
  10. sbit    LCM_EN=P2^5;
  11. sbit k1=P1^5;
  12. sbit led=P3^7;
  13. sbit beep=P3^6;
  14. sbit light = P1^1;
  15. void    delay(unsigned int k);
  16. void    InitLcd();
  17. void    WriteDataLCM(uchar dataW);
  18. void    WriteCommandLCM(uchar CMD,uchar Attribc);
  19. void    DisplayOneChar(uchar X,uchar Y,uchar DData);
  20. void    LCD_Clear();
  21. void InitLcd()
  22. {
  23.         WriteCommandLCM(0x38,1);
  24.         WriteCommandLCM(0x08,1);
  25.         WriteCommandLCM(0x01,1);
  26.         WriteCommandLCM(0x06,1);
  27.         WriteCommandLCM(0x0c,1);
  28. }
  29. void WaitForEnable(void)
  30. {
  31.         DataPort=0xff;
  32.         LCM_RS=0;LCM_RW=1;_nop_();
  33.         LCM_EN=1;_nop_();_nop_();
  34.         while(DataPort&0x80);
  35.         LCM_EN=0;
  36. }
  37. void WriteCommandLCM(uchar CMD,uchar Attribc)
  38. {
  39.         if(Attribc)WaitForEnable();
  40.         LCM_RS=0;LCM_RW=0;_nop_();
  41.         DataPort=CMD;_nop_();
  42.         LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  43. }
  44. void WriteDataLCM(uchar dataW)
  45. {
  46.         WaitForEnable();
  47.         LCM_RS=1;LCM_RW=0;_nop_();
  48.         DataPort=dataW;_nop_();
  49.         LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  50. }
  51. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  52. {
  53.         Y&=1;
  54.         X&=15;
  55.         if(Y)X|=0x40;
  56.         X|=0x80;
  57.         WriteCommandLCM(X,0);
  58.         WriteDataLCM(DData);
  59. }
  60. void delay(unsigned int k)
  61. {
  62.         unsigned int i,j;
  63.         for(i=0;i<k;i++)
  64.         {
  65.         for(j=0;j<121;j++)
  66.         {;}
  67.         }
  68. }
  69. void LCD_Clear(void)
  70. {
  71.   WriteCommandLCM(0x01);
  72.   delay(20);
  73. }
  74. void main()
  75. {
  76.         InitLcd()
  77.         LCD_Clear();
  78.                 DisplayOneChar(0,1,'d');
  79.                 DisplayOneChar(1,1,'a');
  80.                 DisplayOneChar(2,1,'n');
  81.                 led=0;
  82.                 beep=1;
  83.                 k1=0;
  84.     WriteCommandLCM(0x08);
  85.      while(1)
  86.      {
  87.                          if(light==0)
  88.                          {
  89.                                 led=1;
  90.                                 beep=0;
  91.                          }
  92.     }
  93. }
ID:1085441 發表于 2023-8-28 00:26 | 只看該作者
這種情況一般是LCD的連接線有問題,查一下接線對不對,程序中IO定義對不對,程序讀寫時序對不對
ID:596109 發表于 2023-8-28 08:27 | 只看該作者
可以查查背光亮度調節,太亮可能會這樣
ID:190832 發表于 2023-8-28 08:54 | 只看該作者
調節背光電阻試試
ID:712097 發表于 2023-8-28 09:05 | 只看該作者
void InitLcd()
        WriteCommandLCM(0x38,1);delay(50);
        WriteCommandLCM(0x08,1);delay(50);
        WriteCommandLCM(0x01,1);delay(50);
        WriteCommandLCM(0x06,1);delay(50);
        WriteCommandLCM(0x0c,1);delay(50);
初始化函數每句加個延時試一下。
ID:97554 發表于 2023-8-28 15:23 | 只看該作者
這個程序能編譯?有錯誤沒有排除吧
ID:97554 發表于 2023-8-28 15:42 | 只看該作者
81和95 行 WriteCommandLCM(0x08);在聲明函數的時候void WriteCommandLCM(uchar CMD,uchar Attribc)里邊這是有參數的
87 行的 InitLcd()  后邊應該有個“ ;”吧?
原程序復制過來的話,不知道在你的KEIL里可以生成HEX?不報錯嗎?
ID:1040201 發表于 2023-8-28 15:55 | 只看該作者
確實少了;  但是顯示白塊 應該是有數據過來了 ,檢查硬件部分看看有沒有問題。再有這種現象  最好是拍個圖片上來。
ID:1085441 發表于 2023-8-28 17:55 | 只看該作者
如果是背光太亮,多少能看到些字符影子。
ID:1092176 發表于 2023-8-29 10:15 | 只看該作者
調節背光滑動電阻
ID:20836 發表于 2023-8-29 10:59 | 只看該作者
P0口有接上拉電阻嗎?
ID:202023 發表于 2023-8-29 23:37 | 只看該作者
void InitLcd()
        DataPort=0xff;
        LCM_EN=0;
這2個函數有問題,液晶不能初始化。你從壇子里搜一下, while(1)
                         if(light==0)
                                led=1;
                                beep=0;
    }while里面沒有顯示函數,就算能顯示,也一直顯示d,a,n三個字母。
