查看: 1873|回復: 4
簡單的問題,不知道哪錯了error C129: missing ';' before 'MB_CRC16'
ID:939553 發表于 2023-8-11 21:13 | 顯示全部樓層 |閱讀模式
頭文件
#ifndef _modbus_
#define _modbus_
uint16_t MB_CRC16(uint8_t *pucFrame, uint16_t usLen );
#endif
C文件
#include "Modbus_crc16.h"
//變量定義
static code uint8_t aucCRCHi[] =
  0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
  0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
  0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
  0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
  0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
static code uint8_t aucCRCLo[] =
  0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06, 0x07, 0xC7,
  0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD, 0x0F, 0xCF, 0xCE, 0x0E,
  0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09, 0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9,
  0x1B, 0xDB, 0xDA, 0x1A, 0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC,
  0x14, 0xD4, 0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
  0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3, 0xF2, 0x32,
  0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4, 0x3C, 0xFC, 0xFD, 0x3D,
  0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A, 0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38,
  0x28, 0xE8, 0xE9, 0x29, 0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF,
  0x2D, 0xED, 0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
  0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60, 0x61, 0xA1,
  0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67, 0xA5, 0x65, 0x64, 0xA4,
  0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F, 0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB,
  0x69, 0xA9, 0xA8, 0x68, 0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA,
  0xBE, 0x7E, 0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
  0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71, 0x70, 0xB0,
  0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92, 0x96, 0x56, 0x57, 0x97,
  0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C, 0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E,
  0x5A, 0x9A, 0x9B, 0x5B, 0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89,
  0x4B, 0x8B, 0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
  0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42, 0x43, 0x83,
  0x41, 0x81, 0x80, 0x40
/*函數*/
        uint8_t ucCRCHi = 0xFF;
        uint8_t ucCRCLo = 0xFF;
        uint16_t iIndex;
  while(usLen--)
    iIndex = ucCRCLo ^ *( pucFrame++);
    ucCRCLo = (uint8_t)( ucCRCHi ^ aucCRCHi[iIndex] );
    ucCRCHi = aucCRCLo[iIndex];
  return (uint16_t)( ucCRCHi << 8 | ucCRCLo );
編譯提示
Modbus_crc16.h(4): error C129: missing ';' before 'MB_CRC16'不知道哪錯??
ID:1088185 發表于 2023-8-11 21:23 | 顯示全部樓層
你貼出來的就是Modbus_crc16.h ?
如果是你干嘛 還再包含自己  #include "Modbus_crc16.h"
如果文件不是Modbus_crc16.h, 那問題就不在你貼出來的地方。
ID:939553 發表于 2023-8-11 21:35 | 顯示全部樓層
1600277881 發表于 2023-8-11 21:23
頭文件就是Modbus_crc16.h
c文件就是Modbus_crc16.c
單獨把c的內容復制到main函數,可以確認沒有問題,運行正常。
ID:939553 發表于 2023-8-11 22:15 | 顯示全部樓層
找到問題了,在C文件中引用了其他定義,未包含頭文件。
ID:939553 發表于 2023-8-11 22:20 | 顯示全部樓層
在C文件引用了其他文件的定義,包含該頭文件就可以了
