查看: 2312|回復: 5
這個簡易單片機秒表為什么沒反應?
ID:1090051 發表于 2023-7-30 11:42 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
sbit p3_3=P3^3;
sbit p2_7=P2^7;
char led_mod[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
char led_com[]={0x01,0x02,0x04,0x08,0x10,0x20};
sbit BEER=P1^1;
int TENms,s,m;
char data_time[6];
void delayms(uint xms)
                uint i,j;
                for(i=xms;i>0;i--)
                                for(j=110;j>0;j--);
void display()
{ uint k;
        data_time[0]=m;
        data_time[1]=10;
        data_time[2]=s/10;
        data_time[3]=s%10;
        data_time[4]=TENms/10;
        data_time[5]=TENms%10;
        for(k=0;k<5;k++)
                        P3=led_com[k];
                        P2=led_mod[data_time[k]];
        if(k==3)
                p3_3=1;
                p2_7=1;
        delayms(200);
isr_10msT0() interrupt 1
                TH0=(65536-500000)/256;
                TL0=(65536-500000)%256;
                TENms++;
                BEER=0;
                if(TENms==100)
                        TENms=0;
                        s++;
                        BEER=1;
                if(s==60)
                        s=0;
                        m++;
                if(m==9,s==59,TENms==99)
                                        m=9;
                                        BEER=0;
                                        TR0=0;
void main(void)
                TENms=0;
                s=0;
                m=0;
                BEER=0;
                TMOD=0x01;
          ET0=1;
                EA=1;
                                        display();
                                        switch(P0&0x1f)
                                                case 0xdf:TR0=1;break;
                                                case 0x7f:TR0=0;TENms=0;s=0;m=0;TR0=0;break;
                                                case 0xbf:TR0=0;TR0=0;break;
compiling main.c...
linking...
Program Size: data=38.0 xdata=0 code=619
creating hex file from ".\Objects\5"...
".\Objects\5" - 0 Error(s), 0 Warning(s).
Build Time Elapsed:  00:00:00
ID:332444 發表于 2023-7-30 12:55 | 顯示全部樓層
其他且不論先點一個數碼管正常后再點第二直到所有正常后再調試其他功能
ID:584814 發表于 2023-7-31 08:27 | 顯示全部樓層
這個壇里保姆不多,請先注釋好程序,謝謝
ID:161164 發表于 2023-7-31 11:30 | 顯示全部樓層
1。沒消影
2。沒延時
3。多余的延時
4。不能大于2^16(65536)
ID:213173 發表于 2023-7-31 14:35 | 顯示全部樓層
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. sbit key=P1^5;
  5. //sbit p2_7=P2^7;
  6. sbit BEER=P1^1;
  7. uchar led_mod[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
  8. uchar led_com[]={0x01,0x02,0x04,0x08,0x10,0x20};
  9. uint TENms;
  10. uchar s,m,count,value;
  11. uchar data_time[6];
  12. bit begin,sign;
  13. void delayms(uint xms)
  14. {
  15.         uint i,j;
  16.         for(i=xms;i>0;i--)
  17.                 for(j=110;j>0;j--);
  18. }
  19. void display()
  20. {
  21.         static uchar k;
  22.         data_time[0]=led_mod[m];
  23.         data_time[1]=led_mod[10];
  24.         data_time[2]=led_mod[s/10];
  25.         data_time[3]=led_mod[s%10]&0x7f;
  26.         data_time[4]=led_mod[TENms/10];
  27.         data_time[5]=led_mod[TENms%10];
  28.         P2=0xff;
  29.         P3=led_com[k];
  30.         P2=data_time[k];
  31.         k=++k%6;
  32. }
  33. void isr_10msT0() interrupt 1
  34. {
  35.         TH0=(65536-10000)/256;
  36.         TL0=(65536-10000)%256;
  37.         if(begin)
  38.         {
  39.                 if(++TENms==100)
  40.                 {
  41.                         TENms=0;
  42.                         if(++s==60)
  43.                         {
  44.                                 s=0;
  45.                                 m++;
  46.                         }
  47.                 }
  48.         }
  49.         if(m==9 && s==59 && TENms==99)
  50.         {
  51.                 BEER=1;
  52.                 begin=0;
  53.         }
  54. }
  55. void key_scan(void)
  56. {
  57.         if(!key)
  58.         {
  59.                 if(++count>=10 && sign==0)
  60.                 {
  61.                         sign=1;
  62.                         value=++value%3;
  63.                         switch(value)
  64.                         {
  65.                                 case 0:TENms=0;s=0;m=0;BEER=0; break;
  66.                                 case 1:begin=1; break;
  67.                                 case 2:begin=0; break;
  68.                         }
  69.                 }
  70.         }
  71.         else
  72.         {
  73.                 count=0;
  74.                 sign=0;
  75.         }
  76. }
  77. void main(void)
  78. {
  79.         TENms=0;
  80.         s=0;
  81.         m=0;
  82.         BEER=0;
  83.         TMOD=0x01;
  84.         TH0=(65536-10000)/256;
  85.         TL0=(65536-10000)%256;
  86.         TR0=1;
  87.         ET0=1;
  88.         EA=1;
  89.         while(1)
  90.         {
  91.                 display();
  92.                 key_scan();
  93.                 delayms(1);
  94.         }
  95. }
ID:1090051 發表于 2023-8-4 10:04 | 顯示全部樓層
#include<reg51.h>
sbit p3_3=P3^3;
sbit p2_7=P2^7;
sbit BEER=P1^1;
int TENms,s,m;
char data_time[6];
void display()
        uint k;
        data_time[0]=m;
        data_time[1]=10;
        data_time[2]=s/10;
        data_time[3]=s%10;
        for(k=0;k<6;k++)
                        P2=0xff;
                        P3=led_com[k];
                if(k==3)
                        p2_7=0;
                TENms++;
                BEER=0;
                if(TENms==100)
                        TENms=0;
                        s++;
                        BEER=1;
                if(s==60)
                        s=0;
                        m++;
                if(m==9&&s==59&&TENms==99)
                        m=9;
                        BEER=0;
                        TENms=0;
                        TR0=0;
void main(void)
                TENms=0;
                s=0;
                m=0;
                BEER=0;
                TMOD=0x01;
          ET0=1;
                EA=1;
                                        display();
                                        switch(P1&0xe0)
                                                case 0xc0:TR0=1;break;
                                                case 0xa0:TR0=0;TR0=0;break;
                                                case 0x60:TR0=0;TENms=0;s=0;m=0;TR0=0;break;
全部功能正常謝謝各位
