查看: 2396|回復(fù): 5
這個(gè)程序想用來顯示0-9,編譯通過了,下載進(jìn)單片機(jī)里沒反應(yīng)
ID:296364 發(fā)表于 2023-7-29 18:12 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
#include <intrins.h>
uchar code shud[10][8]={  {0x00,0x3e,0x41,0x41,0x41,0x3e,0x00,0x00}, //0
                                                {0x00,0x00,0x42,0x7F,0x40,0x00,0x00,0x00}, //1
                                                {0x00,0x72,0x51,0x51,0x49,0x46,0x00,0x00}, //2
                                                {0x00,0x22,0x49,0x49,0x49,0x36,0x00,0x00}, //3
                                                {0x00,0x18,0x14,0x12,0x7F,0x10,0x00,0x00}, //4
                                                {0x00,0x27,0x49,0x49,0x49,0x39,0x00,0x00}, //5
                                                {0x00,0x3E,0x49,0x49,0x49,0x3A,0x00,0x00}, //6
                                                {0x00,0x01,0x01,0x01,0x7D,0x03,0x00,0x00}, //7
                                                {0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00}, //8
                                                {0x00,0x26,0x49,0x49,0x49,0x3E,0x00,0x00} //9
//uchar code shuw[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
uchar i=0;
uchar a=0x7f;
uint j=0;
uchar k=0;
void delay(uint z);
                P1=shud[k][i];
                P2=a;
                a=_cror_(a,1);
                 delay(1);
                //P2=0xff;
                 i++;
                 if(i>=8)i=0;
                 k++;
                 if(k>=10)k=0;
                 j++;
                   if(j>200)
                     a=_cror_(a,1);
                         j=0;
ID:332444 發(fā)表于 2023-7-30 13:00 | 顯示全部樓層
點(diǎn)陣看我帖子有荔枝
ID:161164 發(fā)表于 2023-7-31 10:43 | 顯示全部樓層
代碼不全
delay()函數(shù)只由宣告,沒有實(shí)體
ID:123289 發(fā)表于 2023-7-31 16:44 | 顯示全部樓層
自己走單步調(diào)試。
ID:748096 發(fā)表于 2023-8-13 08:27 來自觸屏版 | 顯示全部樓層
亂七八糟
ID:647261 發(fā)表于 2023-8-14 09:32 | 顯示全部樓層
先了解一下for循環(huán),這樣太亂了
邏輯也不通,k和i同時(shí)增加,就算程序跑起來了,也不能正常顯示
你試試這樣:
uchar k,i;
for(k=0;k<10;k++)
    for(i=0;i<8;i++)
         P1=shud[k][i];
至于那個(gè)j>200是干嘛的,我沒看懂,不知道該怎么編了哈,你自己再想想
