查看: 1128|回復: 0
單片機直流電機調速的程序
ID:1089019 發表于 2023-7-19 19:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <REGX52.H>
#include "Delay.h"
#include "Key.h"
#include "Nixie.h"
#include "Timer0.h"
sbit Motor=P1^0;
unsigned char Counter,Compare;        //計數值和比較值,用于輸出PWM
unsigned char KeyNum,Speed;
        Timer0_Init();
                KeyNum=Key();
                if(KeyNum==1)
                        Speed++;
                        Speed%=4;
                        if(Speed==0){Compare=0;}        //設置比較值,改變PWM占空比
                        if(Speed==1){Compare=50;}
                        if(Speed==2){Compare=75;}
                        if(Speed==3){Compare=100;}
                Nixie(1,Speed);
void Timer0_Routine() interrupt 1
        TL0 = 0x9C;                //設置定時初值
        TH0 = 0xFF;                //設置定時初值
        Counter++;
        Counter%=100;        //計數值變化范圍限制在0~99
        if(Counter<Compare)        //計數值小于比較值
                Motor=1;                //輸出1
        else                                //計數值大于比較值
                Motor=0;                //輸出0
