查看: 2051|回復: 0
STM32單片機MAX31865 rs485通信協議源程序
ID:1085364 發表于 2023-7-16 11:16 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
stm32-rs485通信協議源碼
MAX31865接線順序:
clk--PA5
SDO--PA6
SDI--PA7
CS--PA4
RDY--PB6
  1. #include "max31865.h"
  2. void MAX31865_Init()
  3. {
  4.         MAX31865_SB_Write(0x80,0xC1);//四線配置
  5.   HAL_Delay(10);
  6. }
  7. /*輸出電阻值
  8. #include "stm32f10x.h"
  9. #include <stdio.h>
  10. uint16_t temps;
  11. int main()
  12. {
  13.     //獲取轉換的電阻值
  14.     temps=(temps*402.0f)/32768.0f;
  15.     //輸出結果
  16.     printf("temp: %f C\r\n ", temps);
  17.     while(1) {
  18.         //其他操作
  19.     }
  20. }
  21. */
  22. #define RTD_A 3.9083e-3
  23. #define RTD_B -5.775e-7
  24.   float Z1, Z2, Z3, Z4, Rt, temp;
  25. float Get_tempture(void)//PT100
  26. {
  27.   float temps;
  28.   uint16_t data_r;
  29.   data_r = MAX31865_SB_Read(0x01) << 8;
  30.         data_r |= MAX31865_SB_Read(0x02);
  31.         data_r >>= 1;
  32.   temps=data_r;
  33.   temps=(temps*430.0f)/32768.0f;//獲得轉換的電阻值
  34.         //return  temps;
  35.   Rt=temps;
  36.         Z1 = -RTD_A;
  37.   Z2 = RTD_A * RTD_A - (4 * RTD_B);
  38.   Z3 = (4 * RTD_B) / 100;
  39.   Z4 = 2 * RTD_B;
  40.   temp = Z2 + (Z3 * Rt);
  41.   temp = (sqrt(temp) + Z1) / Z4;
  42.   if (temp >= 0)
  43.     return temp;
  44.   // ugh.
  45.   Rt /= 100;
  46.   Rt *= 100; // normalize to 100 ohm
  47.   float rpoly = Rt;
  48.   temp = -242.02;
  49.   temp += 2.2228 * rpoly;
  50.   rpoly *= Rt; // square
  51.   temp += 2.5859e-3 * rpoly;
  52.   rpoly *= Rt; // ^3
  53.   temp -= 4.8260e-6 * rpoly;
  54.   rpoly *= Rt; // ^4
  55.   temp -= 2.8183e-8 * rpoly;
  56.   rpoly *= Rt; // ^5
  57.   temp += 1.5243e-10 * rpoly;
  58.
  59.   //temps=(temps-100.0f)/0.385055f;
  60.   return temp;
  61. }
  62. uint8_t MAX31865_SB_Read(uint8_t addr)//SPI Single-Byte Read
  63. {
  64.   uint8_t read;
  65.         MAX31685_CS_LOW();
  66.         HAL_SPI_Transmit(&hspi1, &addr, 1, 60);
  67.         HAL_SPI_Receive(&hspi1, &read, 1, 60);
  68.         MAX31685_CS_HIGH();
  69.   return read;
  70. }
  71. void MAX31865_SB_Write(uint8_t addr,uint8_t wdata)//SPI Single-Byte Write
  72. {
  73.         uint8_t dat[2];
  74.         dat[0] = addr;
  75.         dat[1] = wdata;
  76.         MAX31685_CS_LOW();
  77.         HAL_SPI_Transmit(&hspi1,dat,2,60);
  78.         MAX31685_CS_HIGH();
  79. }
原理圖:無
仿真:無
Keil代碼下載: max31865程序.7z (6.38 MB, 下載次數: 26)
