制作出來的實物圖如下:
2023-7-14 22:08 上傳
#include "stm32f10x.h"
#include "delay.h"
#include "usart.h"
#include "smg.h"
uint8_t RecBuff[5] = {0, 0, 0, 0, 0};//定義5個數(shù)據(jù)組個綬沖讀取串口數(shù)據(jù),所有數(shù)組數(shù)據(jù)初始化為0
int a=9;
int b=6;
int main(void)
OLED_Init();
uart_init(115200);
SMG_Init();
RecBuff[0]=a;
RecBuff[1]=b;
// SMG_Display(1341);
LED8_Display(3,1);
LED8_Display(2,2);
LED8_Display(1,RecBuff[1]);
LED8_Display(0,RecBuff[0]);
// LED8_Display(3,18);
// LED8_Display(2,18);
// LED8_Display(1,18);
// LED8_Display(0,18);
//delay_ms(1000);
- #include "smg.h"
- #include "delay.h"
- u8 SMG_Code[] =
- // 0 1 2 3 4 5 6 7 8 9 A b C d E F - Bleak White Spot
- 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E, 0xBF, 0xFF, 0x00, 0x7F
- };//段碼
- void SMG_Init()
- GPIO_InitTypeDef GPIO_InitStructure;//定義結(jié)構(gòu)體變量
- RCC_APB2PeriphClockCmd(SMG_PORT_RCC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = SMG_PIN; //要設(shè)置的IO口
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //普通輸出模式
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;; //50MHz
- GPIO_Init(SMG_PORT, &GPIO_InitStructure); /* 初始化GPIO */
- GPIO_ResetBits(SMG_PORT, SMG_PIN); //將數(shù)碼管端口拉高
- u8 LED_table[19]={
- //共陽數(shù)碼管段碼“0123456789AbCdEF熄滅-”
- // 0 1 2 3 4 5 6 7 8 9 10(A) 11(B) 12(C) 13(D) 14(E) 15(F) 16(熄滅)17(-) 18(.)
- 0xC0, 0xF9, 0xA4, 0xB0 ,0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E, 0xFF, 0xBF, 0x7F };
- // 0. 1. 2. 3. 4. 5. 6. 7. 8. 9.
- // 0x40, 0x79, 0x24, 0x30 ,0x19, 0x12, 0x02, 0x78, 0x00, 0x10;
- u8 wei_table[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
- //第一位至第八位位碼
- //數(shù)碼動態(tài)顯示函數(shù)LED8_Display(),有形參x和y,無返回值
- //x表示位選擇,y表示欲顯示的數(shù)碼
- void LED8_Display(u8 x,u8 y)
- LED_OUT(LED_table[y]);//送出段碼
- LED_OUT(wei_table[x]);//送出位碼
- SMG_RCLK=0;
- SMG_RCLK=1;//RCLK產(chǎn)生上升沿A4
- delay_ms(2);
- //單字節(jié)數(shù)據(jù)串行移位函數(shù)LED_OUT(),有形參outdata用于傳入實際數(shù)據(jù)
- //無返回值
- void LED_OUT(u8 outdata)
- u8 i;
- for(i=0;i<8;i++)//循環(huán)8次
- if (outdata & 0x80)//逐一取出最高位 1000 0000 b
- SMG_DIO=1;//送出“1”
- else
- SMG_DIO=0;//送出“0”
- outdata<<=1;//執(zhí)行左移一位操作
- SMG_SCLK=0;
- SMG_SCLK=1;//SCLK產(chǎn)生上升沿
- void SMG_Output(u8 data)
- u8 i;
- for (i = 0; i < 8; i++)
- if (data & 0x80)//按位與,先發(fā)送高位
- SMG_DIO = 1;
- else
- SMG_DIO = 0;
- data <<= 1;
- SMG_SCLK = 0;
- SMG_SCLK = 1; //產(chǎn)生一個上升沿
- void SMG_Display(int num)
- u8 digit[DIGIT_NUM], i, j;
- //將傳入的數(shù)字轉(zhuǎn)換為數(shù)組的元素
- for (i = 1; i <= DIGIT_NUM; i++)
- digit[DIGIT_NUM - i] = num % 10;
- num /= 10;
- for (j = i = 1; i <= DIGIT_NUM; i++, j *= 2)
- SMG_Output(SMG_Code[digit[DIGIT_NUM - i]]); //發(fā)送顯示數(shù)據(jù)
- SMG_Output(j); //發(fā)送顯示位數(shù)
- SMG_RCLK = 0;
- SMG_RCLK = 1; //產(chǎn)生一個上升沿
- delay_ms(2); //保持一定時間,否則數(shù)碼管亮度較低
- //int main()
- // int Clock_MHz;
- // float prev_roll;
- // /*定義一個RCC_ClocksTypeDef類型的結(jié)構(gòu)體*/
- // RCC_ClocksTypeDef RCC_Clock;
- // /*調(diào)用RCC_GetClocksFreq獲取系統(tǒng)時鐘狀態(tài)*/
- // RCC_GetClocksFreq(&RCC_Clock);
- // Clock_MHz = RCC_Clock.SYSCLK_Frequency / 1000 / 1000;
- // uart1_init(460800);
- // delay_init(Clock_MHz);
- // SMG_Init();
- // while (1)
- // SMG_Display(2021);
Keil代碼下載:
程序.7z
(197.46 KB, 下載次數(shù): 37)
2023-7-15 19:44 上傳
下載積分: 黑幣 -5
