查看: 1584|回復: 0
基于python pyqt5設計Error: setupUi() missing 1 required positional argument: ...
ID:622678 發表于 2023-6-26 20:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
請大佬幫忙看看哪里有問題,應該怎么改,本人初學。
C:\Users\Administrator\AppData\Local\Programs\Python\Python37\python.exe "D:/Program Files/JetBrains/PyCharm Community Edition 2020.2.4/jbr/bin/pythonProject3/main.py"Traceback (most recent call last):  File "D:/Program Files/JetBrains/PyCharm Community Edition 2020.2.4/jbr/bin/pythonProject3/main.py", line 76, in <module>    My_PortUi.setupUi()Type Error: setupUi() missing 1 required positional argument: 'name'
# import serial
import datetime
# from easygui import *
from msilib import Dialog
import serial.tools.list_ports
#from goto import with_goto
import time
from PyQt5 import QtCore, QtGui, QtWidgets
class Ui_name(object):
    def setupUi(self, name):
        name.setObjectName("name")
        name.resize(301, 167)
        self.pushButton = QtWidgets.QPushButton(name)
        self.pushButton.setGeometry(QtCore.QRect(190, 20, 75, 23))
        self.pushButton.setObjectName("pushButton")
        self.pushButton_2 = QtWidgets.QPushButton(name)
        self.pushButton_2.setGeometry(QtCore.QRect(190, 60, 75, 23))
        self.pushButton_2.setObjectName("pushButton_2")
        self.radioButton = QtWidgets.QRadioButton(name)
        self.radioButton.setGeometry(QtCore.QRect(20, 90, 61, 31))
        self.radioButton.setObjectName("radioButton")
        self.radioButton_2 = QtWidgets.QRadioButton(name)
        self.radioButton_2.setGeometry(QtCore.QRect(80, 90, 61, 31))
        self.radioButton_2.setObjectName("radioButton_2")
        self.comboBox = QtWidgets.QComboBox(name)
        self.comboBox.setGeometry(QtCore.QRect(70, 20, 69, 22))
        self.comboBox.setObjectName("comboBox")
        self.comboBox.addItem("")
        self.comboBox_2 = QtWidgets.QComboBox(name)
        self.comboBox_2.setGeometry(QtCore.QRect(70, 60, 69, 22))
        self.comboBox_2.setObjectName("comboBox_2")
        self.comboBox_2.addItem("")
        self.label = QtWidgets.QLabel(name)
        self.label.setGeometry(QtCore.QRect(20, 20, 54, 12))
        self.label.setObjectName("label")
        self.label_2 = QtWidgets.QLabel(name)
        self.label_2.setGeometry(QtCore.QRect(20, 60, 54, 12))
        self.label_2.setObjectName("label_2")
        self.label_3 = QtWidgets.QLabel(name)
        self.label_3.setGeometry(QtCore.QRect(20, 140, 81, 16))
        self.label_3.setObjectName("label_3")
        self.lineEdit = QtWidgets.QLineEdit(name)
        self.lineEdit.setGeometry(QtCore.QRect(100, 140, 113, 20))
        self.lineEdit.setObjectName("lineEdit")
        self.retranslateUi(name)
        QtCore.QMetaObject.connectSlotsByName(name)
        name.setTabOrder(self.comboBox, self.pushButton)
        name.setTabOrder(self.pushButton, self.comboBox_2)
        name.setTabOrder(self.comboBox_2, self.pushButton_2)
        name.setTabOrder(self.pushButton_2, self.radioButton)
        name.setTabOrder(self.radioButton, self.radioButton_2)
        name.setTabOrder(self.radioButton_2, self.lineEdit)
    def retranslateUi(self, name):
        _translate = QtCore.QCoreApplication.translate
        name.setWindowTitle(_translate("name", "Dialog"))
        self.pushButton.setText(_translate("name", "連接"))
        self.pushButton_2.setText(_translate("name", "斷開"))
        self.radioButton.setText(_translate("name", "HEX"))
        self.radioButton_2.setText(_translate("name", "文本"))
        self.comboBox.setItemText(0, _translate("name", "com1"))
        self.comboBox.setItemText(1, _translate("name", "com2"))
        self.comboBox_2.setItemText(0, _translate("name", "9600"))
        self.comboBox_2.setItemText(1, _translate("name", "115200"))
        self.label.setText(_translate("name", "端口號"))
        self.label_2.setText(_translate("name", "波特率"))
        self.label_3.setText(_translate("name", "數據保存地址"))
if __name__ == '__main__':
    My_PortUi = Ui_name()
    My_PortUi.setupUi()
    My_PortUi.retranslateUi()
    while True:
        while True:
            port_list = list(serial.tools.list_ports.comports())
            if len(port_list) <= 0:
                print("請插入串口!")
            else:
                for i in list(port_list):
                    print(i)
                break
        while True:
            inport = input("請輸入端口號,并按回車:")
            inbot  = input("請設置波特率,并按回車:")
            try:
                uart_serial = serial.Serial(inport,inbot)
                if uart_serial.isOpen():
                    print('連接成功!\n')
                    break
            except serial.SerialException:
                print('串口打開失敗!請重新確認端口號并重連\n')
                while True:
                        print("請插入串口!")
                    else:
                            print(i)
                        break
        while True:
            try:
                #while True:
                data = uart_serial.readline()
                print(data)
                fw = open('./test.txt','a')
                fw.write(str(datetime.datetime.now())+'  ')
                fw.writelines(data.hex())
                fw.write('\r\n')
                fw.close()
            except:
                #if serial != None:
                uart_serial.close()
                    #fw.close()
                print('串口斷開!請重連\n')
                input("請重插串口,并按回車:")
                time.sleep(3)
                break
