查看: 1690|回復: 1
基于STM32F103移植Grbl
ID:772183 發表于 2023-6-21 09:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Configuration        YSF1_Pro
STM32CubeMX         4.14.0
Date        08/29/2016
MCU        STM32F103ZETx
PERIPHERALS        MODES        FUNCTIONS        PINS
RCC        Crystal/Ceramic Resonator        RCC_OSC_IN        OSC_IN
RCC        Crystal/Ceramic Resonator        RCC_OSC_OUT        OSC_OUT
SYS        SysTick        SYS_VS_Systick        VP_SYS_VS_Systick
USART1        Asynchronous        USART1_RX        PA10
USART1        Asynchronous        USART1_TX        PA9
Pin Nb        PINs        FUNCTIONs        LABELs
7        PC13-TAMPER-RTC        GPIO_Input
23        OSC_IN        RCC_OSC_IN
24        OSC_OUT        RCC_OSC_OUT
34        PA0-WKUP        GPIO_Input
46        PB0        GPIO_Output
91        PG6        GPIO_Output
92        PG7        GPIO_Output
101        PA9        USART1_TX
102        PA10        USART1_RX
SOFTWARE PROJECT
Project Settings :
Project Name : YSF1_Pro
Project Folder : C:\Users\Administrator\Desktop\YSF1_HAL_FreeRTOS-002. 串口調試方法(打印任務執行情況)
Toolchain / IDE : MDK-ARM V5
Firmware Package Name and Version : STM32Cube FW_F1 V1.3.1
Code Generation Settings :
STM32Cube Firmware Library Package : Copy all used libraries into the project folder
Generate peripheral initialization as a pair of '.c/.h' files per IP : Yes
Backup previously generated files when re-generating : No
Delete previously generated files when not re-generated : Yes
Set all free pins as analog (to optimize the power consumption) : No
Toolchains Settings :
Compiler Optimizations : Balanced Size/Speed
ID:1085839 發表于 2023-6-26 06:56 | 只看該作者
看不懂
