先上圖
2023-6-21 01:15 上傳
移植全動電子,軟件SPI刷屏速度慢
- #include "tft9341.h" // Device header
- //管理LCD重要參數(shù)
- //默認為豎屏
- _lcd_dev lcddev;
- //畫筆顏色,背景顏色
- u16 POINT_COLOR = 0x0000,BACK_COLOR = 0xFFFF;
- u16 DeviceCode;
- void SPIv_WriteData(u8 Data)
- unsigned char i=0;
- for(i=8;i>0;i--)
- if(Data&0x80)
- SPI_MOSI_SET; //輸出數(shù)據(jù)
- else SPI_MOSI_CLR;
- SPI_SCLK_CLR;
- SPI_SCLK_SET;
- Data<<=1;
- * @name :void LCD_WR_REG(u8 data)
- * @date :2018-08-09
- * @function :Write an 8-bit command to the LCD screen
- * @parameters :data:Command value to be written
- * @retvalue :None
- void LCD_WR_REG(u8 data)
- LCD_CS_CLR;
- LCD_RS_CLR;
- SPIv_WriteData(data);
- LCD_CS_SET;
- * @name :void LCD_WR_DATA(u8 data)
- * @function :Write an 8-bit data to the LCD screen
- * @parameters :data:data value to be written
- * @retvalue :None
- void LCD_WR_DATA(u8 data)
- LCD_CS_CLR;
- LCD_RS_SET;
- LCD_CS_SET;
- * @name :void LCD_WriteReg(u8 LCD_Reg, u16 LCD_RegValue)
- * @function :Write data into registers
- * @parameters :LCD_Reg:Register address
- LCD_RegValue:Data to be written
- * @retvalue :None
- void LCD_WriteReg(u8 LCD_Reg, u16 LCD_RegValue)
- LCD_WR_REG(LCD_Reg);
- LCD_WR_DATA(LCD_RegValue);
- * @name :void LCD_WriteRAM_Prepare(void)
- * @function :Write GRAM
- * @parameters :None
- * @retvalue :None
- void LCD_WriteRAM_Prepare(void)
- LCD_WR_REG(lcddev.wramcmd);
- * @name :void Lcd_WriteData_16Bit(u16 Data)
- * @function :Write an 16-bit command to the LCD screen
- * @parameters :Data:Data to be written
- * @retvalue :None
- void Lcd_WriteData_16Bit(u16 Data)
- LCD_CS_CLR;
- LCD_RS_SET;
- SPIv_WriteData(Data>>8);
- SPIv_WriteData(Data);
- LCD_CS_SET;
- * @name :void LCD_DrawPoint(u16 x,u16 y)
- * @function :Write a pixel data at a specified location
- * @parameters :x:the x coordinate of the pixel
- y:the y coordinate of the pixel
- * @retvalue :None
- void LCD_DrawPoint(u16 x,u16 y)
- LCD_SetCursor(x,y);//設(shè)置光標位置
- Lcd_WriteData_16Bit(POINT_COLOR);
- * @name :void LCD_Clear(u16 Color)
- * @function :Full screen filled LCD screen
- * @parameters :color:Filled color
- * @retvalue :None
- void LCD_Clear(u16 Color)
- unsigned int i,m;
- LCD_SetWindows(0,0,lcddev.width-1,lcddev.height-1);
- LCD_CS_CLR;
- LCD_RS_SET;
- for(i=0;i<lcddev.height;i++)
- for(m=0;m<lcddev.width;m++)
- Lcd_WriteData_16Bit(Color);
- LCD_CS_SET;
- * @name :void LCD_GPIOInit(void)
- * @function :Initialization LCD screen GPIO
- * @retvalue :None
- void LCD_GPIOInit(void)
- __HAL_RCC_GPIOA_CLK_ENABLE();
- * @name :void LCD_RESET(void)
- * @function :Reset LCD screen
- * @retvalue :None
- void LCD_RESET(void)
- LCD_RST_CLR;
- HAL_Delay(100);
- LCD_RST_SET;
- HAL_Delay(50);
- * @name :void LCD_Init(void)
- * @retvalue :None
- void LCD_Init(void)
- LCD_GPIOInit();//LCD GPIO初始化
- LCD_RESET(); //LCD 復位
- //*************2.2inch ILI9341初始化**********//
- LCD_WR_REG(0xCF);
- LCD_WR_DATA(0x00);
- LCD_WR_DATA(0xD9); //C1
- LCD_WR_DATA(0X30);
- LCD_WR_REG(0xED);
- LCD_WR_DATA(0x64);
- LCD_WR_DATA(0x03);
- LCD_WR_DATA(0X12);
- LCD_WR_DATA(0X81);
- LCD_WR_REG(0xE8);
- LCD_WR_DATA(0x85);
- LCD_WR_DATA(0x10);
- LCD_WR_DATA(0x7A);
- LCD_WR_REG(0xCB);
- LCD_WR_DATA(0x39);
- LCD_WR_DATA(0x2C);
- LCD_WR_DATA(0x34);
- LCD_WR_DATA(0x02);
- LCD_WR_REG(0xF7);
- LCD_WR_DATA(0x20);
- LCD_WR_REG(0xEA);
- LCD_WR_REG(0xC0); //Power control
- LCD_WR_DATA(0x21); //VRH[5:0] //1B
- LCD_WR_REG(0xC1); //Power control
- LCD_WR_DATA(0x12); //SAP[2:0];BT[3:0] //01
- LCD_WR_REG(0xC5); //VCM control
- LCD_WR_DATA(0x39); //3F
- LCD_WR_DATA(0x37); //3C
- LCD_WR_REG(0xC7); //VCM control2
- LCD_WR_DATA(0XAB); //B0
- LCD_WR_REG(0x36); // Memory Access Control
- LCD_WR_DATA(0x48);
- LCD_WR_REG(0x3A);
- LCD_WR_DATA(0x55);
- LCD_WR_REG(0xB1);
- LCD_WR_DATA(0x1B); //1A
- LCD_WR_REG(0xB6); // Display Function Control
- LCD_WR_DATA(0x0A);
- LCD_WR_DATA(0xA2);
- LCD_WR_REG(0xF2); // 3Gamma Function Disable
- LCD_WR_REG(0x26); //Gamma curve selected
- LCD_WR_DATA(0x01);
- LCD_WR_REG(0xE0); //Set Gamma
- LCD_WR_DATA(0x0F);
- LCD_WR_DATA(0x23);
- LCD_WR_DATA(0x1F);
- LCD_WR_DATA(0x0B);
- LCD_WR_DATA(0x0E);
- LCD_WR_DATA(0x08);
- LCD_WR_DATA(0x4B);
- LCD_WR_DATA(0XA8);
- LCD_WR_DATA(0x3B);
- LCD_WR_DATA(0x14);
- LCD_WR_DATA(0x06);
- LCD_WR_DATA(0x09);
- LCD_WR_REG(0XE1); //Set Gamma
- LCD_WR_DATA(0x1C);
- LCD_WR_DATA(0x04);
- LCD_WR_DATA(0x47);
- LCD_WR_DATA(0x44);
- LCD_WR_DATA(0x05);
- LCD_WR_DATA(0x2F);
- LCD_WR_DATA(0x36);
- LCD_WR_REG(0x2B);
- LCD_WR_DATA(0x3f);
- LCD_WR_REG(0x2A);
- LCD_WR_DATA(0xef);
- LCD_WR_REG(0x11); //Exit Sleep
- HAL_Delay(120);
- LCD_WR_REG(0x29); //display on
- LCD_direction(USE_HORIZONTAL);//設(shè)置LCD顯示方向
- //LCD_LED=1;//點亮背光
- LCD_Clear(WHITE);//清全屏白色
- * @name :void LCD_SetWindows(u16 xStar, u16 yStar,u16 xEnd,u16 yEnd)
- * @function :Setting LCD display window
- * @parameters :xStar:the bebinning x coordinate of the LCD display window
- yStar:the bebinning y coordinate of the LCD display window
- xEnd:the endning x coordinate of the LCD display window
- yEnd:the endning y coordinate of the LCD display window
- * @retvalue :None
- void LCD_SetWindows(u16 xStar, u16 yStar,u16 xEnd,u16 yEnd)
- LCD_WR_REG(lcddev.setxcmd);
- LCD_WR_DATA(xStar>>8);
- LCD_WR_DATA(0x00FF&xStar);
- LCD_WR_DATA(xEnd>>8);
- LCD_WR_DATA(0x00FF&xEnd);
- LCD_WR_REG(lcddev.setycmd);
- LCD_WR_DATA(yStar>>8);
- LCD_WR_DATA(0x00FF&yStar);
- LCD_WR_DATA(yEnd>>8);
- LCD_WR_DATA(0x00FF&yEnd);
- LCD_WriteRAM_Prepare(); //開始寫入GRAM
- * @name :void LCD_SetCursor(u16 Xpos, u16 Ypos)
- * @function :Set coordinate value
- * @parameters :Xpos:the x coordinate of the pixel
- Ypos:the y coordinate of the pixel
- * @retvalue :None
- void LCD_SetCursor(u16 Xpos, u16 Ypos)
- LCD_SetWindows(Xpos,Ypos,Xpos,Ypos);
- * @name :void LCD_direction(u8 direction)
- * @function :Setting the display direction of LCD screen
- * @parameters :direction:0-0 degree
- 1-90 degree
- 2-180 degree
- 3-270 degree
- * @retvalue :None
- void LCD_direction(u8 direction)
- lcddev.setxcmd=0x2A;
- lcddev.setycmd=0x2B;
- lcddev.wramcmd=0x2C;
- switch(direction){
- case 0:
- lcddev.width=LCD_W;
- lcddev.height=LCD_H;
- LCD_WriteReg(0x36,(1<<3)|(0<<6)|(0<<7));//BGR==1,MY==0,MX==0,MV==0
- break;
- case 1:
- lcddev.width=LCD_H;
- lcddev.height=LCD_W;
- LCD_WriteReg(0x36,(1<<3)|(0<<7)|(1<<6)|(1<<5));//BGR==1,MY==1,MX==0,MV==1
- break;
- case 2:
- LCD_WriteReg(0x36,(1<<3)|(1<<6)|(1<<7));//BGR==1,MY==0,MX==0,MV==0
- break;
- case 3:
- LCD_WriteReg(0x36,(1<<3)|(1<<7)|(1<<5));//BGR==1,MY==1,MX==0,MV==1
- break;
- default:break;
2023-6-21 01:15 上傳
由于程序太大 無法上傳,所以只上傳了核心屏幕驅(qū)動(上圖8個文件),大家可以自習移植:
HARDWARE.7z
(24.31 KB, 下載次數(shù): 20)
2023-6-21 01:13 上傳
下載積分: 黑幣 -5
