■在藍(lán)橋杯單片機(jī)綜合訓(xùn)練平臺上,利用定時(shí)器T0、數(shù)碼管模塊和2個(gè)獨(dú)立按鍵(J5的2-3短接),設(shè)計(jì)一個(gè)秒表,具有清零、暫停、啟動(dòng)功能。
1.顯示格式為:分-秒.0.05秒(即50ms)08-26-18表示: 8分26秒900毫秒
2.獨(dú)立按鍵S4為:暫停/啟動(dòng)
獨(dú)立按鍵S5為:清零
按鍵均為按下有效。
已完成仿真與調(diào)試。
2023-6-16 14:49 上傳
單片機(jī)源程序如下:
- #include "reg52.h"
- sbit HC138_A = P2^5;
- sbit HC138_B = P2^6;
- sbit HC138_C = P2^7;
- sbit S5 = P3^2;
- sbit S4 = P3^3;
- //共陽4位數(shù)碼管的段碼數(shù)組
- unsigned char code SMG_NoDot[18] =
- {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
- 0x80,0x90,0x88,0x80,0xc6,0xc0,0x86,0x8e,
- 0xbf,0x7f};
- char minute=0;
- char second=0;
- char ms=0;
- void DisplaySMG_Dynamic();
- void Delay(unsigned int time);
- void DelaySMG(unsigned int time)
- while(time--);
- while(time--);
- void Init74HC138(unsigned char n)
- switch(n)
- case 4:
- HC138_A = 0;
- HC138_B = 0;
- HC138_C = 1;
- break;
- case 5:
- HC138_A = 1;
- HC138_B = 0;
- HC138_C = 1;
- break;
- case 6:
- HC138_A = 0;
- HC138_B = 1;
- HC138_C = 1;
- break;
- case 7:
- HC138_A = 1;
- HC138_B = 1;
- HC138_C = 1;
- break;
- case 8:
- HC138_A = 0;
- HC138_B = 0;
- HC138_C = 0;
- break;
- void DispaySMG_Bit(unsigned char value, unsigned char pos)
- Init74HC138(7);
- P0 = 0xff;
- Init74HC138(6);
- P0 = (0x01 << pos);
- Init74HC138(7);
- P0 = value;
- DispaySMG_Bit(SMG_NoDot[minute/10],0);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[minute%10],1);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[16],2);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[second/10],3);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[second%10],4);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[16],5);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[ms/10],6);
- DelaySMG(30);
- DispaySMG_Bit(SMG_NoDot[ms%10],7);
- DelaySMG(30);
- void InitTimer0()
- TMOD = 0X01;
- TH0=(65535-50000)/256;
- TL0=(65535-50000)%256;
- ET0=1;
- EA=1;
- TR0=1;
- void ServiceTimer0() interrupt 1
- ms++;
- if(ms ==20)
- second++;
- ms=0;
- if(second==60)
- minute++;
- second=0;
- if(minute==60)
- minute=0;
- void ScanKeys()
- if(S5 == 0)
- Delay(100);
- if(S5 == 0)
- minute=0;
- second=0;
- ms=0;
- while(S5 ==0)
- DisplaySMG_Dynamic();
- if(S4 == 0)
- Delay(100);
- if(S4 == 0)
- TR0=~TR0;
- while(S4 ==0)
- main()
- InitTimer0();
- while(1)
- ScanKeys();
2023-6-16 15:05 上傳
Keil代碼與Proteus7.5版本的仿真dsn文件下載(其他版本打開會出錯(cuò)):
11 定時(shí)器進(jìn)階-數(shù)字鐘(更新后).7z
(320.89 KB, 下載次數(shù): 13)
2023-6-16 14:50 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
