就是想實(shí)現(xiàn)電腦發(fā)數(shù)據(jù)然后單片機(jī)數(shù)碼管上面顯示相應(yīng)的數(shù)字。遇到瓶頸了。單片機(jī)是STC12C5204AD
U16~U19是LS145 芯片。這個(gè)是我敲的代碼但是運(yùn)行結(jié)果不對(duì),不懂是不是寫(xiě)錯(cuò)了。
附帶原理圖請(qǐng)大神們指教。
#include<reg51.h>
#include "intrins.h"
#define uchar unsignedchar
unsigned char senddata;
unsigned char seg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x00};
void delayms(unsigned int k);
void Deng();
void Smg();
void Nixie(unsigned char L,N)
switch(L)
case 1:P3=0x08;break;
case 2:P3=0x0c;break;
case 3:P3=0x10;break;
case 4:P3=0x14;break;
case 5:P3=0x20;break;
case 6:P3=0x24;break;
case 7:P3=0x28;break;
case 8:P3=0x2c;break;
case 9:P3=0x30;break;
case 10:P3=0x34;break;
case 11:P3=0x38;break;
case 12:P3=0x3c;break;
P1=seg[N];
P2=seg[N];
delayms(1);
P1=0x00;
P2=0x00;
void Deng() //燈
P1=0X00;
P2=0X00;
P3=0x30;
delayms(1);
P1=0X00;
P3=0x34;
delayms(1);
P1=0X00;
P2=0X00;
P3=0x38;
delayms(1);
P3=0x3c;
P1=0x00;
delayms(1);
void Smg() //數(shù)碼管
Nixie(1,1);
delayms(1);
Nixie(2,2);
delayms(1);
Nixie(3,3);
delayms(1);
Nixie(4,4);
delayms(1);
Nixie(5,5);
delayms(1);
Nixie(6,6);
delayms(1);
Nixie(7,7);
delayms(1);
Nixie(8,8);
delayms(1);
void InitializeSystem() //串口初始化,波特率9600
SCON = 0X50;//串口方式1,允許接收
TMOD = 0X20;//定時(shí)器1定時(shí)方式2
TCON = 0x40;//設(shè)定時(shí)器1開(kāi)始計(jì)數(shù)
TH1 = TL1 = 250;
PCON = 0x80; //波特率加倍控制,SMOD位
RI = 0; //清收發(fā)標(biāo)志
TI = 0;
TR1 = 1; //啟動(dòng)定時(shí)器
EA=1; //開(kāi)啟總中斷
ES = 1;
ET1=0;
//字符發(fā)送函數(shù)
void putchar(unsigned char data1)
SBUF = data1; //將待發(fā)送的字符送入發(fā)送緩沖器
while(TI == 0); //等待發(fā)送完成
TI = 0; //發(fā)送中斷標(biāo)志請(qǐng)0
//字符串發(fā)送函數(shù)
void putstring(unsigned char *dat)
while(*dat != '\0') //判斷字符串是否發(fā)送完畢
putchar(*dat); //發(fā)送單個(gè)字符
dat++; //字符地址加1,指向先下一個(gè)字符
delayms(1);
//接收中斷函數(shù)
void revdata(void) interrupt 4
if(RI == 0) return; //如果沒(méi)有接收中斷標(biāo)志,返回
ES = 0; //關(guān)閉串口中斷
RI = 0; //清串行中斷標(biāo)志位
senddata=SBUF;
ES = 1; //開(kāi)啟串口中斷
void main(void)
InitializeSystem( );
if(senddata=='1')
Nixie(1,1);
unsigned char data i, j;
while(k--)
i = 22;
j = 128;
do
while (--j);
} while (--i);
