只需一步,快速開(kāi)始
查看: 2503|回復(fù): 7
單片機(jī)倒計(jì)時(shí)程序 求指導(dǎo)
1. 倒計(jì)時(shí)秒表
    系統(tǒng)接1個(gè)按鍵用于啟動(dòng),1個(gè)蜂鳴器用于提示計(jì)時(shí)時(shí)間到,兩個(gè)數(shù)碼管用于顯示時(shí)間。
    功能:系統(tǒng)上電數(shù)碼管顯示60;當(dāng)按鍵按下時(shí),系統(tǒng)開(kāi)始倒計(jì)時(shí),同時(shí)數(shù)碼管顯示當(dāng)前時(shí)間;當(dāng)計(jì)時(shí)為0時(shí),蜂鳴器響。
如果用中斷函數(shù)具體該怎么弄呢?
ID:789121 發(fā)表于 2023-6-13 16:30 | 只看該作者
畫(huà)電路圖了么?主要使用定時(shí)器中斷計(jì)時(shí)和外中斷相應(yīng)按鍵
ID:161164 發(fā)表于 2023-6-13 22:21 | 只看該作者
本帖最后由 lkc8210 于 2023-6-14 09:46 編輯
  1. #include "reg51.h"
  2. typedef unsigned char u8;
  3. typedef unsigned int u16;
  4. //-----------------------------------------------
  5. /* define constants */
  6. #define FOSC 11059200L
  7. #define T1MS (65536-FOSC/12/1000)   //1ms timer calculation method in 12T mode
  8. /* define SFR */
  9. sbit TEST_LED = P1^0;               //work LED, flash once per second
  10. /* define variables */
  11. u16 count;                         //1000 times counter
  12. //-----------------------------------------------
  13. /* Timer0 interrupt routine */
  14. void tm0_isr() interrupt 1
  15. {
  16.     TL0 = T1MS;                     //reload timer0 low u8
  17.     TH0 = T1MS >> 8;                //reload timer0 high u8
  18.     if (count-- == 0)               //1ms * 1000 -> 1s
  19.     {
  20.         count = 1000;               //reset counter
  21.         TEST_LED = ! TEST_LED;      //work LED flash
  22.     }
  23. }
  24. //-----------------------------------------------
  25. /* main program */
  26. void main()
  27. {
  28.     TMOD = 0x01;                    //set timer0 as mode1 (16-bit)
  29.     TL0 = T1MS;                     //initial timer0 low u8
  30.     TH0 = T1MS >> 8;                //initial timer0 high u8
  31.     TR0 = 1;                        //timer0 start running
  32.     ET0 = 1;                        //enable timer0 interrupt
  33.     EA = 1;                         //open global interrupt switch
  34.     count = 0;                      //initial counter
  35.     while (1);                      //loop
  36. }
ID:116103 發(fā)表于 2023-6-14 05:43 | 只看該作者
按鍵后,TR0=1,啟動(dòng)定時(shí)器,在中斷中每一秒送減初值,到0時(shí),在中斷中TR0=0, 蜂鳴=1.
ID:332444 發(fā)表于 2023-6-14 14:31 | 只看該作者
首先寫(xiě)好數(shù)碼管驅(qū)動(dòng),設(shè)置定時(shí)器時(shí)間,其他都好辦,無(wú)論是正計(jì)時(shí)還是倒計(jì)時(shí)都一樣一個(gè)算法而已
ID:332444 發(fā)表于 2023-6-14 22:59 | 只看該作者
學(xué)習(xí)單片機(jī)首先就要學(xué)好寫(xiě)顯示驅(qū)動(dòng):數(shù)碼管/LCD/點(diǎn)陣的驅(qū)動(dòng),這是人機(jī)交互的窗口,顯示寫(xiě)好后其它都借助顯示都容易了。
ID:332444 發(fā)表于 2023-6-15 09:06 | 只看該作者
像這種沒(méi)有電路圖的提問(wèn)只能講個(gè)大概而已,須知道硬件和軟件結(jié)合的單片機(jī)必須是硬件和代碼嚴(yán)格對(duì)應(yīng)的,否則都是空談。
ID:77589 發(fā)表于 2023-6-16 15:55 | 只看該作者
這個(gè)應(yīng)該不難,看看資料就會(huì)了!!
