查看: 2344|回復(fù): 1
基于51單片機的溫度電壓電流檢測系統(tǒng)程序+仿真
ID:316613 發(fā)表于 2023-5-4 08:46 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
具有l(wèi)cd1602顯示功能, AD轉(zhuǎn)換功能,模擬電路運放部分,送入mcu
#include <reg51.h>
#include <stdio.h>
#include<intrins.h>
/*****************************程序引腳定義***********************************************/
/*定義LCD控制信號線*/
sbit SCL = P2^5;
sbit SDA = P2^6;
/*定義AD采集IC信號線*/
sbit ADE=P2^7;            //輸出使能
sbit ADEOC=P3^7;        //轉(zhuǎn)換完畢信號輸出1
sbit ADST=P3^6;            //AD復(fù)位及開始信號
sbit ADSCK=P3^5;        //時鐘信號輸入
sbit ADA=P2^2;
sbit ADB=P2^1;
sbit ADC=P2^0;
sbit DQ=P2^3;//定義DS18B20接口
#define KEYValueShowEN 0
bit ack;
unsigned char LCD_data=0x08;
/*dat用于存儲AD采集回來的數(shù)字變量,范圍為0-255*/
unsigned int dat;
/***********************************************************************函數(shù)聲明*****************************************/
/*LCD驅(qū)動函數(shù)名聲明*/
void LCD_Init(void);         //初始化函數(shù),設(shè)置LCD的顯示模式
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data);              //寫入字符函數(shù)
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s);              //寫入字符串函數(shù)
void LCD_Clear(void);        //清屏函數(shù)
void LCD_Write_Data(unsigned char Data);                                                 //寫入數(shù)據(jù)函數(shù)
void LCD_Write_Com(unsigned char com);                                                  //     寫入命令函數(shù)
void LCD_PrintChar(unsigned char ucIdxX, unsigned char ucIdxY, unsigned char cData);  //向LCD中寫入一個Char型數(shù)據(jù)
void LED_PrintValueI(unsigned char x, unsigned char y, int Data);                      //向LCD寫入一個整形數(shù)據(jù)
void LED_PrintValueF(short int x, unsigned short int y, float ddata, unsigned short int num);//向LCD中寫入一個浮點型數(shù)據(jù)
/*延時函數(shù)聲明*/
void DelayUs2x(unsigned char t);
void DelayMs(unsigned char t);
/*AD采樣函數(shù)聲明*/
void ADinit();                                //定時器和AD初始化
void ADdress(unsigned char add);            //八路模擬輸入選擇(0~7)add最大值為7
unsigned int readad(unsigned char add);                //AD轉(zhuǎn)換函數(shù)
/***********************************************************************函數(shù)實現(xiàn)*****************************************/
//*****************延時************************
void delay_nus(unsigned int n) //N us延時函數(shù)
    unsigned int i=0;
        for (i=0;i<n;i++)
            _nop_();
void delay_nms(unsigned int n) //N ms延時函數(shù)
    unsigned int i,j;
        for (i=0;i<n;i++)
            for (j=0;j<1140;j++);
uS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
unsigned char 是定義無符號字符變量,其值的范圍是
0~255 這里使用晶振12M,精確延時請使用匯編,大致延時
長度如下 T=tx2+5 uS
while(--t);
mS延時函數(shù),含有輸入?yún)?shù) unsigned char t,無返回值
while(t--)
     //大致延時1mS
     DelayUs2x(245);
     DelayUs2x(245);
//MS延時函數(shù)(12M晶振下測試)
void Delay_ms(unsigned int n)
    unsigned int  i,j;
    for(i=0;i<n;i++)
        for(j=0;j<123;j++);
void nop4()
     _nop_();     //等待一個機器周期
     _nop_();     //等待一個機器周期
     _nop_();     //等待一個機器周期
     _nop_();     //等待一個機器周期
void Start()
     SDA=1;
    _nop_();
    SCL=1;
    nop4();
    SDA=0;
    nop4();
    SCL=0;
    _nop_();
    _nop_();
void Stop()
     SDA=0;
    _nop_();
    SCL=0;
    nop4();//>4us后SCL跳變
    SCL=1;
    nop4();
    SDA=1;
    _nop_();
    _nop_();
void  Write_A_Byte(unsigned char c)
unsigned char BitCnt;
  for(BitCnt=0;BitCnt<8;BitCnt++)  //要傳送的數(shù)據(jù)長度為8位
     if((c<<BitCnt)&0x80)  SDA=1;   //判斷發(fā)送位
     else  SDA=0;
     _nop_();
     SCL=1;               //置時鐘線為高,通知被控器開始接收數(shù)據(jù)位
     nop4();
     _nop_();
     SCL=0;
    _nop_();
    _nop_();
    SDA=1;               //8位發(fā)送完后釋放數(shù)據(jù)線,準備接收應(yīng)答位
    _nop_();
    _nop_();
    SCL=1;
    _nop_();
    _nop_();
    _nop_();
    if(SDA==1)ack=0;
       ack=1;        //判斷是否接收到應(yīng)答信號
      // P1=0x00;
    SCL=0;
    _nop_();
    _nop_();
bit Write_Random_Address_Byte(unsigned char add,unsigned char dat)
     Start();    //啟動總線
    Write_A_Byte(add<<1|0); //發(fā)送器件地址
    if(ack==0)return(0);
    Write_A_Byte(dat);   //發(fā)送數(shù)據(jù)
    Stop(); //結(jié)束總線
    return(1);
//********************液晶屏使能*********************
void Enable_LCD_write()
    LCD_data|=(1<<(3-1));//E=1;
    Write_Random_Address_Byte(0x27,LCD_data);  //
    delay_nus(2);
    LCD_data&=~(1<<(3-1));//E=0;
//*************寫命令****************************
void LCD_write_command(unsigned char command)
    delay_nus(16);
    LCD_data&=~(1<<(1-1));//RS=0;
    LCD_data&=~(1<<(2-1));//RW=0;
    //LCD_data&=~(1<<(4-1));
    LCD_data&=0X0f; //清高四位
    LCD_data|=command & 0xf0; //寫高四位
    Enable_LCD_write();
    command=command<<4; //低四位移到高四位
    LCD_data&=0x0f; //清高四位
    LCD_data|=command&0xf0; //寫低四位
    Enable_LCD_write();
//*************寫數(shù)據(jù)****************************
void LCD_write_data(unsigned char value)
    delay_nus(16);
    LCD_data|=(1<<(1-1));//RS=1;
    LCD_data|=value&0xf0; //寫高四位
    Enable_LCD_write();
    value=value<<4; //低四位移到高四位
    LCD_data|=value&0xf0; //寫低四位
    Enable_LCD_write();
//**********************設(shè)置顯示位置*********************************
void set_position(unsigned char x,unsigned char y)
    unsigned char position;
    if (y == 0)
        position = 0x80 + x;
        position = 0xc0 + x;
    LCD_write_command(position);
*函數(shù)名:  void LCD_Clear(void)
*參數(shù):無
*功能說明:清屏函數(shù)
     LCD_write_command(0x01);
     DelayMs(5);
運行效果
運行效果
ID:1074184 發(fā)表于 2023-6-7 15:02 來自觸屏版 | 只看該作者
有工程文件嗎,兄弟
