查看: 1539|回復: 0
stm32單片機流水燈代碼
ID:1073139 發表于 2023-4-21 11:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
代碼:
#include "stm32f10x.h"
#include "bsp_led.h"
#include "bsp_key.h"
void Tim3_Int_Init(u16 arr,u16 psc);
void TIM3_IRQHandler(void);
int x = 1;
int mode = 0;
int change = 0;
int y = 1;
  * @brief  主函數
  * @param  無
  * @retval 無
int main(void)
    /* LED 端口初始化 */
    LED_GPIO_Config();
    while (1)
        if (mode==1 && change==0)
            Tim3_Int_Init(4999, 7199);
            change = 1;
        else if (mode==2 && change==0)
            Tim3_Int_Init(7199, 9999);
            change = 1;
        TIM3_IRQHandler();
        if( Key_Scan(KEY2_GPIO_PORT,KEY2_GPIO_PIN) == KEY_ON )
            mode += 1;
            change = 0;
            if (mode >= 5)
                mode = 1;
        if( Key_Scan(KEY1_GPIO_PORT,KEY1_GPIO_PIN) == KEY_ON )
            y += 1;
            LED1_ON;
    TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;//配置定時器時鐘
    NVIC_InitTypeDef NVIC_InitStruct;//配置中斷控制器
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);//使能定時器時鐘
    TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;//設置時鐘分割
    TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;//設置為向上計數模式
    TIM_TimeBaseInitStruct.TIM_Period = arr;//設置在下一個更新時間裝入活動的自動重裝載寄存器周期的值
    TIM_TimeBaseInitStruct.TIM_Prescaler = psc;//預分頻值
    TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStruct);//初始化
    TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);//使能TIM3中斷,允許更新中斷
    NVIC_InitStruct.NVIC_IRQChannel = TIM3_IRQn;
    NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
    NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStruct.NVIC_IRQChannelSubPriority = 3;
    NVIC_Init(&NVIC_InitStruct);//NVIC
    TIM_Cmd(TIM3,ENABLE);//使能TIM3
    if(TIM_GetITStatus(TIM3,TIM_IT_Update) == 1)//檢查TIM3更新中斷發生與否
        TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//清除TIMx更新中斷標志
        x += 1;
        switch(mode)
            case 1:
                if (x==1)
                    LED3_OFF;
                    LED1_ON;
                else if (x==2)
                    LED1_OFF;
                    LED2_ON;
                else if (x==3)
                    LED2_OFF;
                    LED3_ON;
                    x = 0;
                break;
            case 2:
                if (x==1)
                    LED2_OFF;
                    LED3_OFF;
                    LED1_ON;
                else if (x==2)
                    LED2_ON;
                    LED3_ON;
                    x = 0;
                break;
            case 3:
                if (y==1)
                    LED3_OFF;
                    LED1_ON;
                else if (y==2)
                    LED1_OFF;
                    LED2_ON;
                else if (y==3)
                    LED2_OFF;
                    LED3_ON;
                    y = 1;
                break;
            default:
                break;
