查看: 1705|回復(fù): 0
51單片機AD電壓采集仿真程序 PCF8591模擬量采集 用8*8點陣翻頁顯示
ID:928899 發(fā)表于 2023-4-17 16:48 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
包含程序及仿真,pcf8951驅(qū)動程序,不僅可以檢測電壓,還能檢測光照強度以及溫度,很適合小白
  1.
  2. #include <reg52.h>
  3. #include <I2C.H>
  5. #define uint unsigned int
  6. #define  PCF8591 0x90    //PCF8591 地址
  7. unsigned char code tab[]={0xfe,0xfd,0xfb,0xf7,
  8. 0xef,0xdf,0xbf,0x7f};
  9. unsigned char code graph[11][8]={
  10. {0x0,0x18,0x24,0x24,0x24,0x24,0x24,0x18},//0
  11. {0x0,0x8,0x18,0x8,0x8,0x8,0x8,0x8},//1
  12. {0x0,0x18,0x24,0x24,0x8,0x10,0x20,0x3C},//2
  13. {0x0,0x18,0x24,0x4,0x8,0x24,0x24,0x18},//3
  14. {0x0,0x8,0x8,0x18,0x28,0x3C,0x8,0x8},//4
  15. {0x0,0x3C,0x20,0x38,0x4,0x4,0x24,0x18},//5
  16. {0x0,0x18,0x24,0x20,0x38,0x24,0x24,0x18},//6
  17. {0x0,0x3C,0x24,0x4,0x8,0x10,0x10,0x10},//7
  18. {0x0,0x18,0x24,0x24,0x18,0x24,0x24,0x18},//8
  19. {0x0,0x18,0x24,0x24,0x1C,0x4,0x24,0x18},//9
  20. {0x4C,0xD2,0x52,0x52,0x52,0x52,0x52,0xEC},//10
  21. };
  22. unsigned char count;
  23. unsigned char cnta;
  24. unsigned char AD_CHANNEL;
  25. unsigned int  D[4];
  26. void delay11(unsigned int cnt)
  27. {
  28. while(--cnt);
  29. }
  30.
  31. /*******************************************************************
  32. ADC發(fā)送字節(jié)[命令]數(shù)據(jù)函數(shù)
  33. *******************************************************************/
  34. bit ISendByte(unsigned char sla,unsigned char c)
  35. {
  36.    Start_I2c();              //啟動總線
  37.    SendByte(sla);            //發(fā)送器件地址
  38.    if(ack==0)return(0);
  39.    SendByte(c);              //發(fā)送數(shù)據(jù)
  40.    if(ack==0)return(0);
  41.    Stop_I2c();               //結(jié)束總線
  42.    return(1);
  43. }
  44. /*******************************************************************
  45. ADC讀字節(jié)數(shù)據(jù)函數(shù)
  46. *******************************************************************/
  47. unsigned char IRcvByte(unsigned char sla)
  48. {  unsigned char c;
  49.    Start_I2c();          //啟動總線
  50.    SendByte(sla+1);      //發(fā)送器件地址
  51.    if(ack==0)return(0);
  52.    c=RcvByte();          //讀取數(shù)據(jù)0
  53.    Ack_I2c(1);           //發(fā)送非就答位
  54.    Stop_I2c();           //結(jié)束總線
  55.    return(c);
  56. }
  57. //******************************************************************/
  58. main()
  59. { unsigned char jj,kk,ll,bb,cc,dd;
  60. double Data; //
  61. double V;         //轉(zhuǎn)化成的電壓值
  62. while(1)
  63. {
  64.          ISendByte(PCF8591,0x40);
  65.          Data=IRcvByte(PCF8591);  //ADC0 模數(shù)轉(zhuǎn)換1
  66.                  V=Data*5/256;
  67.                  D[0]=V*100;
  68.         for(bb=0;bb<10;bb++){
  69.                 for(jj=0;jj<8;jj++)   //共要掃描八行
  70.                 {
  71.                 P1=graph[D[0]/100][jj];   //送字模數(shù)據(jù)
  72.                         P2=tab[jj];
  73.                     delay11(200);   //選中第一行
  74.                         P2=0xff;
  75.                         delay11(500);
  76.               }
  77.            delay11(500);}
  78.                     for(bb=0;bb<10;bb++){
  79.                 for(jj=0;jj<8;jj++)   //共要掃描八行
  80.                 {
  81.                 P1=0x06;
  82.                         P2=0x7f;
  83.                         delay11(500);
  84.                         P2=0xbf;
  85.                         delay11(500);
  86.               }
  87.            delay11(500);}
  88.                  for(cc=0;cc<10;cc++){
  89.                 for(kk=0;kk<8;kk++)   //共要掃描八行
  90.                 {
  91.                 P1=graph[D[0]%100/10][kk];   //送字模數(shù)據(jù)
  92.                         P2=tab[kk];
  93.                     delay11(200);   //選中第一行
  94.                         P2=0xff;
  95.                         delay11(500);
  96.               }
  97.            delay11(500);}
  98.                 for(dd=0;dd<10;dd++)
  99.                 {
  100.                  for(ll=0;ll<8;ll++)   //共要掃描八行
  101.                 {
  102.                 P1=graph[D[0]%10][ll];   //送字模數(shù)據(jù)
  103.                         P2=tab[ll];
  104.                     delay11(200);   //選中第一行
  105.                         P2=0xff;
  106.                         delay11(500);
  107.               }
  108.            delay11(500);}
  109.
  110.    }
  111. }
注意現(xiàn)在用的8*8一次只能顯示一個字符 所以需要翻頁顯示 不太直觀  大家可以改為數(shù)碼管或者 多點陣顯示
Keil代碼與Proteus8.13仿真下載:
仿真程序.7z (79.42 KB, 下載次數(shù): 23)
參與人數(shù) 1黑幣 +50 收起 理由
