查看: 7519|回復: 4
急求幫助,一段關于電子血壓計的程序
ID:56123 發表于 2013-10-30 19:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 zzzyz 于 2013-10-30 19:48 編輯
這是一段仿真電子血壓計的程序,但是仿真和程序都沒有報錯,但是數碼管卻顯示不出數據來,急求幫助
#include <reg52.h>
#include <absacc.h>
#define  DAC_1    XBYTE[0x2000]
#define  DAC_2    XBYTE[0x4000]
#define  ADC_0    XBYTE[0x6000]
#define  ADC_1    XBYTE[0x6001]
#define  ADC_2    XBYTE[0x6002]
#define  ADC_3    XBYTE[0x6003]
#define  ADC_4    XBYTE[0x6004]
#define  ADC_5    XBYTE[0x6005]
#define  ADC_6    XBYTE[0x6006]
#define  ADC_7    XBYTE[0x6007]
unsigned char        dspbuf[4]={0xef,0xef,0xef,0xef},sel=0,key_sta=0,key_num;
unsigned int         adcount=0;
sbit D_SER= P1^0;
sbit D_SRCLK= P1^1;
sbit D_RCLK= P1^2;
sbit KEY1= P3^4;
sbit KEY2= P3^5;//定時器初始化:
void init_timer0(void)
  TMOD =0X22;         //定時器0以方式2(自動重新裝載8位計數器)自動計數
  TL0 = 0X06;
  TH0 = 0X06;                 //至初始值為6,每0.25ms進入一次中斷
  TL1 = 0Xe8;
  TH1 = 0Xe8;
  TR0 = 1;
  TR1 = 1;
  ET0 = 1;
//中斷設置:
void init_special_interrupts(void)
  EX0 = 0;
  ET0 = 1;
  EX1 = 0;
  ET1 = 0;
  ES  = 1;
  EA  = 1;
  PT0 = 0;
  PX1 = 1;
PS  = 0;
SCON=0x50;   //串行口方式1工作
//數碼管顯示:
void dsptask()
  unsigned char i;
  unsigned char a,b;
  switch(sel)
   case 0: a=0x01;  break;
   case 1: a=0x02;  break;
   case 2: a=0x04;  break;
   default: a=0x08;
for(b=0x80,i=0;i<8;i++)
    if(a&b)  D_SER=1;
    else     D_SER=0;
    D_SRCLK=0;
    D_SRCLK=1;
    D_SRCLK=0;
    b=b>>1; b=b&0x7f;
  a=dspbuf[sel];
  key_num=sel;
  sel++;
  if(sel>=4) sel=0;
    if(a&b)  D_SER=1;
    else     D_SER=0;
    D_SRCLK=0;
    D_SRCLK=1;
    D_SRCLK=0;
    b=b>>1;  b=b&0x7fff;
  D_RCLK=0;
  D_RCLK=1;
  D_RCLK=0;
//鍵盤掃描:                        //鍵盤值為1~8
void key_service()
  if(key_sta&0x01) return;             // key_sta.0=1
   if(KEY2)
    key_num=key_num+1;
key_sta=key_sta|0x01;              // 置key_sta.0=1
   else if(KEY1)
       key_num=key_num+5;
  }//定時器0中斷處理:
void timer_isr() interrupt 1  {
  EA=0;
  adcount++;                        //計數,便于放氣速度設置
  key_service();                      //鍵盤掃描
  EA=1;
//掃描字顯示轉化:
fdisp(unsigned char n,unsigned char m)      //將需要顯示的數轉化成相應的顯示碼
  char  c;
   switch(n)
    case 0:  c=0x11;  break;
    case 1:  c=0x7d;  break;
    case 2:  c=0x23;  break;
    case 3:  c=0x29;  break;
    case 4:  c=0x4d;  break;
    case 5:  c=0x89;  break;
    case 6:  c=0x81;  break;
    case 7:  c=0x3d;  break;
    case 8:  c=0x01;  break;
    default: c=0x09;
   dspbuf[m]=c;
//主函數:
void main(void)
float max=0,min=0,minus=0,mmax=0,om=0;
int os=0,od=0,os0=0,os1=0,os2=0,od0=0,od1=0,od2=0;
unsigned char t,i,flag=0,high=0,hhigh=0,ave=0;
init_timer0();                  //初始化定時器0
init_special_interrupts();      //設置中斷
for(i=0;i<4;i++){fdisp(0,i);}
dsptask();
for(;;)
  if(key_num==1)                      //開始放氣
   key_sta=key_sta&0xfe;           // 置key_sta.0=0
   t=ADC_0;
   if(t>max) max=t;
   else if(t<min) min=t;
   if(adcount>199)
    adcount=0;
    DAC_1=0xf0;             //由D/A輸出來控制放氣速度
    if(min!=0&&max!=0)  {minus=max-min;if(minus>mmax) {mmax=minus;ave=min;}}
  }                                 //求出振蕩波峰峰值最大時平均壓對應的電壓值
  else if(key_num==2)                 //停止放氣,求出所需數值并顯示
   if(adcount>199) adcount=0;
   max=0;
   min=0;
   minus=0;
   om=ave/(28*3.5*0.133);      //常數28為放大倍數,根據硬件的實際情況可有所調整
   os=om*0.8;
   od=om*0.5;                  //根據固定比率法求出收縮壓和舒張壓,單位為mmHg
   if(os>140||od>90) high=1;
   if(os>160||od>100){high=0;hhigh=1;} //收縮壓大于160mmHg為超高血壓,大于120mmHg為高血壓
   os2=os/100;
   os=os%100;
   os1=os/10;
   os0=os%10;
   od2=od/100;
   od=od%100;
   od1=od/10;
   od0=os%10;
   do{
    if(flag=0&&adcount>199)      //顯示收縮壓
     adcount=0;
     flag=1;
     fdisp(os0,0);
     fdisp(os1,1);
     fdisp(os2,2);
     fdisp(0,3);
     dsptask();
    else if(flag=1&&adcount>199)
     adcount=0;
     flag=0;
     fdisp(od0,0);
     fdisp(od1,1);
     fdisp(od2,2);
     fdisp(0,3);
     dsptask();                   //顯示舒張壓
     if(adcount>199!=key_num!=3)
      if(high==1)
       fdisp(1,0);
       fdisp(0,1);
       fdisp(0,2);
       fdisp(0,3);
       dsptask();
      }                   //顯示高血壓——1
      else if(hhigh==1)
       fdisp(2,0);
       fdisp(0,1);
       fdisp(0,2);
       fdisp(0,3);
       dsptask();
      }                     //顯示超高血壓——2
       for(i=0;i<4;i++) fdisp(0,i);
       dsptask();
      }                     //顯示血壓正常——0
   }while(key_num!=3);
  else if(key_num==3)                       //復位
   dsptask();
   high=0;
   hhigh=0;
   os=0,od=0,os0=os1=os2=0,od0=od1=od2=0;
   flag=0;
  else key_sta=key_sta&0xfe;           // 置key_sta.0=0;
參與人數 1黑幣 +5 收起 理由
初心不忘~! + 5 贊一個!
收藏收藏1 分享淘帖 頂1 踩
ID:110225 發表于 2016-4-13 16:32 | 只看該作者
硬件怎么弄求助
ID:374948 發表于 2019-9-11 15:48 | 只看該作者
程序是不是有問題啊,min最小值,你怎么得來的
ID:438476 發表于 2020-4-6 00:17 | 只看該作者
請問下問題解決了嗎?
ID:570093 發表于 2020-4-8 13:32 | 只看該作者
請問下問題解決了嗎?順便可以分享下電路圖不?
