查看: 1737|回復: 3
STM32f407單片機半傳輸中斷,問題求助
ID:285416 發表于 2023-3-26 20:24 | 顯示全部樓層 |閱讀模式
#include "main.h"
  u8 DmaBuffere[2][RHEOSTAT_NOFCHANEL]={0};
extern u8 flag[2],Bufbj;
void My_DMA_Init(void)
        NVIC_InitTypeDef NVIC_InitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
/* Enable ADC3, DMA and GPIO clocks ****************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
        NVIC_InitStructure.NVIC_IRQChannel= DMA2_Stream0_IRQn;//TIM2_IRQn;  //
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
/* DMA2 Stream0 channel2 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)RHEOSTAT_ADC1_DR_ADDR;
  DMA_InitStructure.DMA_Memory0BaseAddr = (u32)DmaBuffere[0];//數組名表示首地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = RHEOSTAT_NOFCHANEL*2;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_ClearITPendingBit(DMA2_Stream0,DMA_IT_TCIF0);//DMA_IT_HTIF0
        DMA_ClearITPendingBit(DMA2_Stream0,DMA_IT_HTIF0);
DMA_ITConfig(DMA2_Stream0,DMA_IT_TC, ENABLE);
  DMA_ITConfig(DMA2_Stream0, DMA_IT_HT, ENABLE);
        DMA_Cmd(DMA2_Stream0, ENABLE);
//DMA_PeripheralDataSize_HalfWord++DMA_PeripheralDataSize_Byte
void DMA2_Stream0_IRQHandler(void)         // 使用DMA中斷采集數據,不會容易丟失數據
   if (DMA2->LISR&0x20)
                        DMA2->LIFCR|=0x20;
                        flag[0]=1;
                   if (DMA2->HISR&0x10)
                        DMA2->HIFCR|=0x10;
                                flag[1]=1;
哪里不對了,半進不了
ID:405850 發表于 2023-3-27 08:54 | 顯示全部樓層
ADC + DMA不用配置中斷優先級吧? DataSize也沒見設置呢?還有adc的配置呢
ID:285416 發表于 2023-3-27 16:52 來自觸屏版 | 顯示全部樓層
DataSize  是指什么沒明白  adc配置不用看了呢  全斷是對的
ID:285416 發表于 2023-3-27 16:55 來自觸屏版 | 顯示全部樓層
半斷就不對  斷不了 debug調  寄存一直0
