SOC.h
- #ifndef _SOC_H
- #define _SOC_H
- #define MAX_SOC 100 //1%/位 0~100%
- #define MIN_SOC 0 //最小SOC
- #define ADJUSTCAP_OCV 1
- #define ADJUSTCAP_CHARGE 2
- //范圍0~999AH 3596400AS
- typedef struct
- unsigned long ulAs; //1AH = 1*3600As
- unsigned long ulWh; //電量 0.1Wh/bit
- unsigned char ucSOC; //剩余電量 1%/位
- }TSOCPARA;
- extern TSOCPARA g_SOCPara;
- typedef struct
- signed long g_slChaAms; //充電累計(jì)容量
- unsigned char ucOriSOC; //充電起始SOC
- }TCHAAHPARA;
- extern TCHAAHPARA g_tChaAhPara;
- extern volatile unsigned char CalSOCTimesOut;
- extern volatile signed long g_slAms; //JACK
- void WriteAs(void);
- void ReadSoc( void ); //從EEPROM讀取SOC
- void WriteDefaultSoc( void ); //寫(xiě)默認(rèn)SOCEEPROM
- void WriteSoc( unsigned short usSoc ); //寫(xiě)SOC到EEPROM
- unsigned char CalAdjustCap( unsigned char ucSelect);
- #endif
SOC.c
- #include "TypeDefine.h"
- #include "SOC.h"
- #include "FM31256.H"
- //安時(shí)*毫秒
- //long型 最大596ah
- //限制 500ah*3600*1000 = 1800000000Ams //1A*1ms
- #define MAX_LIMIT_AMS 0x6B49D200 //1800000000Ams
- TSOCPARA g_SOCPara;
- //進(jìn)行容量保存判斷標(biāo)準(zhǔn) 相差值大小
- unsigned char g_ucSOC_Back = 0;//
- volatile unsigned char CalSOCTimesOut;
- volatile signed long g_slAS = 0;//當(dāng)前容量
- volatile signed long g_slAms =0; //JACK
- //SOC累計(jì)標(biāo)準(zhǔn) 初始狀態(tài)上累計(jì) 對(duì)應(yīng)g_slAms 變量
- signed long g_slInitAS = 0;//初始容量
- static unsigned char g_ucCalAdjustFlag = 0;
- TCHAAHPARA g_tChaAhPara;
- unsigned long diff(unsigned long w1,unsigned long w2)
- if(w1>w2)
- return(w1-w2);
- else
- return(w2-w1);
- const unsigned int g_cuiOCVTable[ 5 ]={0,0,0,0,0};
- const unsigned int g_cuiOCVSOCTable[ 5 ]={0,0,0,0,0};
- /* lookUp1d
- * Performs simple linear interpolation of a 2D map.
- * Outputs are bounded by the upper and lower values
- * Both axis are expected to be increasing in value
- * as the index increases
- * Return = -1 for error and 1 for success
- * Params = int *ans > an address to put the result
- * int x > the x value to lookup
- * const int *xAxis > array of value for x axis
- * const int lenX > length of x axis array
- * int y > the y value to lookup
- * const int *yAxis > array of value for y axis
- * const int lenY > length of y axis array
- int lookUp1d(int *ans,
- int x, const int *xAxis, const int lenX,
- const int *tab)
- int ret = -1; /* -1 is the error return value */
- int ix=0;
- /* make sure the lengths are good */
- if ( (lenX <=0 ) ||
- (xAxis == NULL) ||
- (tab == NULL) ||
- (ans == NULL) )
- /* this has bad input data */
- else
- /* make sure it is in the boundaries before we do any looping*/
- if (x<=xAxis[0])
- x = xAxis[0];
- else
- if (x>=xAxis[lenX-1])
- x = xAxis[lenX-1];
- for (ix=0;ix<(lenX-1);ix++)
- if (x>=xAxis[ix] && x<=xAxis[ix+1])
- int x1,x2;
- int z1,z2;
- /* copy to a lot of temp variables to make code easier to read*/
- x1=xAxis[ix];
- x2=xAxis[ix+1];
- z1=tab[ix];
- z2=tab[(ix+1)];
- /* then interpolate in the y direction for the answer */
- *ans = z1+((z2-z1)*(x-x1))/(x2-x1);
- /* indicate a valid result */
- ret = 1;
- break; /* exit as fast as possible */
- return ret;
- //返回: -1 for error and 1 for success
- //參數(shù):填充結(jié)果, OCV值
- int OCV_SOC( int *resSOC, unsigned int uiVolt)
- int res = 0;
- res = lookUp1d(resSOC,uiVolt,g_cuiOCVTable,5,g_cuiOCVSOCTable);
- return res;
- //兩種方法修正實(shí)際可用容量( 不考慮老化 )
- int res1 = 0, res2 = 0;
- unsigned char ucMaxSOC = 0, ucMinSOC = 0 ;
- unsigned long ulTemp1 = 0,ulTemp2 = 0;
- res1 = OCV_SOC( &ucMaxSOC, ECU_Rt.maxv );
- res2 = OCV_SOC( &ucMinSOC, ECU_Rt.minv );
- if( ( 1 == res1) && ( 1 == res2))
- if( ADJUSTCAP_OCV == ucSelect)
- //OCV 法 EV HEV
- //OCVmax => SOCmax OCVmin => SOCmin
- //Cpack=SOCmin*Crate + ( 1 - SOCmax) * Crate = 60 + 30 = 90Ah
- ulTemp1 = Sys_Rt.Type_Cap;
- ulTemp1 *= ucMinSOC;
- ulTemp2 = Sys_Rt.Type_Cap;
- ulTemp2 *= 100 - ucMaxSOC;
- ulTemp1 += ulTemp2;
- ulTemp1 /= 100;
- Sys_Rt.ADJType_Cap = (UINT16)ulTemp1;
- g_ucCalAdjustFlag = 1;
- else if( ADJUSTCAP_CHARGE == ucSelect)
- //充電法 (EV)
- //OCVmin => SOCmin
- //Cpack=SOCmin*Crate + Ccharged
- ulTemp1 = g_tChaAhPara.ucOriSOC;
- ulTemp1 *= Sys_Rt.Type_Cap;
- ulTemp1 /= 100;
- ulTemp2 = g_tChaAhPara.g_slChaAms;
- ulTemp2 /= 1000;
- ulTemp2 /= 3600;
- else
- return 0;
- return 1;
- else
- return 0;
- void CalSOC( unsigned long ulAs ) //WriteAs(void)調(diào)用
- unsigned long ulTemp = 0;
- unsigned long ulTemp1 = 0;
- unsigned int uiCapType = 0;
- g_SOCPara.ulAs = ulAs;
- ulTemp = g_SOCPara.ulAs;
- ulTemp = ulTemp / 3600; //As => Ah
- if( 1 == g_ucCalAdjustFlag)
- uiCapType = Sys_Rt.ADJType_Cap; //使用校準(zhǔn)后的額定容量
- else
- uiCapType = Sys_Rt.Type_Cap; //使用給定的額定容量
- if( ulTemp < uiCapType) //當(dāng)前容量小于額定容量(額定容量可修正)
- //g_SOCPara.ulWh = ulTemp * g_tVoltDataPackage.ulSumData;//0.1Wh W=U*I*T
- //1Ah => 0.01Ah 分辨率擴(kuò)大100倍
- ulTemp *= 100;
- ulTemp1 = uiCapType;//額定容量擴(kuò)大100倍
- ulTemp1 *= 100;
- //XX% SOC
- ulTemp *= 100;//剩余容量÷額定容量 × 100%100
- ulTemp = ulTemp / ulTemp1; //計(jì)算SOC,剩余電量比例
- g_SOCPara.ucSOC = (unsigned char) ulTemp;
- else
- g_SOCPara.ucSOC = 100;
- ulTemp = Sys_Rt.ADJType_Cap;//校準(zhǔn)后容量
- else
- ulTemp = Sys_Rt.Type_Cap;//使用給定的額定容量
- if( diff(g_ucSOC_Back,g_SOCPara.ucSOC) >= 1 )//SOC 百分比相差 1 SOC有改變才存儲(chǔ)
- g_ucSOC_Back = g_SOCPara.ucSOC;//更新最后記錄的SOC
- //寫(xiě)SOC到FM31256
- (void)WriteMulti31256RAM( FLASH_SOC_ADDR, ( unsigned char *)&g_SOCPara, sizeof( g_SOCPara ) );
- signed char scIncSOC = 0;
- signed long slIncCap = 0;
- unsigned long ulCapTemp = 0;
- unsigned char ucForceSetFlag = 0;
- if(CalSOCTimesOut != 0) return; //1s 定時(shí)處理SOC計(jì)算
- CalSOCTimesOut = 200; //設(shè)定記數(shù)值
- //累加當(dāng)前充放電容量 正負(fù)相加減
- if( g_slAms < 0 )
- ulTemp = (-1) * g_slAms;
- ulTemp /= 1000;//Ams => As
- g_slAS = g_slInitAS;
- g_slAS -= ulTemp;//累計(jì)上電后 放電 容量
- else
- ulTemp = g_slAms;
- g_slAS += ulTemp;//累計(jì)上電 充電 容量
- //計(jì)算 g_slAS 為當(dāng)前容量///////////////////////////////////
- //當(dāng)前容量 < 0
- if( g_slAS < 0 )
- g_slAS = 0;//容量歸零
- //放電 累計(jì)容量 最大限制 = 上電初始容量
- g_slAms = g_slInitAS;
- g_slAms *= 1000;//As => Ams
- g_slAms =(-1) * g_slAms;
- //當(dāng)前容量 > 額定容量
- uiCapType = Sys_Rt.ADJType_Cap;//判斷是否使用校準(zhǔn)后容量
- else
- uiCapType = Sys_Rt.Type_Cap;//
- ulTemp = g_slAS;
- ulTemp /= 3600; //容量轉(zhuǎn)化為Ah
- if( ulTemp >= uiCapType) //當(dāng)前容量大于額定容量(可修正)
- //充電 累計(jì)容量 最大限制 = 額定容量-上電初始容量
- g_slAms = uiCapType;//額定容量
- g_slAms *= 3600;//Ah => As
- g_slAS = g_slAms;//當(dāng)前容量 = 額定容量 中間結(jié)果賦值
- g_slAms -= g_slInitAS;//額定容量-上電初始容量
- if( abs( g_slAms ) > MAX_LIMIT_AMS)
- g_slAms = MAX_LIMIT_AMS;//超界后清零
- /*0 < g_slAS < uiCapType*/
- CalSOC( g_slAS ); //計(jì)算SOC 百分比
- *函數(shù)名: WriteDefaultSoc 設(shè)置SOC百分比 100% *
- *功能描述: 寫(xiě)默認(rèn)SOC *
- *輸入?yún)?shù): 無(wú) *
- *輸出參數(shù): 無(wú) *
- *返回值: 無(wú) *
- unsigned char ucDefaultSoc = MAX_SOC; //SOC放大1倍
- //更新SOC
- g_SOCPara.ucSOC = ucDefaultSoc;
- g_ucSOC_Back = ucDefaultSoc;
- else
- ulTemp = Sys_Rt.Type_Cap;//額定容量
- ulTemp *= g_SOCPara.ucSOC;
- ulTemp /= 100;//剩余AH
- g_SOCPara.ulAs = ulTemp * 3600;//As
- //寫(xiě)默認(rèn)SOC到FM31256
- *函數(shù)名: WriteSOC 設(shè)置SOC百分比 *
- *功能描述: 寫(xiě)SOC *
- *輸入?yún)?shù): usSoc:SOC *
- *返回值: 無(wú) *
- void WriteSoc( unsigned char usSoc )
- if( usSoc > MAX_SOC ) //SOC越界
- usSoc = MAX_SOC;
- //更新SOC
- g_SOCPara.ucSOC = usSoc;
- g_ucSOC_Back = usSoc;
- else
- ulTemp *= 100;//1Ah => 0.01Ah
- g_SOCPara.ulAs = ulTemp * 3600;//0.001As
- g_SOCPara.ulAs /= 100;//0.001As => 1As
- //g_SOCPara.ulWh = ulTemp * g_tVoltDataPackage.ulSumData;//0.001Wh
- //g_SOCPara.ulWh /= 100;//0.001Wh =>0.1Wh
- g_slAS = g_SOCPara.ulAs;//
- g_slInitAS = g_SOCPara.ulAs;
- g_slAms = 0;
- *函數(shù)名: ReadSoc *
- *功能描述: 從EEPROM中讀SOC 設(shè)置標(biāo)稱容量 *
- *返回值: 無(wú) *
- Sys_Rt.Type_Cap = 400;
- //從FM31256讀SOC
- (void)ReadMulti31256RAM( FLASH_SOC_ADDR, ( unsigned char *)&g_SOCPara, sizeof( g_SOCPara ) );
- if( g_SOCPara.ucSOC > MAX_SOC )
- g_SOCPara.ucSOC = MAX_SOC;
- else
