查看: 1894|回復: 0
STM32單片機+OV7670+顏色識別程序
ID:903925 發表于 2023-3-1 20:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include "sys.h"
  2. #include "usart.h"
  3. #include "delay.h"
  4. #include "led.h"
  5. #include "usmart.h"
  6. #include "lcd.h"
  7. #include "hsl.h"
  8. #include "ov7670.h"
  9. #include "exti.h"
  10. #include "timer.h"
  11. extern u8 ov_sta;        //在exit.c里面定義
  12. extern u8 ov_frame;        //在timer.c里面定義
  13. //
  14. int h,s2,l;
  15. u16 get_date;
  16. COLOR_HSL Hsl1;
  17. #define min3v(v1, v2, v3)   ((v1)>(v2)? ((v2)>(v3)?(v3):(v2)):((v1)>(v3)?(v3):(v1)))//比較最小值
  18. #define max3v(v1, v2, v3)   ((v1)<(v2)? ((v2)<(v3)?(v3):(v2)):((v1)<(v3)?(v3):(v1)))//比較最大值
  19. RESULT Resu;//捕獲顏色設置
  20. //        TARGET_CONDI Condition={60,100,20,120,10,160,40,40,320,240};
  21. //TARGET_CONDI Condition={0,200,0,34,20,30,40,40,320,240};
  22. //unsigned char i;
  23. //static volatile ErrorStatus HSEStartUpStatus = SUCCESS;
  24. int find_x,find_y;
  25. //unsigned int position=0;
  26. //typedef struct
  27. //        {
  28. //    int  x;      // [0,320]
  29. //                int  y;       // [0,240]
  30. //  }
  31. //ZUOBIAO;//HSL格式顏色
  32. //ZUOBIAO zuobiao_for_top;
  33. //ZUOBIAO zuobiao_for_down;
  34. //ZUOBIAO zuobiao_for_left;
  35. //ZUOBIAO zuobiao_for_right;
  36. //ZUOBIAO zuobiao_for_center;
  37. //
  38. //更新LCD顯示
  39. void camera_refresh(void)
  40. {
  41.         u32 j;
  42.         u16 color;
  43.         if(ov_sta==2)
  44.         {
  45.                 LCD_Scan_Dir(U2D_L2R);                //從上到下,從左到右
  46.                 LCD_SetCursor(0x00,0x0000);        //設置光標位置
  47.                 LCD_WriteRAM_Prepare();     //開始寫入GRAM
  48.                 OV7670_CS=0;
  49.                 OV7670_RRST=0;                                //開始復位讀指針
  50.                 OV7670_RCK=0;
  51.                 OV7670_RCK=1;
  52.                 OV7670_RCK=0;
  53.                 OV7670_RRST=1;                                //復位讀指針結束
  54.                 OV7670_RCK=1;
  55.                 for(j=0;j<76800;j++)
  56.                 {
  57.                         GPIOB->CRL=0X88888888;
  58.                         OV7670_RCK=0;
  59.                         color=OV7670_DATA;                //讀數據
  60.                         OV7670_RCK=1;
  61.                         color<<=8;
  62.                         OV7670_RCK=0;
  63.                         color|=OV7670_DATA;                //讀數據
  64.                         OV7670_RCK=1;
  65.                         GPIOB->CRL=0X33333333;
  66.                         LCD_WR_DATA(color);
  67.                 }
  68.                 OV7670_CS=1;
  69.                 OV7670_RCK=0;
  70.                 OV7670_RCK=1;
  71.                 EXTI->PR=1<<15;                     //清除LINE8上的中斷標志位
  72.                 ov_sta=0;                                        //開始下一次采集
  73.                 ov_frame++;
  74.                 LCD_Scan_Dir(DFT_SCAN_DIR);        //恢復默認掃描方向
  75.         }
  76. }
  77. static void readcolor(unsigned int x,unsigned int y,COLOR_RGB *Rgb)
  78. {
  79.         unsigned short C16;
  80.         C16 = LCD_ReadPoint(x,y);
  81.         Rgb->red   =         (unsigned char)((C16&0xf800)>>8);
  82.         Rgb->green =         (unsigned char)((C16&0x07e0)>>3);
  83.         Rgb->blue  =     (unsigned char)((C16&0x001f)<<3);
  84. }
  85. //RGB轉HSL
  86. static void rGBtohSL(const COLOR_RGB *Rgb,COLOR_HSL *Hsl)
  87. {
  88.   int maxVal,minVal,difVal;
  89.         int r  = Rgb->red;
  90.         int g  = Rgb->green;
  91.     int b  = Rgb->blue;
  92.          int h,s2,l;
  93.         maxVal = max3v(r, g, b);
  94.         minVal = min3v(r, g, b);
  95.
  96.         difVal = maxVal-minVal;
  97.
  98.         //計算亮度
  99.     l = (maxVal+minVal)*240/255/2;
  100.
  101.         if(maxVal == minVal)//若r=g=b
  102.         {
  103.                 h = 0;
  104.                 s2 = 0;
  105.         }
  106.         else
  107.         {
  108.                 //計算色調
  109.                 if(maxVal==r)
  110.                 {
  111.                         if(g>=b)
  112.                                 h = 40*(g-b)/(difVal);
  113.                         else
  114.                                 h = 40*(g-b)/(difVal) + 240;
  115.                 }
  116.                 else if(maxVal==g)
  117.                         h = 40*(b-r)/(difVal) + 80;
  118.                 else if(maxVal==b)
  119.                         h = 40*(r-g)/(difVal) + 160;
  120.                 //計算飽和度
  121.                 if(l == 0)
  122.                         s2 = 0;
  123.                 else if(l<=120)
  124.                         s2 = (difVal)*240/(maxVal+minVal);
  125.                 else
  126.                         s2 = (difVal)*240/(511 - (maxVal+minVal));
  127.         }
  128.     Hsl->hue =        (unsigned char)(((h>240)? 240 : ((h<0)?0:h)));
  129.     Hsl->saturation = (unsigned char)(((s2>240)? 240 : ((s2<0)?0:s2)));
  130.     Hsl->luminance =  (unsigned char)(((l>240)? 240 : ((l<0)?0:l)));
  131. }
  132. int main()
  133. {
  134.   COLOR_RGB Rgb;
  135.          int sum_x=0,sum_y=0,i_xy = 0,n_i;
  136.          int X,Y;
  137. //         int led_flg = 0;
  138. //         int pointCnt=0;
  139. //         int val_exp = 500;
  140. //         int position_front_Cnt = 0,position_left_Cnt = 0,position_right_Cnt = 0,position_centre_Cnt = 0;
  141. //         int position_front_exp = val_exp,position_left_exp = val_exp,position_right_exp = val_exp,position_centre_exp = val_exp ,pointCnt_exp = 900;        //靈敏度,,就是有多少紅色(像素塊為單位)可以觸發條件。
  142.         ///pointcnt_exp 需要實際測試,來確定最終值
  143.          delay_init();                     //延時函數初始化
  144.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 設置中斷優先級分組2
  145.         uart_init(9600);
  146.         OV7670_Init();
  147.         LED_Init();                                  //初始化與LED連接的硬件接口
  148.         LCD_Init();                                   //初始化LCD
  149.         if(lcddev.id==0X6804||lcddev.id==0X5310||lcddev.id==0X5510||lcddev.id==0X1963) //強制設置屏幕分辨率為320*240.以支持3.5寸大屏
  150.         {
  151.                 lcddev.width=240;
  152.                 lcddev.height=320;
  153.         }
  154.         usmart_dev.init(72);        //初始化USMART
  155.
  156.         POINT_COLOR=BLACK;//設置字體為紅色
  157.         while(OV7670_Init())//初始化OV7670
  158.         {
  159.                 LCD_ShowString(60,150,200,200,16,"OV7670 Error!!");
  160.                 delay_ms(200);
  161.             LCD_Fill(60,150,239,166,WHITE);
  162.                 delay_ms(200);
  163.         }
  164.         LCD_ShowString(60,150,200,200,16,"camera, okey!");
  165.         TIM3_Int_Init(10000,7199);                        //TIM3,10Khz計數頻率,1秒鐘中斷
  166.         EXTI15_Init();                                                //使能定時器捕獲
  167.         OV7670_Window_Set(10,174,240,320);        //設置窗口
  168.           OV7670_CS=0;
  169.                 uart_init(9600);         //串口初始化為9600
  170.
  171.         while(1)
  172.         {
  173.         for(find_y=0;find_y<320;find_y=find_y +4)//尋找測試點
  174.          {
  175.                 for(find_x=0;find_x<240;find_x=find_x +4)
  176.                         {
  177.                                 get_date=LCD_ReadPoint(find_x,find_y);
  178.                                 readcolor(find_x,find_y,&Rgb);
  179.                                 rGBtohSL(&Rgb,&Hsl1);// 完成了度rgb轉化為色調,亮度,對比度
  180.
  181.                                 if(((Hsl1.hue>=0)&&(Hsl1.hue<=27))&&((Hsl1.saturation>=70)&&\
  182.                 (Hsl1.saturation<=100))&&((Hsl1.luminance>=70)&&(Hsl1.luminance<=150))) //紅色條件
  183. //if(((Hsl1.hue>=220)&&(Hsl1.hue<=240))&&((Hsl1.saturation>=80)&&\
  184.         //        (Hsl1.saturation<=100))&&((Hsl1.luminance>=70)&&(Hsl1.luminance<=150))) //藍色條件
  185. //if(((Hsl1.hue>=50)&&(Hsl1.hue<=70))&&((Hsl1.saturation>=80)&&\
  186.         //        (Hsl1.saturation<=100))&&((Hsl1.luminance>=70)&&(Hsl1.luminance<=150))) //黃色
  187.                         {
  188.                            sum_x = sum_x+find_x ;
  189.                                  sum_y = sum_y+find_y ;
  190.                                  i_xy++;
  191.                         }
  192.          }
  193.         }
  194. //            k++;
  195.             n_i=i_xy;
  196.       X=sum_x /n_i;
  197.       Y=sum_y /n_i;
  198.         // 發送 命令
  199. //if(k==5)                                // 人為降低發送頻率 減少主控緩存壓力
  200. //        {
  201.         if(n_i>=10){
  202.           if(X<80&&X>0)
  203.                    printf ("R");               //右轉
  204.   else if(X>160&&X<=240)
  205.                   printf ("L");         //左轉 l
  206.         else if(X>=80&&X<=160)
  207.                 { if(Y<=120)   printf ("3");  //舵機偏移  2
  208.               else printf ("1");         //前進 1
  209.           }
  210.         }
  211. //                else if printf("L");
  212. //        else if((X==0)&&(Y==0)) printf("R");  //找目標顏色
  213. //         k=1;
  214. // }
  215. //         printf ("(%d,%d,%d,%d,%d)\n",sum_x ,sum_y,n_i,X,Y );
  216.           sum_x =0;
  217.     sum_y =0;
  218.           X=0;
  219.           Y=0;
  220.           i_xy =0;
  221.    camera_refresh();        //更新顯示
  222.
  223. }
  224. }
Keil代碼下載: 轉hsl識別.7z (252.53 KB, 下載次數: 26)
參與人數 1黑幣 +30 收起 理由
admin + 30 共享資料的黑幣獎勵!
